Silverstone AP183 is out (aka WHAT WAS THAT I CAN'T HEAR YOU) - Overclock.net - An Overclocking Community
post #1 of 28 (permalink) Old 03-24-2019, 11:02 AM - Thread Starter
Tetrapyloctomist
Aenra's Avatar
Rep: 21 (Unique: 20)
Might have been mentioned and if so my apologies, but as per title;
The AP183 is out!
For me and three more people the whole world over, the next version of this auditory beast is out apparently!
Reminisce that constant ring in your ears after a Motorhead concert!
Enjoy a worry-free life experience! You'll no longer be able to hear her speak! Or shout, come to that!
Show that pesky AMD CPU just who's the boss around here!
Now with full PWM support (yes sir, i kid you not), 1500RPM (up from 1200), a reduced operational amperage of 0.3A (down from 0.45A) and dual ball bearing on top! They won't specify startup voltage of course, but who cares anyway, it's only wires! It may not be Christmas, but it sure feels like it!
Crank that fiend all the way up and go deaf in style.
https://www.silverstonetek.com/produ...id=847&area=en
Pride, honour and purity.
Aenra is offline
post #2 of 28 (permalink) Old 03-24-2019, 11:16 AM
Rep: 4 (Unique: 4)
The AP183 is out!
Attachment 261260
Attachment 261262
Attachment 261264
Looks really cool.
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
post #3 of 28 (permalink) Old 03-24-2019, 11:46 AM
Never Finished
airisom2's Avatar
Rep: 268 (Unique: 206)
Not sure how I feel about this fan. The FM182 is the better radiator fan due to it not having the grill (grill offers directional airflow at the cost of airflow, static pressure, and noise. Radiators act as airflow straighteners, so it's redundant and hurts performance). The AP182 is the better airflow fan due to it's 2krpm rotational speed.
While PWM is nice, big fans like these are typically run at a fixed rpm and left alone (thinking MO-RA/Phobya extreme rads and the 180mm x1-3 rads as well as case fans on the applicable raven/fortress series). On the other hand, PWM is actually a nice addition because I remember reading about how these fans were a challenge to control by most motherboard/fan controllers, and only the included fan controller gave you the range. That might have been just the AP182, though. Hopefully, the PWM curve scales linearly on these fans.
Dual ball bearings, while durable and long-lasting, are loud compared to FDB-type bearings. Can't knock off power consumption, though. These big fans are power hogs and the lower the better.
But in the grand scheme of things, these are a successor to the dated AP181s. I'm just unimpressed at the revision. Lower power consumption is about all we get. The AP181s undervolt nicely, and anything over ~1krpm is pretty noisy on these fans. A quieter bearing and revised fan blade would have been welcome additions. These fans can vibrate a good bit, so some dampening on the corners would be nice as well.
The ideal 180mm fan would be for me:
500-2krpm range PWM
Improved blade design (basically, a shrunk down A20 fan)
Detachable grill
Integrated rubber dampening
Integrated fan controller to toggle between say 800, 1200, 2000rpm (think FHP141)
FDB bearings
"Universal" mounting holes. So, picture the Thermaltake 200mm fan. Now picture an extension adaptor that you screw into all 4 corners that is slotted to accomodate all large fan mounting locations.
1680 V2 4.5GHz 1.33v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Rosewill Rise | Thermalright LGM RT
Logitech G600 | G440 | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Passive Preamp | Emotiva BasX A-100
OCZ Vertex 4 256GB | 51TB DAS | SS Prime Ultra Titanium 1KW
airisom2 is online now
post #4 of 28 (permalink) Old 03-24-2019, 12:12 PM - Thread Starter
Tetrapyloctomist
Aenra's Avatar
I want to reply in caps and keep the deaf theme going, lol, but i'll refrain ^^
Now as to your remarks.. seriously?
Why would you buy the equivalent of a Fatboy and downclock it to a Piaggio? Why would you, today of all times, even consider a 180fan radiator? And why, assuming you did anyhow, would you even consider this kind of fan to run on a radiator?
You use this to complement an air cooler and/or increase intake airflow and/or ensure even less of a temp delta between ambient and case temps. That's it.
As you mentioned, that grill in the back, kinda says it all, uses-wise
None of this makes sense, you do grasp that.
As to noise, yeah, it's noisy. So's the fatboy. Which is why you bought it, isn't it; in part anyway.
On principle, i agree about the dampening, but it's so easy and cheap to implement it yourself that frankly? I'm not even sure i'd care for it, would only drive the cost up and for a solution that may or may not be superior to what you could accomplish on your own.
Also, you don't just get lower power; you get a significantly increased lifetime compared to the older models (still lower than other 180 fans, but then again, they spin at 800 at best) and most of all, higher CFM and pressure. Without that accursed potentiometer, which i do admittedly despise, lol.. just nice, plain ole PWM here.
Aenra is offline
post #5 of 28 (permalink) Old 03-24-2019, 12:31 PM
Never Finished
airisom2's Avatar
Hmmm. The first question, I'd say because it's loud? Certain circumstances could facilitate the need for a higher fan speed (benchmark runs, troubleshooting, etc.). Then again, I'm not too sure by what you mean by fatboy and piaggio. I'm thinking loud (harley), and quiet (moped). Maybe you mean big and small. Regardless, these large fans are awesome on 1080/1260mm radiators. You can run 4 of these instead of 9 120-140mm fans, so cable management, maintenance, noise, and deadzone is better, though I'm not too sure on the deadzone part. They also perform really well on these large radiators, especially when noise is the priority on something that large. You can get large fans like these, run them really low and still get excellent temperatures.
The 180mm fans can only be used in a select number of cases, all of which are silverstone cases, unless there are a couple that support them that I don't know about. Silverstone's 180mm fans on their fortress and raven cases perform just fine, and swapping in the AP183 won't change that. Phanteks and Thermaltake cases won't fit this fan because of the nearly proprietary mounting holes. Kinda like how the old NZXT phantom 200mm fan could only fit in NZXT cases because of the mounting holes.
A selling point of large fans is being able to have a lot of airflow while being able to spin them low. Spinning them up faster to interrupting noise levels contradicts that. But hey, that's just me. Still, the AP182 is a monster regardless of what I think. That's an awesome fan.
Well, there isn't much to some silicone stuck on some corners. Just slap it on there and charge an extra dollar. I'd be down with that. Large fans like to vibrate. Having some dampening will help with that a lot.
The higher cfm and pressure is due to the increased rotational speed. Increased lifetime can be attributed by the dbb. AP181s had sleeves. The AP181s didn't sound too bad, but with DBB, they're going to get the low frequency growl which I can't stand.
Can't lie on the fan controller, that thing is a PITA. That's why PWM sounds so good on these fans. We can use PWM controllers now haha. But like I said, hopefully the curve scales linearly without the use of some type of stepdown resistor.
post #6 of 28 (permalink) Old 03-24-2019, 01:05 PM
Abula's Avatar
Rep: 38 (Unique: 33)
The best thing is that its PWM, now you could power them via the sata power PWM splitters and not worry about the current draw.
Looking forward to the release, hope we see a FT06 with them.
GAME - Intel i9 9900K | AsRock Z390 Tachi | G.SKILL 32GB DDR4 3200Mhz | Asus RTX2080Ti Strix | Samsung 970Pro 1TB + Samsung 860Pro 4TB
SIM - Intel i7 8700K | AsRock Z370 ITX/AC | Corsair 16GB DDR3000 | MSI RTX2080ti Duke | AData XPG 8200 Pro 1TB
SB - Intel i9 7940X | AsRock X299 Fatal1ty | G.SKILL 32GB DDR4 3200Mhz | Asus GTX1660Ti
WS - AMD 1950X | AsRock X399 Taichi | G.Skill 32GB DDR4 3200Mhz | 9271-8i 22TB Raid6 | Intel 900p 480GB
Abula is offline
post #7 of 28 (permalink) Old 03-24-2019, 01:16 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
If only it could bring Lemmy back..... I'd like to say "too young", "such a shock", etc, but the guy seriously walked the walk. Actually, he ran the walk. At full speed. At all times. And was a genius while doing it, a great influencer and loved by other musicians.
The fan looks good, too, btw.
ciarlatano is offline
post #8 of 28 (permalink) Old 03-24-2019, 01:26 PM
Never Finished
airisom2's Avatar
Silverstone showcased a raven prototype case with the AP183s:
Pretty funky layout. Reminds me a lot of the RV03, but without the 5.25" bays. I should've gotten that case while it was still produced. That would have made for a great little fileserver. With 7 5.25" bays, you could fit 11x 3.5" hotswap backplanes
post #9 of 28 (permalink) Old 03-24-2019, 02:23 PM - Thread Starter
Tetrapyloctomist
Aenra's Avatar
Quote: Originally Posted by ciarlatano View Post
At full speed
Yeap.. took what's an inevitable trainwreck of a lifestyle and managed to stretch it for a full 70 year period; smiling the whole way through. Wish i could say likewise
As to the fan, yeah, me too! Was complaining about their sleeve bearing a few days ago and here we are now.
(big and loud, just something special with that combo, for me anyway)
Aenra is offline
post #10 of 28 (permalink) Old 03-24-2019, 05:26 PM
Smug, Jaded, Enervated.
GHADthc's Avatar
Rep: 101 (Unique: 66)
Hmm that's pretty interesting, also good to see Silverstone making new cases that aren't just generic clones of NZXT (like they had been doing recently)...I wonder if there is going to be a Fortress variation of that Raven case.
These fans would of been nice for my TJ-11 project, but I have like 12 AP181's (actually have about 14, as well as 3x Phobya 900rpm PWM 180's..have quite a collection of 180mm fans actually) that are still fine, so I can't justify replacing them...I have chopped off the fan control wires from them, actually chopped off all wiring atm, I am going to re-wire custom length wires to them, and run some sort of controller to control 12 of them in my project...and also have removed the air penatrator grills from the intake AP181's for my 540mm rads (just snapped them off with my finger, should probably clean up the little jagged bits of plastic sticking out from them, the fans are like FM181's and Cougar CF-V12H's had a love child atm).
GHADthc is offline
