GPU silencing - Page 2 - Overclock.net - An Overclocking Community
GPU silencing
post #11 of 35 (permalink) Old 04-16-2019, 02:34 AM
The last VRM burner
Rep: 9 (Unique: 7)
290X 82C on Tri-X cooler with Conductonaut paste - 82C and loud.
290X 62C on Kraken X60 - 62C and dead silent.
Trust me, I know what I write.
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Sapphire Radeon RX580 8GB Nitro+
2x KHX2400C11D3/8GX 11-12-12-32-1T-250
Samsung 850 Pro
Toshiba HDWD10 (P300)
Corsair CS650M
Raijintek Tisis + Arctic Cooling MX4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
SteelSeries Rival 310
Mousepad
SteelSeries QCk Mini
Audio
Audio in Motion SC808
Audio
AKG K240 Studio 1st rev
Other
NZXT Hue+
Other
Mayflash F300
BroadPwns is online now
post #12 of 35 (permalink) Old 04-16-2019, 03:28 AM
Rep: 2 (Unique: 2)
I have Zotac 1080 amp extreme, using Corsair H45 (120mm) to cool this gpu with the help of custom made mounting bracket. Earlier idle temps were 42-44c (with fans off) and load temps were 73-75c (triple fans @ 70%). Now it idles at 33c and load temp at 55c.
So, liquid cooling a gpu is best way to silence it.
TopM5 is offline
post #13 of 35 (permalink) Old 04-16-2019, 03:32 AM
jonny27's Avatar
Rep: 2 (Unique: 2)
You have absolutely zero clue on what you're saying. Your claim is solely based on "works on my machine™️, so nothing less will work for you". I have a Raijintek Morpheus slapped on a 1070ti which tops at 49°c @~1000rpm (so plenty of margin to drop fan speeds if I want), and even on stock coolers proper airflow goes a long way, so you have plenty of options before jumping staight to watercooling.
Also, an X60 dead silent? One of the noisiest AiO pumps ever reviewed is dead silent? I don't think dead silent means what you think it means.
jonny27 is offline
post #14 of 35 (permalink) Old 04-16-2019, 03:38 AM
The last VRM burner
Rep: 9 (Unique: 7)
Have you ever heard Tri-X cooling system? I might have exaggerated the dead silence but the pump noise (if there was any) got suppresed completely by fans in my system (all run at ~900RPM, 5 fans) and cases side panel and I didn't run fans at even 50% speed (mounted SP140 fans). Yes, I have a large clue on what I'm talking about.
PC for all
(18 items)
Samsung 850 Pro
Corsair CS650M
LianLi 330X
Operating System
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
Mousepad
Audio
Audio
Other
NZXT Hue+
Other
Mayflash F300
post #15 of 35 (permalink) Old 04-16-2019, 03:52 AM - Thread Starter
Rep: 1 (Unique: 1)
Guys, i understand you are happy with what you've got, but for me:
120mm fans mod gonna cost me around 30-40 bucks, and is gonna get me silent performance at same cooling as the stock fans or even better. Most probably a bit better.
G12 with a cheap AIO is gonna get me to 100 bucks. It voids my GPU warranty. AIOs have expiration date (pumps last so much......., especially on cheap AIOs). When my PC is not under heavy load, there's no fan running, except the CPU (which is gonna get corrected with a macho RT rev.B when it comes out). I don't want a pump running always, or at night. I can hear everything at night, and I don't want to hear a freaking pump (thus AIO coolers are never silent,.......they might be virtually inaudible, but they are never silent). And all that for dropping 5-6-7°C on already good temps at the same noise ratio.
I refloated the thread to report my findings, since there's a lot of ppl with the Meshify C and more than one or 2 had issues with GPUs being hot or noisy AND/OR maybe receive some more suggestions to work around my issues without to many cons. A G12+ AIO has way, way to many cons for me.
Tnx for the help and understanding.
Shenhua is offline
post #16 of 35 (permalink) Old 04-16-2019, 03:56 AM
The last VRM burner
Rep: 9 (Unique: 7)
Yeah, price comparision and idle performance deffinitely goes in heavy air cooling favor. Though the AiO mod provides best performance under load and it doesn't void GPU warranty, screws under stickers are also not a reason to void warranty.
PC for all
(18 items)
Samsung 850 Pro
Corsair CS650M
LianLi 330X
Operating System
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
Mousepad
Audio
Audio
Other
NZXT Hue+
Other
Mayflash F300
post #17 of 35 (permalink) Old 04-16-2019, 03:57 AM - Thread Starter
Rep: 1 (Unique: 1)
If you've red the first comment i live in Europe, and Asus gives a **** about grey areas. So stickers do void warranty.
Also my card is reconditioned.
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
post #18 of 35 (permalink) Old 04-16-2019, 04:11 AM
jonny27's Avatar
Rep: 2 (Unique: 2)
Just a heads up, if you hook up the 120mm fans to your card, things might not work as intended, learned that the hard way with my Morpheus.
The stock cooler was a blower one, with a minimum speed of 1200rpm=33%, and I bought a pair of 1400rpm beQuiet SW3, expecting a ~500rpm idle (and a mini4pin to 4pin splitter obviously). The problem is Nvidia cards, for some reason, control the fan speed by rpm, so what happened was the new fans were always idling at 1200rpm like the stock one.
In the end, I had to hook them up to the motherboard using cpu temps as a basis (because I don't have any workload where only the gpu is stressed).
jonny27 is offline
post #19 of 35 (permalink) Old 04-16-2019, 04:42 AM
April 2020
keikei's Avatar
Rep: 309 (Unique: 236)
Have you looked into fitting an aftermarket gpu air cooler? Not the perfect solution, but it'll cool your card pretty good if you can deal with some the issues.
PCMR
(17 items)
RYZEN 1700
ASROCK TAICHI X370
RADEON VEGA VII
G.SKILL Ripjaws V Series 16GB (2 x 8GB) DDR4 3200
WD Red 4TB NAS Hard Disk Drive - 5400 RPM (x2)
8TB Seagate Barracuda Hard drive internal 3.5" (x2)
SAMSUNG 860 EVO Series 2.5" 1TB
EVGA SuperNova 1300 G2
Noctua NH-U14S (CPU COOLER)
Cooler Master JetFlo 120mm Blue LED Fan (X6)
LIAN LI PC-V760B
Operating System
WINDOWS 10 64
Dell UltraSharp UP2718Q - LED monitor - 4K - 27"
Keyboard
VORTEX POK3R WHITE EDITION
Mouse
LOGITECH G305 WIRELESS GAMING MOUSE
Audio
Sennheiser HD 598 Cs Headphones
Other
Real Arcade Pro. 4 Kai Modded
keikei is offline
post #20 of 35 (permalink) Old 04-16-2019, 01:36 PM - Thread Starter
Rep: 1 (Unique: 1)
That would be next option if the 120mm fan mod doesn't work. However as i stated, the temps are good enough. I don't have a heat problem, i have a noise problem.
I know they are directly related, but since i have some margins to move around, I'm trying to avoid voiding the warranty or increase the costs as much as i can. I can afford an aftermarket cooler no problem, but as I'm trying to adapt the build the best i can for my needs, I'm also trying to make it the cheapest i can, without compromising anything. I do understand that sounds a bit contradictory for the PC enthusiast that freaks out about 70°C and spends 100-200 bucks and blasts the fan at 1500rpm just to see the CPU/GPU at 50°C.
I'm not lf it. I'm looking to make the cheapest silent build, with acceptable temps and no water cooling. I'm freaking tired of seeing water coolers everywhere, because ppl still have the image of water cooling vs air cooling of 2010, when we used to have cases designed with 0 importance on cooling.
The macho RT goes for 65€ where i live, and I'm pretty positive that in the right case/fans setup, that cooler, gives you same performance as a nzxt x62, with max RPM on both coolers. The difference in price is of 2,5 times and the AIO pump will eventually start making noise. They all do, no exception..... Also the LGM RT is by a big margin quieter.
Srry for the Offtopic......
Shenhua is offline
