Where are the triple towers? - Overclock.net - An Overclocking Community
post #1 of 49 (permalink) Old 03-11-2019, 10:52 PM - Thread Starter
ltpdttcdft's Avatar
Rep: 35 (Unique: 30)
Once in a while cooler manufacturers come up with things like the Alpenfohn Everest that never make it into production.
Why doesn't this exist yet?
Here is my idea of what a triple-tower Noctua might look like:
ltpdttcdft is offline
post #2 of 49 (permalink) Old 03-12-2019, 07:09 AM
doyll's Avatar
Rep: 1645 (Unique: 922)
Probably because they don't improve cooling.
A top tier single tower (TRUE Spirit 140 Power) is as good or better than any of the twin towers out there.
Independent testing has shown NH-D14 is every bit as good and probably a little better cooling than NH-D15 when both are using same fans, and TRUE Spirit 140 Power gives 2-3c cooler temps than D14 on i7 [email protected]
It seems heatpipe cooling is close to it's maximum ability without some sort of new tech. The change from solid material heatsink to heatpipe heatsink made a huge difference in cooling .. and some types of heatpipes perform better than others but only marginally.
There were some vapor chamber coolers marketed but they suffered from problems like base not being flat. In 2013 I tested ID-Cooling FI-REEX Deluxe (got 3 coolers to get 1 with flat base .. I was able to lap 2 flat and 34d was warped too much to even lap flat). FI-REEX is a single tower 160x140x88mm (HxWxD) w/o fans, 113mm deep w/ 1x fan, 138mm deep w/ 2x fans. It has 6x 8mm vapor chamber pipes and 2x 'U' 8mm heatpipes with a rating of 300w. I found it cooled as well as TRUE Spirit 140 Power rated 360w. ID-Cooling has discontinued FI-REEX for a black colored version called Hunter VC-3D using 2x 140mm fans. I need to try getting new Hunter VC-3D and test it.
doyll is offline
post #3 of 49 (permalink) Old 03-12-2019, 09:45 AM - Thread Starter
ltpdttcdft's Avatar
I was wondering how a slim 140mm single tower could win and suspect it's only because of mounting pressure.
I just checked and the TRUE Spirit 140 Power screws directly into the mounting plate (no springs).
Just like the old version of the Scythe Fuma without springs matching coolers well above its weight class, new version has spring mounting and performs normally for its size.
post #4 of 49 (permalink) Old 03-12-2019, 12:39 PM
doyll's Avatar
Honestly springs in spring mounted bases do little or nothing, but you are correct, higher pressure does usually give better heat transfer. Really the best way to get good heat transfer is to have good TIM print in the area the CPU die/chip is in contact with it's IHS and from IHS into cooler base.
Reasons are not very complicated. TRUE Spirit 140 Power has 8mm diameter heatpipes while most other cooler have 6mm diameter heatpipes. That's more surface area contacting fins and inside of heatpipe wicking area moving liquid back to heat source and also more volume for vapor toward ends and release heat. More volume means more heat can be moved from base to fins.
Most of the heat from heatpipes radiating into the fins is cooled off in a first 15-25mm radius of heatpipe so large finpaks fin area doesn't improve cooling much if at all, and the faster the airflow over fins the quicker the heat is removed from them.
Also keep in mind that twin towers are using the heated air from front tower to cool the back tower.
Combine them all and hopefully you will understand why twin tower or triple tower coolers are often no better if as good as single tower coolers.
doyll is offline
post #5 of 49 (permalink) Old 03-12-2019, 02:32 PM
Mr.4way SLI
Moparman's Avatar
Rep: 190 (Unique: 171)
I compared the NH-D14 years ago to a few other coolers Box stock and with same fan setups and countless hours of testing. I still use the Assassin to this day with a 3 fan setup.
https://www.overclock.net/forum/246-...per-212-a.html
Moparman is offline
post #6 of 49 (permalink) Old 03-12-2019, 03:26 PM
white owl's Avatar
Rep: 136 (Unique: 103)
I totally agree, heat pipes have peaked and it seems like simply adding more of them or using more surface area provides diminishing improvement. The bigger towers do seem to do a little better when you're using CPUs that draw a lot of current but on desktop chips it would seem like adding more fins and pipes doesn't make the CPU any cooler.
It's kinda like idle temps, they're going to be about the same on a wide range of coolers, likely because the silicon and the oxide layer on top of it aren't great conductors of heat so they resist putting heat into the cooler.
It seems like we need a new type of cooling but IMO water is just too costly and large if you really want a step up from air.
If I'm ever flush again I may build a loop with the intention of keeping it around forever. The performance difference between EK's blocks and their knock offs are very small so rads and a pump would be my main cost...which is still pretty expensive if you want a long term pump like a D5.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #7 of 49 (permalink) Old 03-12-2019, 04:17 PM
TK421's Avatar
Rep: 157 (Unique: 122)
how about the corsair aios? newest version apparently use the gen 6 cooler.
I might switch out my D15 for one of the h150i (gen6 360mm) due to unable to hold temps of my 5820K below 85c beyond 1.25v.
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴ
Desktop for gaming
(17 items)
ThinkPad T480
(9 items)
ThinkPad T430 XM
(9 items)
i7 5820K
X99 Deluxe
RTX 2080 Ti XC Ultra
Crucial 4x4GB
Samsung 950 Pro 512GB
Samsung 850 EVO 1TB
WD Black 4TB
WD Red 10TB
Optical Drive
Dell CH03N BD
EVGA 750 G2
Swiftech Drive H360X3
Phanteks Enthoo Luxe
Operating System
Windows 10 Enterprise LTSC 1809
BenQ XL2430T
ASUS PG279Q
Keyboard
Bloody B850
Mouse
Logitech G102 Prodigy (Mercury)
i7 8550U
Lenovo Windu-2 20L5
Intel UHD 620
F4-3000C16D-16GRS | 2x8GB 2400MHz
Intel NVME SSD 256GB
Lenovo 65w USB-C
Delta 01YR200
Operating System
LP140WF6-SPB7 FHD IPS
i7 3920XM
Nozomi 4 Type 2344 BZU
Intel HD4000
F3-2133C11-8GSRL | 2x8GB 2133MHz
Samsung 850 Pro 256GB
Lenovo 90W
Operating System
AUO B140HAN01.3
Keyboard
Classic 7-row NMB 45N2211
TK421 is offline
post #8 of 49 (permalink) Old 03-12-2019, 06:00 PM
white owl's Avatar
I hate everything about CLCs, they remind me of toys from the $0.99 store. Even the best CLC made cools within 10% of the best air coolers while costing 100%-150% more and requires you to buy different fans if you want it to cool like what you see in the reviews and be a quiet as air cooling...which further jacks up the cost. Then there's the reliability aspect, I've seen way too many members here saying their temps have increased over a short time. Pump still works but not enough to be effective. I hate dealing with RMAs and I hate products that were made to be as cheap as possible and mostly sold on misconceptions and in some cases flat out lies.
AIOs would be an option but there aren't any that I know of that are as reliable as I'd like and they lock you into a little eco system of compatible parts.
For the $200 it would cost to get a CLC and the fans I'd be able to get a D5+res combo and probably the CPU block with some money left over. I could probably build a really solid loop for the CPU for well under $400 using a D5 and a thick 360mm rad. Then I can add a GPU block later for $25-$40.
If you wanted to cool you CPU and GPU with AIOs to significantly beat air cooling you'd already be well into what it would cost to build a custom loop.
Plus CLC's look so uninspired, so mass produced, so bland. All the people that make them are currently having an RGB/bling battle where they try to make them as tacky as they possibly can with angular body kits and small OLED screens and what not. I like the idea of RGB but hate the way it's marketed and used.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #9 of 49 (permalink) Old 03-12-2019, 06:46 PM
Overclocker in training
ThrashZone's Avatar
Rep: 62 (Unique: 48)
Hi,
Probably cracked a few mother boards and said oops that's not going to work
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #10 of 49 (permalink) Old 03-12-2019, 08:23 PM - Thread Starter
ltpdttcdft's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
...and now the latest generation of coolers have wimpy springs due to Intel CPUs with thin PCBs.
