Where are the triple towers? - Page 5 - Overclock.net - An Overclocking Community
post #41 of 49 (permalink) Old 03-14-2019, 09:36 AM
NewType88's Avatar
Rep: 1 (Unique: 1)
Forget the triple tower coolers, make the case a giant heatsink that can dissipate 2000w boiiii.
How big would a single tower need to be to have that sort of thermal performance I wonder ?
NewType88 is offline
post #42 of 49 (permalink) Old 03-14-2019, 10:38 AM
Melcar's Avatar
Rep: 636 (Unique: 438)
Wasn't there a concept case a while back that acted as a heatsink of sorts?
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #43 of 49 (permalink) Old 03-14-2019, 02:23 PM
NewType88's Avatar
Rep: 1 (Unique: 1)
Ya I've seen something like that, the NSG S0, but it dissipates 180w for CPU and 250w for GPU. The case looks pretty cool, they could design another one to accept fans in a discrete looking way, as to still give it a fanless look.
post #44 of 49 (permalink) Old 03-14-2019, 09:13 PM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 160 (Unique: 125)
Quote: Originally Posted by doyll View Post
First let us do a little simple physics. Your case can only flow as much air in as it is flowing out .. the in vs out / out vs in airflow is the smaller of the in or out. Your case has 5 fans trying to push air into a case with only a back and a bottom vent to let air out. That means the 5 intakes an only move as much air into case as back and bottom vents and let out and as the back and bottom vent area is only about half what the front and top are, your intake fans can only flow at most about half as much air as their potential. And in a system needing a 140mm of air for CPU cooler and 1-2x intakes for GPU that's not enough cool airflow.
Top fan farthest to the back is running the opposite direction of what it should .. if a top fan is even used there.
Middle top fan fan is blowing down into cooler that has 2x fans trying to flow air back thru cooler and out of case.
Only the front most top fan might be helpful, and it's limited by 5.25" bay cage.
As others said, remove the PSU shroud and use bottom intake to flow air up toward PSU.
That bottom intake will also flow much better if case is raised 20-30mm so there is about 40mm of space between bottom of case and what it's setting on. This give about the same airflow area to bottom vents as bottom vent area airflow. I use and open top caster base bu
t longer feet, square wooden blocks, hockey pucks, spray can caps, etc will all work. Here's link to details about this:
https://www.overclock.net/forum/22657923-post15.html
Above link also has info about how restrictive vent grill and filters are.
Here is a link to Define R series case mods to improve airflow.
https://www.overclock.net/forum/23754692-post48.html
Not sure if I've posted it, but here is link to info about how airflow works and how to optimize case airflow and cooling.
https://www.overclock.net/forum/22319249-post5.html
Tried your suggestion of removing bottom cage
The top fans are now exhaust
Repasted and dusted a bit
I still max out at around 200w but the temps are peaking at 90c on cpu package (4.4 1.37v), only small improvement.
https://i.imgur.com/kL5cEek.png
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
TK421 is offline
post #45 of 49 (permalink) Old 03-14-2019, 09:44 PM
Melcar's Avatar
It would be helpful if you could give us the room temp and the temp inside the case. Are you using both HDD cages?
The Luxe has this silly front shield that covers the front intakes. Many people remove that (case won't be as pretty).
Another thing you could do, if you are not using the top drive cage and the 5.25" cage, is to remove both. That helps a lot in getting air faster to the CPU cooler. It is how I'm currently running my Enthoo Pro.
Sent from my Redmi 4A using Tapatalk
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #46 of 49 (permalink) Old 03-14-2019, 10:09 PM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Room temp 24c.
The shield is removed, I forgot to mention that. But I don't think that would matter much.
I'm using both the HDD cage, but the 5.25" is empty. Is it possible to remove the 5.25 bay?
I can test with the side panel removed, if that would help?
TK421 is offline
post #47 of 49 (permalink) Old 03-14-2019, 10:46 PM
Melcar's Avatar
Yes, you can remove the 5.25" bay. However, since you are using both HDD cages it may not be a good option. The top HDD drive cage latches to the bottom of the 5.25" cage, so removing it may reduce the stability of your HDD cages.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #48 of 49 (permalink) Old 03-15-2019, 03:21 AM
Professional Lurker
Fullereneshift's Avatar
Rep: 0
Monsterlabo The First is in production. According to their website it can handle a 9900k and GTX 1080 passively cooled while still being small form factor (19L). There is a bottom mount for a 140mm fan, and a 200mm top mount in the works.
Iterated
(12 items)
Ryzen 5 2600
MSI B450M MORTAR
XFX RX 480 GTR
Team Group Vulcan
Intel 660p
EVGA G2
Phanteks PH-TC14PE (Black)
Fractal Design Meshify C Dark TG
Operating System
Win
Mouse
Logitech G703
Mousepad
SteelSeries QcK+
Other
be quiet! Silent Wings 3 140 High-Speed
Fullereneshift is offline
post #49 of 49 (permalink) Old 03-16-2019, 08:32 PM
Fix it till its broke
Owterspace's Avatar
Rep: 4 (Unique: 3)
Zalman did one years ago, there is on on ebay for 995us.
https://www.google.ca/search?q=zalma...w=1920&bih=977
3770K @ 4700MHz 1.375v/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/12GB G.Skill Mix @ 933MHz 9-10-9-28 2T 1.57v
EVGA GTX 980 Classified @ 1480/2000MHz 1.212v
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG + Many CFM's /CM Silent Pro M2 850
Owterspace is offline
