Updating/Upgrading all fans on case and aio's - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 03-19-2019, 06:02 AM - Thread Starter
Pedros's Avatar
Rep: 31 (Unique: 28)
So ... the day as come where i'm so fed up with the fans i have. Currently, i have Coolermaster Masterfan Air Flow and Air Pressure fans and they are so noisy ... either from the actual noise of the bearing and from the structure of the fan itself, since the fan oscillation makes it sometimes contact the case chassis and ... it's just meh!
So, upgrading all this stuff ... it's going to be painful ...
4 x 140mm Airflow fans ( bottom and top of the case for intake/exhaust )
4 x 140mm Air Pressure fans ( front of the case, push/pull for x62 )
2 x 120mm Air Pressure fans ( rear of the case, push/pull for Seahawk X )
I was looking for the existing fans in the market ... without RGB ... I was thinking about the Noctua's Industrial or the Silent Wings 3, but i'm more into the SW3 for the price difference.
Any pieces of advice here? Other fans that are worth considering?
"Oh...your ass is grass and I've got the weed-whacker."
The Hive
(17 items)
i7 4790K 4.8Ghz @ 1.31v (Delided)
Msi Z97 Gaming 7
MSI GTX 1080Ti Seahawk X
Kingston HyperX Savage
Samsung 960 Pro M.2
Crucial MX500 2Tb
XFX Black Pro 1250W
Corsair H105 Push/Pull
Corsair Carbide Air 740
Operating System
Windows 10
LG 32" 32GK850G
Keyboard
Logitech G512 / Ducky One Mini
Mouse
Glorious XXL
Mouse
Logitech G Pro Wireless
Audio
Philips Fidelio X2
Audio
WHARFEDALE10.2 + WHARFEDALE D10
Audio
Burson Playmate + Burson Bang Amp
Pedros is offline
post #2 of 11 (permalink) Old 03-19-2019, 06:56 AM
To The Game
Chargeit's Avatar
Rep: 292 (Unique: 198)
I'd avoid filling up every fan spot and instead try to keep an airflow path (try to avoid having fans fight each other). I'd look into hooking the fans up to a controller or your mobo. I run my case fans off my mobo and usually have a fairly conservative curve set. A well set curve can go a long way to keeping your fan noise under check. I normally set a max fan speed of 80% on my case fans and even lower on my cpu fans.
Worth mentioning pretty much all fans will get annoying if you allow them to hit their max. I don't see a reason to go for silent/low rpm fans when you can get good higher rpm pwm fans and limit the max fan speed. Those Noctua's are really good fans but make sure to limit them to 70 - 80% otherwise they'll sound like jet engines.
Chargeit is offline
post #3 of 11 (permalink) Old 03-19-2019, 07:00 AM
The last VRM burner
Rep: 44 (Unique: 27)
https://imgur.com/FoO8sME.jpg
https://imgur.com/pf8F4F3.jpg
Two pictures which should interest you.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 11 (permalink) Old 03-19-2019, 07:04 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1324 (Unique: 703)
push/pull on an AIO is a waste, the rad isn't nearly thick enough and the fins aren't dense enough for it to be needed. I ran push/pull on my H115i for a bit and went back to push only.
I like my NF-A14 iPPC-3000s (but I rarely run them more than 20-30% unless I'm benching) but they're not cheap. The Bitfenix Specre Pros, Silent Wings, EK Vardar, NB eLoops, and Corsair ML Pro fans are good too.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (Blues)
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #5 of 11 (permalink) Old 03-19-2019, 08:08 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 428 (Unique: 285)
You should be more into the SW3 due to the performance difference. The Noctua iPPC don't stack up as the charts @BroadPwns pointed out show. And, as noted by @ThePook , push/pull on a CLC is pretty much a waste of time that does nothing but add noise.
And you need to not think in terms of "airflow" and "air pressure" fans. What you need to look at is the PQ relative to the application. Since your case is going to have some restriction (in most cases equal to a rad), the things marketed as "airflow" fans usually can't overcome it to move a proper amount of air.
ciarlatano is online now
post #6 of 11 (permalink) Old 03-20-2019, 10:55 AM
poah's Avatar
Rep: 7 (Unique: 6)
arctic P12 and P14.
poah is offline
post #7 of 11 (permalink) Old 03-20-2019, 11:12 AM
9 Cans of Ravioli
The Pook's Avatar
Quote: Originally Posted by ciarlatano View Post
@ThePOO k
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Operating System
Operating System
MX Linux
Keyboard
Mouse
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #8 of 11 (permalink) Old 03-20-2019, 11:36 AM
ACleverName's Avatar
Rep: 14 (Unique: 12)
Quote: Originally Posted by The Pook View Post
Lol i noticed that
Just Roll With It
ACleverName is offline
post #9 of 11 (permalink) Old 03-20-2019, 11:41 AM
Melcar's Avatar
Rep: 637 (Unique: 439)
Agree with others on the push/pull. Not worth it on a CLC.
If you don't care much about looks, the ML140/120 two packs can't be beat for the price. I have not used the fans, but Thermalbench (which I regard very highly) has them among their best. Many people don't like the fans however.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #10 of 11 (permalink) Old 03-20-2019, 12:09 PM
waifu for lifu
keikei's Avatar
Rep: 327 (Unique: 245)
I nearly went and bought $ sound dampening material, when i found it was possible to tweak the fan speed in the bios a few weeks back. No need to hit 100% fan speed when not necessary. Great advice.
PCMR
(18 items)
AMD RYZEN 7 1700
ASROCK TAICHI X370
EVGA RTX 2080 Ti XC2 ULTRA
G.SKILL Ripjaws V Series 16GB (2 x 8GB) DDR4 3200
WD Red 4TB NAS HDD (x2)
8TB Seagate Barracuda HDD (x2)
SAMSUNG 860 EVO SSD 1TB
WD Blue SSD 2TB
EVGA SuperNova 1300 G2
Noctua NH-U14S (CPU COOLER)
Cooler Master JetFlo 120mm Blue LED Fan (X6)
LIAN LI PC-V760B
Operating System
WINDOWS 10 64
Dell UltraSharp UP2718Q - LED monitor - 4K - 27"
Keyboard
LEOPOLD FC980M / MAXKEY SA CHOCOLATE KEYSET
Mouse
LOGITECH G305 WIRELESS GAMING MOUSE
Audio
Sennheiser HD 598 Cs Headphones
Other
Real Arcade Pro. 4 Kai Joystick modded
keikei is offline
