Solder the wires - Prolimatech Ultra Sleek Vortex 14 Fan - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 02-17-2019, 08:19 AM - Thread Starter
Eze2kiel's Avatar
Rep: 9 (Unique: 9)
Hi.
I need to know how to solder the wires in a Prolimatech Ultra Sleek Vortex 14 Fan.
The four wires came off when the owner of the Fan pulled a few years ago.
I would need to know where each wire goes to be soldered again.
I don't know if it is correct to place them like this:
1- Black
2- Blue
3- Red
4- Yellow
Anyone who has it clear with this?
Thanks!
Eze2kiel is offline
post #2 of 5 (permalink) Old 02-17-2019, 10:14 PM - Thread Starter
Eze2kiel's Avatar
Rep: 9 (Unique: 9)
None?
Help!
Eze2kiel is offline
post #3 of 5 (permalink) Old 02-18-2019, 03:45 AM
News Fiend
ryan92084's Avatar
Google turned up this photo from https://blog.goo.ne.jp/maple_syrup_w...d451af16e4504c
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #4 of 5 (permalink) Old 02-18-2019, 05:53 AM
In lurking mode
iamjanco's Avatar
Rep: 79 (Unique: 51)
At the motor end of the cable, as numbered by the OP in his image:
Pin Number|Wire Color|Pin Name|Description
1|BLACK|V-|GND
2|RED|+12VDC|FAN POWER
3|BLUE|PWM|DIGITAL CONTROL
4|YELLOW|SENSE or SPEED or TACH or FAN RPM|SIGNAL
At the other end of the cable (pwm fan header end):
1|BLACK|V-|GND
3|YELLOW|SENSE or SPEED or TACH or FAN RPM|SIGNAL
4|BLUE|PWM|DIGITAL CONTROL
Note: If you look closely in the OP's original image, you'll note lettering next to the solder contacts on the PCB like "P", "T", "+". Color coding in the case above doesn't necessarily follow spec, but is correct. Ref. allpinouts.org Motherboard (CPU) 4 Pin Fan
Also see:
4-Wire Pulse Width Modulation (PWM) Controlled Fans Specification, September 2005, Revision 1.3 (PDF doc)
iamjanco is offline
post #5 of 5 (permalink) Old 02-19-2019, 04:26 PM - Thread Starter
Eze2kiel's Avatar
Rep: 9 (Unique: 9)
Many THANKS kids!
Eze2kiel is offline
