Morpheus II Vs. MK-26 - Page 3 - Overclock.net - An Overclocking Community
post #21 of 79 (permalink) Old 11-11-2018, 01:15 AM
jonny27's Avatar
Rep: 3 (Unique: 3)
Yeah, mine are connected to the motherboard as well. I tried connecting them to the gpu first (with a mini 4pin adapter), but it looks like nvidia works with actual fan rpm instead of pwm percentage. No matter how much I tweaked it, I couldn't drop the pair of Silent Wings 3 below 1200rpm, which is the minimum rpm of the factory fan. Before buying the graphics card, I searched as well for one with a compatible fan connector, but now my advice is just buy whatever and hook the fans to the motherboard.
In any case, I'm using the MB's 2nd pwm connector (thankfully is true pwm), with cpu temp as a basis (don't really use any workload where I only stress the gpu) and even though it could use some more tweaking, I'm liking the result for far: a 75C result on the stock cooler dropped to 49, with the fans at 1050rpm. Boost clocks were stable through the test too, so I'm assuming the vrm's (thank you nvidia for not including vrm temp sensors, really smart that) are fine under the stock baseplate.
jonny27 is offline
post #22 of 79 (permalink) Old 11-11-2018, 01:30 AM
Goodcharly's Avatar
Rep: 1 (Unique: 1)
I don't know if it works but theorically the NA-FC1 from Noctua should let you run your fans slower. It reduces the RPM signal.
Goodcharly is offline
post #23 of 79 (permalink) Old 11-11-2018, 01:47 AM
jonny27's Avatar
Rep: 3 (Unique: 3)
In theory yes, but at this point I would just be removing one controller from the case to install another one. Also, it's now working fine as it is.
jonny27 is offline
post #24 of 79 (permalink) Old 11-11-2018, 02:16 AM
deepor's Avatar
Rep: 474 (Unique: 320)
I've seen somewhere mentioned that nvidia is nowadays checking the fan's RPM sensor reading. The card tries to find whatever PWM signal will produce a certain RPM. I mean, when you tell its fan controller to set a "30%" speed, it thinks that's intended for whatever factory fans were originally on the card. If that was a 4000 RPM fan, it then tries to run your fans at 1200 RPM, no matter what kind of fans you actually have.
If that's really how it is, the NA-FC1 would be a bit pointless, it still wouldn't really be possible to have the card control the fans.
deepor is offline
post #25 of 79 (permalink) Old 11-11-2018, 02:19 AM - Thread Starter
HeroofTime's Avatar
Rep: 2 (Unique: 2)
@Melcar If it's not too inconvenient, can you take a picture of your graphics card and show how close it is to the chipset heat sink?
I'll be following up very soon with some of the brainstorming I've been doing in regards to what I think I'm going to do. Thanks a lot for all the help guys.
AMD 1800X w/ Phanteks PH-TC14PE (3850MHz, 100MHz BCLK)
G.SKILL 3200MHz CL16 16GBx2 (3066MHz, 14-14-14-14-28-42-4-6-24-1T)
GIGABYTE GTX 1080 Ti Gaming OC (2038MHz, 5940MHz)
ASUS ROG Crosshair VI Hero (BIOS v6301)
HeroofTime is offline
post #26 of 79 (permalink) Old 11-11-2018, 04:15 AM
Goodcharly's Avatar
Rep: 1 (Unique: 1)
I see. You better check twice the GPU you buy. And I hope we will be still seing regular mini-4pin connector in the future...
post #27 of 79 (permalink) Old 11-11-2018, 04:50 AM
doyll's Avatar
Rep: 1661 (Unique: 924)
Interesting. Would you have a link to info about this PWM signal to rpm reading? We've had motherboard and GPU with 'fan not spinning' warnings, but I've never seen one that was comparing PWM% to fan rpm%. Not doubting what you say, just wanting to learn more.
doyll is offline
post #28 of 79 (permalink) Old 11-11-2018, 07:22 AM
deepor's Avatar
@doyll :
I saw this on a leaflet that came with my Arctic Twin Turbo III. I found a download for it on their website:
https://www.arctic.ac/de_en/download...al_english.pdf
There's a sentence about nvidia at the top of the second page. In the settings table at the bottom of the page you can also see that they recommend weird, very low percentages for nvidia. The fans that come with the Twin Turbo are thin 92mm fans with a 900 to 2000 RPM range.
deepor is offline
post #29 of 79 (permalink) Old 11-11-2018, 07:34 AM
Bartouille's Avatar
Rep: 57 (Unique: 44)
MK-26 isn't good. Back in the days I replaced my Windforce X3 on my 7950 with it and there was no improvement.
I don't know about Morpheus II but if you look back at this https://www.tomshardware.com/reviews...90,3671-4.html, Accelero Xtreme III can keep a R9 290 at 50C. It's worth considering too.
Personally I would just go with an AIO. Cleaner, performs better than any of these air coolers, don't add tons of weight to the card, and most importantly doesn't make your card 4-5 slots.
junkman
(20 items)
AMD RYZEN Threadripper 1950X
ASUS ROG ZENITH EXTREME
SAPPHIRE Radeon RX Vega 64
G.SKILL F4-3733C17D-8GVK
Crucial MX300 275GB
SAMSUNG Spinpoint F3 1TB
WD Blue 6TB
EVGA SuperNOVA 1300 G2
RayStorm Neo sTR4
HEATKILLER IV for RX Vega 56 & 64
MO-RA3 360 PRO (18X 9G1224G101 Sanyo Denki)
LAING D5 STRONG
7X Noctua NF-P12 redux-1700 PWM
LIAN LI PC-O11 Dynamic
Operating System
Windows 10 Pro 64-bit
Operating System
Ubuntu 18.04 LTS
ViewSonic XG2760
Keyboard
Corsair Vengeance K65
Mouse
ZOWIE EC2-A
Bartouille is offline
post #30 of 79 (permalink) Old 11-11-2018, 07:47 AM
jonny27's Avatar
Rep: 3 (Unique: 3)
And a noisy pump at all times. No thanks.
jonny27 is offline
