Noctua DH15 and DH15S - Page 3 - Overclock.net - An Overclocking Community
post #21 of 50 (permalink) Old 01-25-2019, 05:28 AM
Fix it till its broke
Owterspace's Avatar
Rep: 2 (Unique: 2)
If you are using both drive cages, the front intakes serve only to cool those drive bays. I am just using the bottom cage, so I have one front exposed, and it doesn't do a whole lot on its own. I have a fan on the drive cage blowing towards the rear. Those top intakes help a lot. Even though I have 5 in 1 out, its more like 3 in 1 out. This definitely isn't the best case out there lol. I've also removed the filters. I am running the front fans at 7v, 12v is pretty loud but moves a lot more air. 120x38 Panaflos.. 100cfm or so at full tilt
3770K @ 4400 MHz 1.215v(Dynamic)/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/12GB G.Skill Mix @ 1866MHz 9-10-9-24 2T 1.6v
EVGA GTX 980 Classified @ 1480/2000MHz 1.212v
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG/CM Silent Pro M2 850
Owterspace is offline
post #22 of 50 (permalink) Old 01-25-2019, 05:55 AM
doyll's Avatar
Rep: 1661 (Unique: 924)
Quote: Originally Posted by ciarlatano View Post
If he is using the Define R4 in his sig, the top fan is a huge help. I had to do the same with that case. It's simply because the front intakes are so choked.
Are you referring to my reply to postem? He has Thermaltake Core V41.
GeneO does indeed have Define R4 but has replaced stock garbage Define R4 front case fans with NF-A14 Chromax fans which have decent pressure rating so case flows air just fine. I'm assuming he has removed HDD cages and has SSDs mounted elsewhere so front intakes are only limited by vent size, grill and filter. With all PCIe back slot covers removed for more rear vent area it's even better. Having another of his NF-A14 as bottom intake and extending case feet so case has 30-40mm bottom clearance also improve airflow to bottom vents dramatically.
doyll is offline
post #23 of 50 (permalink) Old 01-25-2019, 11:00 AM
poah's Avatar
Rep: 4 (Unique: 3)
Quote: Originally Posted by postem View Post
Quote: Originally Posted by doyll View Post
@postem
As has been said, top tier air coolers are easily as good as CLCs, but we need to setup case airflow so case is flowing air in sync with air cooling components' needs. This means lower airflow at idle and low load and case progressively flowing more are as componet load increases and their cooler fans' speed increases and use more air.
What case do you have? What is the case fan setup going to be with CPU being air cooled?
You might find the basic guide to how airflow works and how to optimize case airflow in below link of interest.
https://www.overclock.net/forum/22319249-post5.html
Hi doyll, thanks for your kind response.
My case is a thermaltake v41.
https://www.thermaltake.com/products...?id=C_00002499
The reason im prone to go back to Air cooling are the follows:
1) I never trusted that much AIOs (or water in general). I must give in that the AIO is keeping good temps for 2 years, it was just when i added an Axis style GPU that i crossed the "magical barrier" (at least for me) of 40c, and rising, of the coolant.
2) Due to current situation in my room, which is posed to change in 6 months, i cant manage to replace the case. The case lies behind, lined with my desk.
3) Even if sound levels are similar, and i dont think so at 1800RPM, AIO is mounted as top exaust, and fans are very near me. With fans inside the case, sound will be dampened.
Currently, 2 140 ML fans @ 60%, 1 120mm ML fan jury rigged as top intake, so 3 intake fans, and 1 rear 120mm jetflow fan @ 60%.
All fans with curves going up to 90%, except radiator fans, those make very bad noises when changing rotation, so usually i keep radiator fans around 1200-1300 RPM, and during the day, due to room temperature around 31-32c, i blast 1800-1900RPM to keep coolant below 40c.
PSU is with fan turned inside case, mostly due to very dusty enviroment.
GPU is always kept below 67c due to zotac fan profiles, but its okay in noise terms to me.
With Noctua DH15 or DH15s, i expect to keep temperatures under control without having to account for coolant temps, while keeping cpu fans at most the max of noctua.
With AIO, even with liquid > 42c, cpu never goes beyond 71c, its 5ghz 1.34v and dellided, there are 3c at most core temperature delta.
The case can support 3 120 or 140mm top fans or up to 2 200mm fans. What you think would be best for air channeling? closing the top or having fans on it? It really annoys me too that with the top grill, i have dust and other particles that often falls into the case.
I was never much of a fan of top grills as it exposes the case to every kind of contaminants than can fall.
Get some the new Arctic p series fans and turn the flow to inlet. That will lower both noise and temp.
poah is offline
post #24 of 50 (permalink) Old 01-25-2019, 11:14 AM
Optimal Pessimist
GeneO's Avatar
Rep: 115 (Unique: 88)
Yep. There is a decent airflow from the front but it is certainly restrictive.
FDR4-8086k
(22 items)
8086k 5.1/4.8 GHz @ 1.296v (AVX 0, adaptive)
Asus Maximus X Code
Asus GTX 2070 Super A8GB
32GB g.skill Trident Z RGB @ 3733 16-16-36, 1.36v
Samsung 850 EVO 1TB
Western Digitial Caviar Black 2 TB in USB 3.0 enclosure
Western Digital Black 6 TB
Western Digitial Caviar Green in USB 3.0 enclosure
Samsung 960 Pro 512 GB
Samsung 860 EVO 1TB
Seasonic Prime Ultra Titanium 750W
Noctua NH-D15 (only middle NF-A15 Chromax)
4 x Noctua NF-A14 Chromax black swap
Noctua NF-F12 Chromax black swap
Fractal Design R4
Operating System
Windows 10 Pro 64 bit
Eizo CG2730
DELL P2217H
Keyboard
Cooler Master Quickfire Rapid TKL
Mouse
Logitech G305
Mouse
perixx dx-2000
Audio
On Board SupremeFX
GeneO is offline
post #25 of 50 (permalink) Old 01-26-2019, 08:12 PM - Thread Starter
postem's Avatar
Rep: 17 (Unique: 12)
Hi just to update current situation.
Replaced H110i gtx with Noctua D15. Unfortunally i wasnt able to fit both fans inside my case (max 170mm height) and my memory is 44mm tall.
Anyway, got some impressive results. All fans are set to get into 100% after 75c. Until 70c, even noctua fans arent going 100%. For most of the time, im getting under 70c on 8700K, same temperatures as h110i with 1800 rpm fans blasting 50db in my face.
Even with fans hitting 100% on noctua, and its just one fan, its barely audible.
I made some changes too:
1) I removed h110 that was as exaust top, and i sealed the top holes with paper, at least for now; primary reason was to keep dust and other debris from getting inside, second reason was to evaluate airflow, coming directly from intake fan; there is a imediate fan below pointing to the gpu;
2) Turned psu fan to silent mode (only runs if it hits some temp, i guess its 50c+, seasonic gold), and turned psu intake to bottom, so to also not interfere with airflow
3) Replaced crappy exaust fan with noctua AF12.
System is barely audible now, and even at P95 AVX, i was hitting max 85c. After a long time of realbench, which both heat up gpu and cpu, max cpu was doing 75c, so by all means a success.
I will confirm values when room temperatures goes beyond 30c, the last two days it was between 25 and 28c.
Max gpu temps are 69 (2+ since h110 replacement), under 67% max gpu fans.
So far, i consider it a success; much less noisy and with just one fan, that is really impressive.
Now i have some questions, feel free to send your opinions:
1) Considering i cant change the case right now, i can get any benefit putting some high quality noctua 120mm fan on front of D15? 2-4c would be good.
2) I couldnt find much case variety that allows 180mm+ clearance.
The options are either full towers on some midtowers with restricted airflow intake. Someone has any suggestion of good cases with massive airflow input and clearance? Extra bonus is possible to seal top, like fractal design.
postem is offline
post #26 of 50 (permalink) Old 01-26-2019, 08:18 PM - Thread Starter
postem's Avatar
Drive cages are a damn issue. The problem, at least for me, is that i dont want to give up on my HDDs, they have decent size and performance in RAID0. Most priority stuff i put on NVME, i still wants to replace all disks with SSDs however putting another nvme will probably choke the band on 1151 platform, and even sata ssds are still costly to replace several disks.
postem is offline
post #27 of 50 (permalink) Old 01-26-2019, 10:30 PM
Optimal Pessimist
GeneO's Avatar
You will only see 1-2c difference with two fans. not worth it. I run 1.
I put my HDD in external closures so I don't have to hear them unless I need them. I now have just SSD and nvme in the case - a 960 Pro and two 1 TB EVO in Rais-0. Very quiet. Most of my data (photo images) are on external HDD - 6TB + 2 x 2 TB.
FDR4-8086k
(22 items)
Asus Maximus X Code
Samsung 850 EVO 1TB
Samsung 860 EVO 1TB
Fractal Design R4
Operating System
Eizo CG2730
DELL P2217H
Keyboard
Mouse
Logitech G305
Mouse
perixx dx-2000
Audio
On Board SupremeFX
GeneO is offline
post #28 of 50 (permalink) Old 01-27-2019, 12:15 AM
Senior OCN Member
shilka's Avatar
Rep: 2749 (Unique: 1629)
Take a look at the Phanteks Evolv X
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is online now
post #29 of 50 (permalink) Old 01-27-2019, 05:43 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
Results look good, and pretty much spot on with what you should expect from that change.
In addition to the EVOLV X, you may want to consider the Enthoo Pro M as an alternative. It will have the clearances you need, great airflow and construction, and not break the bank if you are budget conscious.
ciarlatano is offline
post #30 of 50 (permalink) Old 01-27-2019, 06:09 AM
doyll's Avatar
Phanteks released Eclipse P600S with same design concept as Evolv X, just not as many bells and whistles and a much lower price.
http://phanteks.com/Eclipse-P600s.html
doyll is offline
