Noctua NH-U12A: Game Changer? - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 03-19-2019, 03:01 PM - Thread Starter
Rep: 6 (Unique: 6)
Is Noctua NH-U12A suitable for an Intel Core i9-9900K with reasonable overclock in a good case?
lb_felipe is offline
post #2 of 15 (permalink) Old 03-19-2019, 03:14 PM
Senior OCN Member
shilka's Avatar
Rep: 2775 (Unique: 1642)
The cooler is not even out yet and there are no reviews or info at this stage so you are asking a question that cant be answered
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
EVGA SuperNova G2 750 Watt
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is online now
post #3 of 15 (permalink) Old 03-19-2019, 03:17 PM
⤷ αC
AlphaC's Avatar
Rep: 911 (Unique: 592)
It is probably going to perform on par with an average twin tower cooler at 1200-1300RPM when used at 2000RPM.
In other words, as long as you aren't going nuts with voltage or using AVX instructions without offsets you ought to be fine with it as you'll remain under ~200W.
The price is iffy though without reviews , most of the price is from the two $30 fans. For $50-60 you can buy a Scythe Mugen 5 or NH-U14S , the former with a weaker 1200RPM fan and the latter having a taller tower with 140mm fan @ 1500RPM.
The fin area and weight is quite similar to the NH-U14S , but it's likely a few percent less fin area vs the Mugen 5 (although the fin area is deeper on the Mugen 5 and the NH-U12A has an extra heatpipe).
Mugen 5 has 39 fins (2.0mm fin spacing and 0.4mm fin thickness) , 85mm depth and 130mm width, around 750g
NH-U12A has over 50 fins , 58mm depth and 125mm width, 760g
(the increase to 58mm from 45mm depth is +29% , heat pipes went up from 5 to 7 which is the largest change, likewise weight went from 580g to 760g which is +31%)
NH-U14S has 51 fins (57 if you count the smaller ones underneath, 0.42mm fin thickness, 1.72mm fin spacing) , 150mm width and 52mm depth, 770g
In essence from the key metrics (heatpipes, heatpipe construction , fin area , and amount of mass) it should do quite well. From VSG's testing on restriction (radiator) the fan outperformed the TY-143 140mm fan https://www.techpowerup.com/reviews/...x25_PWM/5.html and noise should be lower than 500RPM more on the NF-F12 used on the older NH-U12S. See also https://www.overclockers.com/noctua-...25-fan-review/
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #4 of 15 (permalink) Old 03-20-2019, 05:16 AM
Tetrapyloctomist
Aenra's Avatar
Rep: 37 (Unique: 23)
Currently, the only point of interest for me is the soldering. Which as far as this cooler may be concerned, is also the only thing that really stands out; well, for people uninfluenced by hype that is.
Assuming someone half capable ever bothers, another (and future, not present) point of interest would be its rather apparent scaling potential. For the non - 'my precious/sensitive/SPECIAL/i have needs' people that can "withstand" some extra noise, this could be quite the solution.
*admittedly, a rather ridiculous solution.. pay over 100 for the cooler, only so as to ditch the 2K RPM fans and replace them with others; which you'd also have to pay for.. but still, i'm curious as to the results.
(btw, why the focus on the extra heatpipe?.. Have seen it mentioned here, other forums as well; how many more times must this happen before you [plural] learn that one heatpipe more, or less, means nothing? Or can mean nothing)
Pride, honour and purity.
Aenra is offline
post #5 of 15 (permalink) Old 03-20-2019, 05:02 PM
Abula's Avatar
Rep: 38 (Unique: 33)
To me its as good as it will get for a 120mm fan CPU cooler, given that we haven't seen reviews, the NF-A12x25 is a ninjaded Scythe Gentle Typhoon, which perform very well on rads and heatsinks, and the increase area and pipes should help some. I think its going to be close to a twin tower or even a 140mm like the U14/TSP140, but will see once reviews come up, the only problem that i see on this cooler is its price, the two NF-A12x25 don't help to keep the cost down, i would have thought that would been better for noctua to release it with only 1 and include the clips for the second and people could add the second fan if they wish.
I pre ordered one should come in a couple of weeks, i also have an NH-D15s on my test bench with a Gigabyte Z390 Aorus Master + i 7 8086k (delided with lm + custom cooper ihs), also will be testing a Mugen 5 with the stock fan and with the NF-A12x25, all heastinks will be mounted using Noctua NT-H2.
GAME - Intel i9 9900K | AsRock Z390 Tachi | G.SKILL 32GB DDR4 3200Mhz | Asus RTX2080Ti Strix | Samsung 970Pro 1TB + Samsung 860Pro 4TB
SIM - Intel i7 8700K | AsRock Z370 ITX/AC | Corsair 16GB DDR3000 | MSI RTX2080ti Duke | AData XPG 8200 Pro 1TB
SB - Intel i9 7940X | AsRock X299 Fatal1ty | G.SKILL 32GB DDR4 3200Mhz | Asus GTX1660Ti
WS - AMD 1950X | AsRock X399 Taichi | G.Skill 32GB DDR4 3200Mhz | 9271-8i 22TB Raid6 | Intel 900p 480GB
Abula is offline
post #6 of 15 (permalink) Old 03-20-2019, 05:21 PM
Melcar's Avatar
Rep: 636 (Unique: 438)
Yeah, they should have gone with a single fan config with extra clips. Unless the fin stack REALLY needs a push/pull fan setup, which I doubt is the case.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #7 of 15 (permalink) Old 03-20-2019, 06:34 PM
white owl's Avatar
Rep: 136 (Unique: 103)
I'd prefer something that fits 140mm fans if space allows.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #8 of 15 (permalink) Old 03-20-2019, 08:07 PM
Shadowarez's Avatar
Rep: 25 (Unique: 22)
Its available just not cheap.
Sent from my SM-G965W using Tapatalk
Shadowarez is offline
post #9 of 15 (permalink) Old 03-21-2019, 05:55 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 416 (Unique: 279)
Uhhhhhh....yeah.....no. They have distinctively different characteristics and performance - https://www.techpowerup.com/reviews/...x25_PWM/5.html
About the only things the NF-A12X25 and GT have in common is that they are 120mm fans.
ciarlatano is offline
post #10 of 15 (permalink) Old 03-21-2019, 06:19 AM
Tank destroyer and a god
Offler's Avatar
Rep: 87 (Unique: 68)
I cant help myself, but i read all that text in voice of Foamy...
On topic... NF-A12x25 are clearly great fans from my experience, better than standard 120mm Noctua fans used recently with ... same cooler body. The overall cooling performance is definitely better.
--- Building in progress * AMD Threadripper 1900x * Asrock X399M Taichi * Radeon VII * Gskill Xflare / Samsung B-die 3200 14-14-14-32 * Samsung 970 PRO 512gb * Fractal Design Node 804 * Seasonic Prime Ultra 850 Titanium *
--- Desktop * AMD Phenom II x6 1090t @ 3,8GHz * ASUS M5A99FX PRO R2.0 * Gigabyte R9 FuryX * A-Data XPG 2.0 / Elpida Hyper MNH 1866 @ 1600 6-6-6-18 * LSI 9211-8i / Raid 0 / 5x Corsair Force 3 GS * Creative Xfi Fatal1ty * Intel I210-T1 * Steelseries 6Gv2 * Logitech MX518 * Samsung U28E590D *
Offler is offline
