Arctic P12 and P120 / P14 and P140 "Pressure Optimized" Fans : reviews/discussion thread - Page 51 - Overclock.net - An Overclocking Community
post #501 of 504 (permalink) Old 05-12-2020, 09:24 PM
sultanofswing's Avatar
Rep: 5 (Unique: 5)
I've got a bunch of P12 PWM PST's in my build and they perform only Marginally worse than my NF-A12x25's and are way quieter.
[email protected] GHz - 0 AVX @ 1.300v w/ Heatkiller Block + Delid | EVGA X299 Dark | Kingpin 2080ti with Bykski Block 2280mhz on water. | 3 XSPC 360's and 1 XSPC 480 | 32gb Corsair [email protected] | 1TB NVME/1TB Sata SSD | Seasonic Prime Platinum 1200 | Phanteks Enthoo Elite | Viewsonic XG-2703-GS | Windows 10-says pro but seems like an amateur
sultanofswing is offline
post #502 of 504 (permalink) Old 05-12-2020, 09:31 PM
AMD Overclocker
Alastair's Avatar
Rep: 261 (Unique: 163)
Anyone give me an idea on how these compare to Eloops like the B12-P or the B12-4?
If You Can Cool It! You Can Clock It! (AMD's Vishera)
GHOST rev 4
(26 items)
Rura Penthe
(12 items)
AMD Ryzen 7 3800X
Gigabyte Aorus X570 Pro Wifi
MSI VEGA 64 WAVE
Avexir Core 2 3600MHz 18-20-20-44
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
CoolerMaster V1300 Platinum
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
XSPC D5 Vario
EKWB Coolstream CE280
6 Corsair ML140's
Barrow Vega 64 full cover waterblock.
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #503 of 504 (permalink) Old 05-13-2020, 01:55 AM
Rep: 0
Quote: Originally Posted by pewpewlazer View Post
... I recall someone mentioning that they noticed that their P12/P14 fans operated at slightly different speeds for a given PWM speed %. As if there was a variance between units or manufacturing lots. ...
Yep, that was me a couple of pages back. I went through a similar exercise of plotting rpm vs pwm signal for each of my 5 P14's. 4 were very close and one significantly different. I also don't know whether the 'variant' fan was a new or an old one. I now have individual fan curves for each fan so that I can closely align their performance. You could obviously do the same, or, now that you've plotted performance, ensure that only closely matched fans share the same fan curve.
Fish#6 is offline
post #504 of 504 (permalink) Old 05-13-2020, 11:45 AM
Village Idiot
pewpewlazer's Avatar
Rep: 112 (Unique: 101)
Quote: Originally Posted by deepor View Post
@pewpewlazer :
I think that's normal, each individual fan is slightly different. Maybe also every motherboard fan header is different? And I know if I put two fans onto a Y-cable, then I get lower speed on the one fan that I can measure through the Y-cable.
I only have good measurements for two Silent Wings 3 High Speed PWM. Here's two CSV files with my measurements:
*snip*
All of these measurements were done on the exact same motherboard fan header. The fans were mounted with open air in front and behind them. The fans were in the front of the case, the side panel was open, the front panel was removed, there was no dust filter, there was no drive cages or similar behind the fans.
Interesting results. I wasn't to terribly surprised to see differences between samples of my sub $7/each fans, but I'd be pretty irritated if I had spent $20++ per fan and still had that kind of inconsistency.
The Y-splitter results don't surprise me, especially since it starts to trail off at higher speeds. The additional power draw of the second fan probably causes a bit more voltage drop.
I just went through testing my 6 front radiator fans and I'm pretty confident that there was a revision of some sort. I left the fans on the radiator, but tested one at a time. My "free air" test results show a similar trend overall, and being "on the rad" doesn't seem to affect speed until above 50%. Anyway, I had 3 new fans on the push side of the rad, and 3 old fans on the pull side. The 3 new fans all behaved similarly, and the 3 old fans were similar as well, but I averaged the 3 samples for each. New vs old however, is not so close:
PWM "NEW" P14 "OLD" P14 OLD - NEW
20% 388 254 -134
30% 556 454 -102
40% 722 650 -72
50% 872 826 -46
60% 1015 984 -31
70% 1156 1141 -15
80% 1285 1290 4
90% 1410 1427 16
99% 1565 1601 36
The low end of the "old" fans is slower, around 250-260 RPM at 20% (even in free air), while the "new" fans all run around 370-390 RPM at 20%. Even in free air, there's a distinct crossover point at around 75% where the "old" fans start running slightly higher speeds than the new ones.
I find 1000 RPM to be about the absolute limit I can tolerate noise wise, so I went ahead and swapped the old fans out for new ones so that all 6 of my front rad fans run close in speed off the same Splitty9. Whether or not it makes a difference, who knows. But it makes me feel better at least.
Derptron 9000
(11 items)
Intel i7 5820k @ 4.5ghz
ASRock X99 Extreme4/3.1
RTX 2080 Ti @ 2100/7950
16GB DDR2400 12-12-12-36
Samsung 970 EVO 1TB
EVGA Supernova 1600 T2
Walmart Great Value Distilled Water
Fractal R6 Blackout TG
LG 32GK850G + LG 32UD59
Audio
Schiit Yggy & Ragnarok -> HD800S
Other
Intel X520-DA1
pewpewlazer is offline
