Fortron Windale 4 or SCYTHE Fuma - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 03-07-2019, 11:44 PM - Thread Starter
Rep: 3 (Unique: 2)
hi all.
thinking of building new machine for myself based on asus prime x370-pro and r5 2600.
I need advice regarding cooling.
How much do you think I would lose on my current i5, switching noctua on 2600 and instead use Fortron Windale 4 or SCYTHE Fuma?
Better maybe to go with windale or fuma on 2600? I wonter if windale would be enough to keep my OC on SB. currently used for gaming, a little encoding using handbrake and playing movies. I don't think I've seen going over 65C (ambient 20-26C) except running prime and similar. case has good airflow (2x 120 noctua in front intake, 1x 120 noctua exhaust, 1x 120 side intake).
thanks.
My Machine
(14 items)
i5 [email protected],5ghz; 1,280V
ASRock Z68 Extreme4 Gen3 (bios 1.20)
GIGABYTE GTX1060 WF OC 6GB
2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27, 1,5V
Samsung 64gb (OS);256gb ser830;256gb serPM830
Optical Drive
LG GH22NS30 DVD-RAM
750W XFX Black Edition
Noctua NH-D14
CoolerMaster Centurion 534 (moded)
Operating System
Win7 Ultimate 64bit
46" Samsung 46es6710
Keyboard
Logitech
Mouse
logitech g403
Mouse
SteelSeries pad
geronimo is offline
post #2 of 4 (permalink) Old 03-08-2019, 11:37 AM
doyll's Avatar
Rep: 1636 (Unique: 918)
Quote: Originally Posted by geronimo View Post
hi all.
thanks.
I would use your NH-D14 is a better cooler with new fans, like a couple of PH-F140HP_II. The fan clips you have should work.
Considering NH-D14 is as good, maybe slightly better than NH-D15 and other coolers considered the best of the best when it has fans as good as newer coolers have I would get mount update from Noctua and use it with new fans. Noctua gives few mount updates to owners of their coolers.
Link below is to Noctua for mount updates:
https://noctua.at/en/support/mounting-and-upgrade-kits
doyll is offline
post #3 of 4 (permalink) Old 03-16-2019, 12:03 PM
⤷ αC
AlphaC's Avatar
Rep: 818 (Unique: 550)
A bit late reply but Scythe Fuma might have memory clearance issues with typical Samsung B-die modules , as it has 35mm clearance under the fin stack. In addition you need Rev B to get an AM4 mount.
The NH-D14 is still quite capable and has 44mm memory clearance, if you're looking at the Scythe Fuma then you should probably just get the AM4 mount for it.
The Windale 4 on the other hand is a downgrade in every way.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #4 of 4 (permalink) Old 03-16-2019, 03:19 PM - Thread Starter
Rep: 3 (Unique: 2)
thanks for the info.
I think I would be ok regarding ram height. I would get g.skill aegis 3000. I think they are 31.2mm. and on the SB system I had g.skill sniper and now hyper x which are also pretty low.
I think I'll put x370 / r5 2600 on hold and wait for zen2 in couple of months and then decide what to do/get.
thanks all.
My Machine
(14 items)
Optical Drive
LG GH22NS30 DVD-RAM
Noctua NH-D14
Operating System
Win7 Ultimate 64bit
Keyboard
Logitech
Mouse
logitech g403
Mouse
SteelSeries pad
geronimo is offline
