Silverstone AP183 is out (aka WHAT WAS THAT I CAN'T HEAR YOU) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 28 (permalink) Old 09-22-2019, 10:43 AM
Overclocker
JackCY's Avatar
Rep: 340 (Unique: 241)
Yes it is but it's a grill that blocks. I get it why they used it, but it is not necessary for the directed output they tried to achieve, it can be done with blade shape. From my own experience grills are noisy and add a lot of restriction. They probably took care so it's not a loud grill but it will still block noticeably.
JackCY is offline
post #22 of 28 (permalink) Old 09-22-2019, 11:40 AM - Thread Starter
Tetrapyloctomist
Aenra's Avatar
Rep: 22 (Unique: 20)
I'm past understanding you people; i just amuse myself now, sorry to put it thus, but..
You're after a short, brightly lived beast like a silverstone AP fan; but worry about noise........ and/or low RPM performance.......... sure thing.
Tell us more.
Pride, honour and purity.
Aenra is offline
post #23 of 28 (permalink) Old 09-22-2019, 12:34 PM
Fix it till its broke
Owterspace's Avatar
Rep: 4 (Unique: 3)
Quote: Originally Posted by Aenra View Post
I'm past understanding you people; i just amuse myself now, sorry to put it thus, but.. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Tell us more.
I run 120x38s in my case, and at 7v they probably move more air than the 140s people rave about all the time, and does so quietly, not to be confused with silent. At 12v though that’s another story. I do find it nearly impossible to believe you can achieve maximum performance silently.
3770K @ 4600MHz 1.315v/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/12GB G.Skill Mix @ 1866MHz 9-10-9-24 2T 1.6v
EVGA GTX 980 Classified @ 1480/2000MHz 1.212v
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG/CM Silent Pro M2 850
Owterspace is offline
post #24 of 28 (permalink) Old 09-22-2019, 06:51 PM
- Insanity Beckons -
Elrick's Avatar
Rep: 173 (Unique: 89)
Quote: Originally Posted by JackCY View Post
That rear integrated grill though
Price is nuts for a piece of plastic. You could fill out a case with 140mm fans for that.
Agreed but what I had installed previously inside that case was somewhat loud when allowed to run at full speed, exactly like a jet engine.
I only purchased this latest release of a PWM fan model that runs at lower speeds there fore being sufficiently quiet. As long as you get slight air movement inside this case then everything works perfectly in removing old hot air from inside the case quietly.
All up now have only 4 fans altogether that work, 2 AP183's on the bottom of the case - 1 140mm Fan in front of the HR-22 and 1 Fan - 120mm as the exhaust, above the HR-22.
Elrick is offline
post #25 of 28 (permalink) Old 09-22-2019, 07:05 PM
Skating Enthusiast
steelbom's Avatar
Rep: 146 (Unique: 117)
Currently have an FT05 which is a bit small for me, so looking forward to the Alta S1 / Raven prototype which AP183's
Kasuf
(9 items)
Ryzen 3700X
MSI Tomahawk B450
ASUS Radeon RX 480 ROG Strix
Corsair Vengeance LPX 32GB 3000MHz
Samsung 850 EVO
Corsair HX750i
Noctua NH-D15
Silverstone FT05B-W
LG 34" Ultrawide (LG34UC98)
steelbom is offline
post #26 of 28 (permalink) Old 09-22-2019, 08:52 PM
Owterspace's Avatar
Rep: 4 (Unique: 3)
I Think I may have to fill my 140mm holes in my case with these fans, and retire some of my older ones.
post #27 of 28 (permalink) Old 09-23-2019, 01:42 AM
Elrick's Avatar
Ahem, these are 180mm fan holes you'll be requiring here. IN other words, they both require Gaping Holes bigger than what John Holmes could ever leave behind .
That is why in my RV03 case which was built to use these fans can only have these installed because using anything less, needs a complicated adapter to be installed down there. Which I have not got the time to build.
Elrick is offline
post #28 of 28 (permalink) Old 09-23-2019, 05:34 AM
Owterspace's Avatar
Rep: 4 (Unique: 3)
Ahh ok gotcha. Well I’m not hurting for airflow so I’ll be ok I guess.
