Arctic P12 and P120 / P14 and P140 "Pressure Optimized" Fans : reviews/discussion thread - Page 16 - Overclock.net - An Overclocking Community
post #151 of 173 (permalink) Old 05-06-2019, 06:40 AM
poah's Avatar
Rep: 4 (Unique: 3)
Quote: Originally Posted by BroadPwns View Post
I bought a value pack of 5 P14s and will get them at tuesday or wednesday. P12 for radiators is deffinitely a nice choice, very quiet and gives a nice pressure. Though can't really say anything about its airflow, except the air pushed exercised noticeably less force on my hand than SP120.
You can't go wrong with these fans unless you want RGB. You can get 5 fans for the same price as one SW3/NF-A12 with very little real world performance difference.
poah is offline
post #152 of 173 (permalink) Old 05-10-2019, 01:54 PM
The last VRM burner
Rep: 16 (Unique: 12)
I installed 3 P14 to the front, all running at 780RPM plugged to motherboard through a 4-way splitter, one P14 directly above CPU tower and installed P12 on the front of CPU cooling. Just gonna say my temperatures doesn't change when I open side panel and front glass panel. Front fans are inaudible, the P12 starts getting a bit noisy after exceeding 1300RPM but it's a low frequency sound, air noise is dominant.
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Sapphire Radeon RX580 8GB Nitro+
2x KHX2400C11D3/8GX 11-12-12-32-1T-250
Samsung 850 Pro
Toshiba HDWD10 (P300)
Corsair CS650M
Raijintek Tisis + Arctic Cooling MX4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
SteelSeries Rival 310
Mousepad
SteelSeries QCk Mini
Audio
Audio in Motion SC808
Audio
AKG K240 Studio 1st rev
Other
NZXT Hue+
Other
Mayflash F300
BroadPwns is online now
post #153 of 173 (permalink) Old 05-10-2019, 02:19 PM
Overclocker
JackCY's Avatar
Rep: 309 (Unique: 225)
Do P14 make any annoying/noticeable motor sounds at 500-1000rpm? 3pin nonPWM version preferably but I can live with 4pin PWM although they often cost more so I don't buy them.
JackCY is offline
post #154 of 173 (permalink) Old 05-10-2019, 02:21 PM
The last VRM burner
I own regular 3-pin P14, they're literally inaudible, no clicking, no motor noise, nothing until you put your ear to them, then you can hear the air moving.
PC for all
(18 items)
Samsung 850 Pro
Corsair CS650M
LianLi 330X
Operating System
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
Mousepad
Audio
Audio
Other
NZXT Hue+
Other
Mayflash F300
post #155 of 173 (permalink) Old 05-10-2019, 04:30 PM
Overclocker
JackCY's Avatar
Think I will replace the awful FD fans with motor noise, they struggle with any obstruction too, 11 blades for airflow and no pressure or pull.
JackCY is offline
post #156 of 173 (permalink) Old 05-23-2019, 12:48 PM
tiryn's Avatar
Rep: 2 (Unique: 2)
I thought I'd share my experience with these.
I bought a 5-pack of the Arctic P12 PWM PST's for £33 off Amazon a few days ago for use on a 360 radiator in a custom loop. I was using Corsair LL120's before and although I like the RGB I wanted to see how much difference more optimised fans would make.
I used 30 mins of Deus Ex Mankind Divided as my test just because that's what I'm playing at the moment.
At 1350 RPM under load my maximum GPU temps were 3c lower with the Arctic P12's.
Also 3c difference with 1800 RPM Arctic P12 vs 1700 RPM Corsair LL120.
At the same 39 dBa when using Corsair LL120'[email protected] I could run the P12's at 1500 RPM which resulted in 4c lower max GPU temps.
~40dBa is my sweetspot for noise/performance.
I measured dBa using my phone in a consistent way with everything active like mechanical hard drives, pump, 3 extra LL120's as case fans at low RPM etc...etc...
So I find the P12's definitely perform better or are quieter than the Corsair LL120 but that was to be expected given how much space the 2 LED loops take up.
I run these at 1500 rpm under load and I'm very happy with them for the price having paid just £6.70 per fan with the 5-pack.
I'll either sell the 2 I have spare or use them on a second radiator in future not sure yet.
The PST daisy-chain feature seems to work well and is handy if you run out of fan headers.
I did encounter a downside however: At maximum speed of 1800 rpm the P12's make a sort of heavy motor sound that comes and goes quickly and is annoying. Not sure how to describe it. It disappears at 1750-1700 rpm and below though so it's easy to avoid without much performance loss.
I've only tested 3 out of my 5 fans but I did test the 3 individually and they all did it. I thought perhaps it was suffering from a bad PWM signal or power issues or something so I tried without the PST daisy-chain feature hooking each one up to a separate header on my Corsair Commander Pro but it didn't change anything. If anyone thinks using my Asus mobo fan headers with bios or software control instead could make a difference I can try it out for them.
4K RGB Madness
(19 items)
Old timer
(11 items)
Intel 8700K @ 5Ghz 1.328v
ASUS ROG Maximus X Hero
NVidia RTX 2080 Founder's Edition
16GB (2x8GB) Corsair Vengeance RGB Pro 3200Mhz 1.35v
1TB Crucial MX500 SSD
2TB Toshiba HDD
750W Corsair RM750x White
Nzxt Kraken X52 AIO 240mm Rad
Corsair Crystal 460x
Operating System
Windows 10 Pro 64-Bit
24" Samsung C24FG73 1080p 144Hz VA monitor
LG 43UH603V 4K TV
Keyboard
Corsair K95 RGB Platinum
Mouse
Logitech G502 Spectrum
Mousepad
Corsair MM800 RGB Hard Mouse Pad
Audio
Logitech Z323 2.1 Speakers
Audio
Corsair VOID 7.1 Wireless Headset
Audio
Corsair ST100 RGB 7.1 Headset Stand
Other
6x Corsair LL120's Case Fans + Commander Pro Controller
Q6600 @ 3.0Ghz
MSI P35 Neo2-FIR
EVGA GTX 560 Ti 1GB
4GB Corsair XMS2 DDR2 800Mhz CL5
1TB Samsung HD103LJ
Corsair CX430W
Stock
Antec Nine Hundred
Operating System
Windows 7 Ultimate 64bit
Samsung 2232BW
Mouse
Logitech G5v1
tiryn is offline
post #157 of 173 (permalink) Old 05-23-2019, 01:10 PM
The last VRM burner
Quote: Originally Posted by tiryn View Post
[blah]
[blah]
It could be resonating with your PC case, have you tried forcing it fan was unmounted?
PC for all
(18 items)
Samsung 850 Pro
Corsair CS650M
LianLi 330X
Operating System
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
Mousepad
Audio
Audio
Other
NZXT Hue+
Other
Mayflash F300
post #158 of 173 (permalink) Old 05-23-2019, 04:32 PM
tiryn's Avatar
Rep: 2 (Unique: 2)
Aha you are right! I plugged in one of the spare P12's alone outside the case and it doesn't resonate at the max speed 1800 rpm. It sounds pleasant.
Is there anything I can do about this?
I'm curious is this why often fans have rubber on them does it help stop this effect?
4K RGB Madness
(19 items)
Old timer
(11 items)
2TB Toshiba HDD
Operating System
LG 43UH603V 4K TV
Keyboard
Mouse
Mousepad
Audio
Audio
Audio
Other
Q6600 @ 3.0Ghz
MSI P35 Neo2-FIR
EVGA GTX 560 Ti 1GB
1TB Samsung HD103LJ
Corsair CX430W
Stock
Antec Nine Hundred
Operating System
Samsung 2232BW
Mouse
Logitech G5v1
tiryn is offline
post #159 of 173 (permalink) Old 05-23-2019, 08:18 PM
The last VRM burner
You might try rubber pins from Noctua in example, instead of regular, metal screws. I can't really say about the rubber on fans but for sure using any elastic and squishy material for mounting extra hardware should take care of the resonation.
Or you could change your case.
PC for all
(18 items)
Samsung 850 Pro
Corsair CS650M
LianLi 330X
Operating System
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
Mousepad
Audio
Audio
Other
NZXT Hue+
Other
Mayflash F300
post #160 of 173 (permalink) Old 05-24-2019, 02:58 AM
doyll's Avatar
Rep: 1641 (Unique: 920)
I second the suggestion to use the rubber mounting pins. All kinds of makers / sellers of them. Look on ebay.
doyll is offline
