GPU silencing - Overclock.net - An Overclocking Community
GPU silencing
post #1 of 35 (permalink) Old 01-22-2019, 05:34 PM - Thread Starter
Rep: 4 (Unique: 4)
GPU silencing
Current parts:
---1080 strix
---R5 2600
---Meshify C dark TG
---CM 212evo
---2 x sw3 140mm pwm high speed as front intakes, in line with, and feeding CPU and GPU
---1x X2 GP-12 as an exhaust on the back starting at 55°C on CPU (only runs on summer and at really low RPM, bellow 500)
The intake aligned with the GPU, is connected to one of the 2 GPU extra fan ports.
Here is the issue i have: the fans of the GPU on themselves are beareble up to 1800rpm (noisy as ****, but beareble), the problem is that the GPU pushes the extra fan case (sw3 1600rpm) to the max after 60°C. Current situation: 66-68°C with GPU fans at 1800+ and 1600 on the intake.
If i run the sw3 run at 900rpm and eliminate its own noise, there is a difference in GPU temps of 8°C (raises from 67 to 75) and the GPU fans go above 2200rpm which is noisy as ****.
I know what options i have, but I would like to hear some opinions of how far should i go, since some of them have drawbacks. I'll put them in order of importance.
---Changing the GPU fans for 2x120mm.
---Changing the thermal paste. I've heard it improves by a lot, and i have kryounaut at home, but it is a reconditioned GPU from Amazon and since im living in Europe, they still make use of warranty stickers......
---Cutting down from the PSU shroud (at least from the top part) and leaving enough to not compromise the build of the case, and fitting in the front 2x140mm +1x120 (it should allow me to reduce under 1000rpm on the 2 intakes that blow under the GPU).
---Buy a new Meshify C without TG, and also make an exhaust on the side at GPU level. Should help with recycling hot air. Also keep my feet warm during winter hahahahha.
Opinions???? Ideas?
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
post #2 of 35 (permalink) Old 01-22-2019, 05:52 PM
speed_demon's Avatar
Rep: 83 (Unique: 66)
@doyll
He's your resident expert on airflow. Though I will add that re-applying thermal paste on the newer Nvidia cards does not have the same large gains that older cards were seeing. It's still worth doing for many of us though. Maybe wait until the warranty is expired to do it?
speed_demon is offline
post #3 of 35 (permalink) Old 01-22-2019, 06:35 PM
Overclocker
JackCY's Avatar
Rep: 340 (Unique: 241)
I don't see any pictures of your setup at all, it doesn't matter much what components you run if you've created very likely a hot box.
JackCY is offline
post #4 of 35 (permalink) Old 01-23-2019, 05:03 AM - Thread Starter
Rep: 4 (Unique: 4)
Quote: Originally Posted by speed_demon View Post
@doyll
I bought it in August 2018 so i still have 2,5 years warranty. It's not much of an option.
I red that the thermal paste they use, even in high end GPUs it's crap. Idk to what extent tho. Tnx for the tip, I'll definitely look into it more, since i really don't wanna remove that seal unless the gains are important.
How is that? How did you come to that conclusion from a Meshify C with 2x140mm premium fans intakes in the front and 1x120avg exhaust in the rear.
I'm pretty sure you're wrong,.... at least from the CPU perspective and the cooler and the RPM im using on the fans. I use the PC for gaming, and the upper fans that impact on the CPU, in gaming run at front intake 650-700rpm~, cooler 700~, rear exhaust stopped, with temps btw 45°C and 48-51°C (depending on the day), and in prime95 small fft, front intake runs at 870~, cooler at 950 and exhaust at 400-500 with 58-60°C.
Considering I'm using a 212evo, how does that makes u think i created a hot box?
You suggest the rear exhaust being stopped impacts on the GPU thermals? I have the inferior front intake blowing at 1600RPM, and 3 of the 5 GPU brackets bellow the card removed, so it shouldn't have anything to do with the rear exhaust, but it might be worth looking into it.
Tnx for the comment anyway.
Shenhua is offline
post #5 of 35 (permalink) Old 01-23-2019, 05:29 AM
I took a look at a few pictures of your case online and it's a simple design which tells me your airflow is likely fine. And with the PCI brackets removed you are already taking a smart approach to your cooling setup.
Do you have any way to post a few pictures for us to take a more detailed look?
post #6 of 35 (permalink) Old 01-23-2019, 05:47 AM - Thread Starter
Rep: 4 (Unique: 4)
Even if the higher placed fans look very slightly missaligned. If u pay a lot of attention is the effect of the camera.
https://imgur.com/a/eyINPdL
Shenhua is offline
post #7 of 35 (permalink) Old 01-23-2019, 08:19 AM
spddmn24's Avatar
Rep: 7 (Unique: 7)
I would just do some experiments and see what works. Try blocking off the top vent on your case, run the rear fan at a tolerable level ect. If the rear fan is off you're losing a lot of air out of the top of the case before it has a chance to cool anything. Try to seal the front fans up to the front panel so they don't just recycle case air. If you have any other fans laying around try throwing them on the top as intake then exhaust.
Coffee
8700k
Z370 AORUS Gaming 7
ROG-STRIX-GTX1080TI-11G-GAMING
F4-3866C18D-16GTZKW
750 evo
850 evo
XPG SX8200
evga 750 g2
NH-D15
SilverStone Primera
Operating System
windows 10 pro
Mouse
g502 lightspeed
Audio
598
spddmn24 is offline
post #8 of 35 (permalink) Old 04-16-2019, 02:37 AM - Thread Starter
Rep: 4 (Unique: 4)
I apologize i took so long to answer, i was in a working frenzy.
I've started running for a while the rear fan aswell, but wouldn't get more than 1-2°C improvements in the hottest situation.
Now i removed the rear exhaust (fractal case fan) and mounted it in the front with the 2x140mm sw3, removed the drive cage, removed the PSU shroud front top, tucked the cables behind the right panel, mounted the SSD on the floor where the HDD cage was, and reconnected the 140mm intake from the GPU to the motherboard.
Improvements: 3-4°C better CPU temps from 49 to 45-46, GPU dropped 1°C and 100-150 RPM on the fans, and the 140mm case fan that was feeding the GPU since it's connected via splitters with the other one, now doesn't make any noise since, it tops out at 800+ rpm.
All in all, i got great improvements, especially in the noise department (which is what i am looking for). Still feel the need to mod the GPU with the 120mm, since the GPU sometimes run to 1700+ rpm..... It's not noisy or annoying on its own (without the 140mm blasting at 1600rpm), but you can definitely hear it very well.
Shenhua is offline
post #9 of 35 (permalink) Old 04-16-2019, 02:45 AM
The last VRM burner
Rep: 29 (Unique: 16)
Only watercooling is valid for your needs. 1080 Strix has a referent PCB, so you can use Kraken G12 with some other compatible AiO.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is online now
post #10 of 35 (permalink) Old 04-16-2019, 03:22 AM - Thread Starter
Rep: 4 (Unique: 4)
I wouldn't be so sure, i have 20°C room temp most of the year, and I'm fine with bellow 70-72 in gaming as long as i can run completly silent. As far as i know liquid cooling was never silent.... and if u ask me, it's completely overrated.
Right now my GPU sits around 61-62 in apex and bf1 and 66°C OW.
Shenhua is offline
