Where are the triple towers? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 49 (permalink) Old 03-12-2019, 09:43 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1240 (Unique: 680)
Quote: Originally Posted by TK421 View Post
how about the corsair aios? newest version apparently use the gen 6 cooler.
I might switch out my D15 for one of the h150i (gen6 360mm) due to unable to hold temps of my 5820K below 85c beyond 1.25v.
My H115i Pro is handling my 9900K fine, but you're unlikely to get much more performance out of an AIO than a D15. On my old 6700 I got virtually identical temps between my H115i and LGMRT. Haven't given the LGMRT a go on my 9900K, but I'd imagine it's a similar story.
Not sure what the loud comments are about, mine is basically inaudible at idle and I keep the pump on max 24/7. The only bad thing about AIOS like mentioned are the price : performance and the fact they all are going to have the pump fail at some point.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #12 of 49 (permalink) Old 03-12-2019, 11:53 PM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 162 (Unique: 127)
Quote: Originally Posted by white owl View Post
I hate everything about CLCs, they remind me of toys from the $0.99 store. Even the best CLC made cools within 10% of the best air coolers while costing 100%-150% more and requires you to buy different fans if you want it to cool like what you see in the reviews and be a quiet as air cooling...which further jacks up the cost. Then there's the reliability aspect, I've seen way too many members here saying their temps have increased over a short time. Pump still works but not enough to be effective. I hate dealing with RMAs and I hate products that were made to be as cheap as possible and mostly sold on misconceptions and in some cases flat out lies.
AIOs would be an option but there aren't any that I know of that are as reliable as I'd like and they lock you into a little eco system of compatible parts.
For the $200 it would cost to get a CLC and the fans I'd be able to get a D5+res combo and probably the CPU block with some money left over. I could probably build a really solid loop for the CPU for well under $400 using a D5 and a thick 360mm rad. Then I can add a GPU block later for $25-$40.
If you wanted to cool you CPU and GPU with AIOs to significantly beat air cooling you'd already be well into what it would cost to build a custom loop.
Plus CLC's look so uninspired, so mass produced, so bland. All the people that make them are currently having an RGB/bling battle where they try to make them as tacky as they possibly can with angular body kits and small OLED screens and what not. I like the idea of RGB but hate the way it's marketed and used.
An EK phoenix 280 is almost double a H150i though...
And the ML fans seems pretty decent from the get go
Well, I'm using a D15 dual fan on a 5820K and the temps aren't that great. Cooler maxes out around 160w if I want to keep the temps below 85c.
Will the H150i provide a significant cooling improvement is what I'm wondering.
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
TK421 is online now
post #13 of 49 (permalink) Old 03-13-2019, 03:42 AM
doyll's Avatar
Rep: 1674 (Unique: 931)
Generally when someone is having problems cooling with top tier air (like D15) the problem is not the cooler but the case not flowing cool air (air at or near room temp) into cooler when CPU and GPU are working hard. Most stock cases either don't have enough case fans or the fans are not good enough for the job and case airflow ends up being 10c, 20c, even 30c warmer than room .. and every degree warmer the air is into cooler translates almost exactly to same number of degrees hotter component is .. air 20c warmer than room giving 85c temps become 60c when air is at more reasonable 5c above room temp.
The reason CLC test results appear to be cooling better than air cooler is because of air temp into CLC as case intake is way cooler than air temp into air cooler when testing in a case built test system.
Also to get the 5-10c cooler temps CLC often have their fans are often extremely loud. Use same kind of high airflow fans for case and air cooler and temps are just as low or lower.
Below is results of CLC vs top tier air vs top tier air with hi-performance fans. Top tier air is about same temp as CLC but dramatically quieter. But with simlair noise level high airflow fans making similar noise level it is 7c cooler than CLC.
Silver Arrow SB-E, Silver Arrow SB-E Extreme vs H100
I7 [email protected] Temperature in Delta
Cooler . . . . . . . . . Delta . RPM . . . . . . dB(A) . . Fans
H100 . . . . . . . . . . 41c . . 2500. . . . . . 55 . . . . 2x
SA SB-E. . . . . . . . 42c . . 1000 & 1300. 38 . . . . TY-150 & TY-141
SA SB-E Extreme . 34c . . 2500 . . . . . . 56 . . . . 2x TY-143
H100 is 1c cooler than Silver Arrow SB-e but makes more than 3 times the noise doing it
Silver Arrow SB-E Extreme is 7c cooler with fans making similar amount of noise as H100 does.
PC-Cooling video review above data came from:
doyll is offline
post #14 of 49 (permalink) Old 03-13-2019, 07:21 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 416 (Unique: 279)
And the Swiftech H360 X3 is a better unit than the EK Phoenix, and is priced in line with the H150i.
I will agree with @ThePook and @doyll in saying the answer to that question is pretty much a resounding "no".
ciarlatano is offline
post #15 of 49 (permalink) Old 03-13-2019, 08:19 AM
white owl's Avatar
Rep: 136 (Unique: 103)
@The Pook
The loud thing comes from thermals. In a lot of tests/reviews I've seen the CLC had to be louder to actually beat a good air cooler, at the same noise level air can often do better. I hardly keep myself up to date on where the CLC market is going though.
As for EKs kits...so far everything I've seen from them can be done better or cheaper if you source your own parts. Never been big on prepackaged/bundled gear simply because there's usually something included that isn't ideal and replacing it negates the whole thing.
Haven't looked into their AIOs. If it's not a D5 I lose interest because the D5 is able to push a full loop with decent flow without being loud.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #16 of 49 (permalink) Old 03-13-2019, 08:23 AM
skupples's Avatar
Rep: 630 (Unique: 342)
because the diminishing returns on air coolers are even more extreme than that of water coolers.
skupples is offline
post #17 of 49 (permalink) Old 03-13-2019, 08:59 AM
doyll's Avatar
How can air cooling have a higher diminishing return than water cooling?
Air coolers cost less, cool as well or better than CLCs at same noise levels and about the same as AIOs that are not CLC .. often giving similar coolng to noise levels as custom loops for a fracton of money and work involved in building a custom loop.
doyll is offline
post #18 of 49 (permalink) Old 03-13-2019, 09:11 AM
9 Cans of Ravioli
The Pook's Avatar
The H100 is a 9 year old AIO with a gen 1 pump, and yeah, it was super loud. It made me go back to air after I moved from AM3. Even the fans are 40dBa on the H100 versus 20.4 on the Pro lineup.
If your ("modern") AIO is noisy then it's faulty
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Mouse
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #19 of 49 (permalink) Old 03-13-2019, 09:27 AM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
https://www.youtube.com/watch?v=q6xrsuPwDbo
I have
Phanteks Enthoo Luxe
All NF A14 PWM fan (beige)
2x intake front to HDD bay
3x intake top (mesh) to inside PC case
1x exhaust rear
I'm not getting that great of temps to my cooler, even with a positive air pressure config.
Do you have data on the H150i or any of the Gen 6 pumps?
H360 x3 is better?
Any temp comparison and overall QC comparison?
How about the reliability of the cooler without maintenance (no drain/refill)?
The issue is that I'm unwilling to disassemble the open loop at all.
@The Pook
The Phoenix struck my interest since it's advertised as prebuilt and can easily add a GPU block if need be.
I'm not sure how maintenance free it is though. And it's more expensive than all the options for CLCs. Even when buying H150i + EVGA hybrid kit.
TK421 is online now
post #20 of 49 (permalink) Old 03-13-2019, 09:57 AM
doyll's Avatar
First off, almost all AIOs you are referring to are CLCs, a sub-group of AIO and not near as well built as AIOs that are not CLCs. Asetek's almost monopoly on CLC cooling with sales as good as they are means they have no real incentive to improve product. They change the looks a little, add RGB and call it a new 'generation' product.
All of this 1st gen, 2nd gen, etc hype is just that, hype with little to no real changes in pump, raidator, etc. I have seen nothing that indicates there is any real functional difference in performance from original H100 vs most resent Asetek CLCs using same size radiators. They have changed to quieter fans, but that has also lowered their maximum cooling ability.
Asetek has published almost nothing of their pump performance so we have no way of knowing what their lift and flow rates .. but from what few independent tests I've seen there is no real difference in pump flowrate from original Asetek to latest generation .. all have a flow rate about equal to what a healthy adult can urinate which is 40-60 L/h .. somewhere between 34 L/h to 61 L/h.
If you have any data and supporting links please post them so we can see the differences.
doyll is offline
