Arctic P12 and P120 / P14 and P140 "Pressure Optimized" Fans : reviews/discussion thread - Page 3 - Overclock.net - An Overclocking Community
post #21 of 504 (permalink) Old 11-19-2018, 09:07 PM
kd5151's Avatar
Rep: 134 (Unique: 104)
Keep in mind if the 5 packs are relatively cheap like the F14's. Then we might have new value king on our hands.
On the other hand. Looking at the design. Seems similar to something cooler master has. A quick google search and you'll know what I'm talking about.
kd5151 is offline
post #22 of 504 (permalink) Old 11-20-2018, 04:36 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Quote: Originally Posted by 8051 View Post
Arctic claims it -- and it's nothing but marketing. The static pressure ratings on these fans are anemic. I'd imagine any restriction in the exhaust or intake path of these fans would result in a large loss in CFM.
I won't be giving up my SanAce 140x38mm for any of these "pressure optimised" fans.
How do you know the static pressure ratings are 'anemic'?
Have you actually tested any of these fans to see what their static pressure actually is?
Of course any restriction to airflow will result is much lower airflow than the specs., especially if not running fan at full speed. Specified airflow is unrestricted flow .. so unless we are using fan running at full speed blowing air around a room we will never be getting full airflow. Even at full speed with your
SanAce I'm guessing when mounted in your case it's flowing 80-85% of it's rated CFM at full speed .. because the way SanAce gets it's CFM and mm H2O rating is the same way all these other fan companies get theirs .. although some to cheat a little by artificially 'balancing' the airflow to be identical on both sides of fan when in actual use the intake side will be ever so slightly lower pressure than the exhaust side.
doyll is offline
post #23 of 504 (permalink) Old 11-21-2018, 12:59 AM
8051's Avatar
Rep: 30 (Unique: 21)
Arctic posted the specs on their fans.
SanAce publishes the methods by which they measure their fans specifications here:
https://www.sanyodenki.com/archive/d...aterial_en.pdf
Please tell me specifically how they're "cheating".
8051 is online now
post #24 of 504 (permalink) Old 11-21-2018, 07:00 AM
doyll's Avatar
Could you please give me the link to Arctic F series fans, specs static pressure rating specs? I can't seem to find it. I find 2.85mm H2O static pressure @ 1950rpm for Bionix 140mm and P14 is 2.4mm H2O @ 1700rpm, but an't find static pressure rating of any F series. 2.85mm H2O and 2.4mm H2O are not 'anemic' to me .. even 1/2 of those ratings while not great is not really 'anemic'.
I think you are misunderstanding what I posted. I did not say SanAce is cheating, I said some fan companies cheat the way they gather data.
Last half of last sentence in my posts reads
"although some to cheat a little by artificially 'balancing' the airflow to be identical on both sides of fan when in actual use the intake side will be ever so slightly lower pressure than the exhaust side"
The third word 'to' should be 'do', but the key word is 'some' as in 'some fan companies'.
doyll is offline
post #25 of 504 (permalink) Old 11-22-2018, 06:42 PM
deepor's Avatar
Rep: 483 (Unique: 328)
I found the perhaps first test review of these new fans, but it's in German:
https://www.hardwareluxx.de/index.ph...hen-druck.html
The review setup seems to be pretty good the way I understand it. There's photos about what stuff they used on page four.
The fans then seem to be pretty good fans. The P14 with its price should be a good choice for anyone, the "Bionix" version maybe not. Here where I am the Silent Wings 3 High Speed are the same price as those Bionix P140 right now. The P14 are about half the price, and there's 5-packs where a single fans is getting kind of close to just a third of the price.
deepor is offline
post #26 of 504 (permalink) Old 11-22-2018, 08:15 PM - Thread Starter
⤷ αC
AlphaC's Avatar
Rep: 912 (Unique: 592)
I had updated the first post with 2 reviews I found earlier
edit: as far as pricing goes what I've seen on Amazon makes it only compelling in a 5 pack.
5 pack of P12 is $31 / €28
Cheapest P12 for single fan ~$12 / €6
Bionix P120 = $16
P14 ~ $13 / €8
Bionix P140 ~€18
5 pack of P14 = €41
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #27 of 504 (permalink) Old 11-22-2018, 08:35 PM
deepor's Avatar
Oh, I didn't look at the first post. An edit perhaps doesn't pop up in the thread subscriptions, only new posts?
deepor is offline
post #28 of 504 (permalink) Old 11-23-2018, 06:28 AM
doyll's Avatar
Very interesting bit of testing. Thanks for posting the link.
While the full speed, free airflow, grill, grill & filter and H5 flow rates and db data tells us little. But the 1000rpm radiator flow is very helpful showing use Arctic P series are as good as NF-A14 and ML140 with only Silent Wings 3 having better airflow (which many of us already know is true). But when I look at the sound pressure levels on radiator at 1000rpm and see Silent Wings 3 being 7dB louder than Arctic P series I started scratching my head and wondering what is going on here. Silent Wings 3 also has significantly higher airflow I'm not saying it isn't true, it does give me cause to wonder. I would be much less skeptical so I can understand noise level being somewhat higher too .. and if the difference was 2, 3 or even 4dB difference it would seem possible. But Silent Wings 3 being 7db louder on radiator at 1000rpm makes me wonder. Maybe they made a mistake in or their test equipment gave them a duff sound reading for P series and/or SW3, or maybe it's because SW3 is flowing 12m3/h more air and that is the cause, I don't know, .. but their 7dB difference between them does make me wonder.
I wish we had performance comparison of fans at same cfm airflow instead of just fan speed. That would give us a much better performance comparison than fixed fan speed .. but it's also more work for reviewer ...
Name:	Arctic P series by hardwaeLUXX.png
doyll is offline
post #29 of 504 (permalink) Old 12-17-2018, 07:58 PM - Thread Starter
⤷ αC
AlphaC's Avatar
AlphaC is offline
post #30 of 504 (permalink) Old 12-25-2018, 10:32 AM
RGB Rainbow Vomit!
Ricwin's Avatar
Rep: 33 (Unique: 27)
Whats the verdict on these fans? I'm planning to replace the mismatch of fans in my case with all the same model and noticed the Arctic P12's are available in packs of five for £15 for 3 pin, or £25 for PWM PST.
The PST version looks particularly useful to reduce cable clutter.
Crystal
(10 items)
O M E N
(9 items)
The Movie Box
(10 items)
Ryzen 2600
Asus TUF B450M
EVGA 1070 Ti SC Black Edition
Corsair Vengeance LPX 16Gb 2933MHz
Samsung 960 Evo 250Gb
Kingston HyperX Fury 480Gb
EVGA 750GQ
BeQuiet! Pure Rock Slim
Corsair Crystal 280X White
Operating System
Windows 10 Pro x64
Intel i7 6700HQ
Nvidia GTX 965m 4Gb
Ballistix Sport LT 16Gb 2400Mhz
HyperX Fury 480Gb
OMEN 15 by HP
Operating System
Windows 10 Home x64
Mouse
SteelSeries Rival 700
Audio
Creative Play!3 & M-Audio AV30.
AMD A8 7600 APU
MSI A88XI AC v2
AMD A8 7600 APU
8Gb Corsair DDR3 1600MHz
120Gb KingDian S280 SSD
CIT 500w SFX PSU
Arctic Alpine 64plus
Silverstone ML05b
Operating System
Windows 10 Pro x64
42" 1080p HD TV
Ricwin is offline
