Are there any high flow 20mm deep 140mm fans? - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 04-06-2019, 02:46 PM - Thread Starter
Null
geoxile's Avatar
Rep: 159 (Unique: 129)
It's for a Noctua NH-C14S, which doesn't have great RAM clearance in low profile mode. I'm currently using a Ultra slim vortex from Prolimatech, it does an adequate but not ideal job.
geoxile is online now
post #2 of 20 (permalink) Old 04-06-2019, 02:55 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 960 (Unique: 592)
You have this one? Prolimatech Ultra Vortex 14?
http://www.prolimatech.com/en/produc...d=1908#showtab
You already have about the highest airflow you're going to get out of a 15mm fan AFAIK.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 16GB
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 20 (permalink) Old 04-06-2019, 03:23 PM - Thread Starter
Null
geoxile's Avatar
Turns out that cfm rating is total nonsense and it's probably cubic meter per hour. Their pressure-flow chart shows 56~ cfm in a no-pressure environment. I looked up a review and at full speed, with a golden motor that hits over 1100RPM it has like 60-70cfm at the most, but mine only hits 1000-1040 RPM so probably around 56-60 cfm.
I can fit a 20mm deep fan too, I just went with the USV 14 because I fell for their rating.
post #4 of 20 (permalink) Old 04-06-2019, 04:04 PM
ltpdttcdft's Avatar
Rep: 35 (Unique: 30)
There are a few slightly faster fans but it's not going to make much of a difference.
1200RPM: Thermaltake Luna 14 Slim
1300RPM: Cryorig XT140
If you want more performance you're gonna need a thicker fan.
I have a Cryorig C1 and the performance of the stock XT140 fan was very disappointing. It's loud and doesn't move much air. I replaced it with a Silverstone FHP-141.
ltpdttcdft is offline
post #5 of 20 (permalink) Old 04-06-2019, 04:15 PM
Meep
Gilles3000's Avatar
Rep: 292 (Unique: 217)
Can't find anything else 140mm sized either.
If you can fit 120mm fans as well, there's the 20mm thick DeepCool GS120, it goes up to 1800 rpm, so it might move some more air. Not sure if that'll make up for the smaller size tho.
Just wondering, any reason you can't fit a full size (25mm) fan underneath the heatsink?
Gilles3000 is offline
post #6 of 20 (permalink) Old 04-06-2019, 07:49 PM - Thread Starter
Null
geoxile's Avatar
RAM. The C14S in low profile mode only support 40mm tall RAM with the stock 25mm wide 140mm fan. I have G.Skill Trident Z that's ~44mm tall. Guess there's not really any better options. The USV is already around 60cfm so it's about as good as it gets for now I guess
post #7 of 20 (permalink) Old 04-08-2019, 12:08 AM
ltpdttcdft's Avatar
Could you add another fan for push-pull? How much room do you have on the other side of the C14S?
post #8 of 20 (permalink) Old 04-08-2019, 08:50 PM - Thread Starter
Null
geoxile's Avatar
I can fit another slim fan but I'm starting to think it may not be worth the effort since I tried putting a spare Corsair ML120, just to try it out, and the cooling is still so so compared to the stock 140mm noctua fan. It needs a higher airflow. I think I might try moving to a Noctua U9s, maybe a L12s because I don't see this working out. Another problem I guess is that I just can't supply enough fresh air to the fans because the C14 heatsink is so large it blocks most of the top vent for any intake.
post #9 of 20 (permalink) Old 04-09-2019, 06:42 AM
Meep
Gilles3000's Avatar
honestly, in your case i think it might be worth it to try removing the heastsinks on your ram, its not easy on the Tridents, but its not terribly hard either.
post #10 of 20 (permalink) Old 04-09-2019, 07:42 AM - Thread Starter
Null
geoxile's Avatar
I certainly considered that. Buying new RAM is an option too since it's pretty cheap nowadays. But the USV slim fans still choked when the side panel was put on compared to open air, so I think the case isn't able to provide enough air anyway. I'm probably going to rule out top down coolers and either go with the u9s or wait for the thermalright silver arrow 130, since the Cerberus has a max cooler height of 148, like absolute max.
