Self adhesive thermal paste - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 04-13-2019, 08:46 AM - Thread Starter
Rep: 1 (Unique: 1)
The fan on my GPU broke. So I took the cover and fan off completely and just put a case fan undeneath it. It seems to cool ok, but it runs at 65 degrees C when gaming. It's a 750ti, are these temps ok? I can't remember what they were when the original fan was on...
I was also thinking of using thermal adhesive to attach another heatsink I have lying around onto it (see pics) do you think this would work? Can the adhesive stick something as heavey as that? What adhesive would you recommend?
The uATX byter
(12 items)
i7 2600k
Asus P8P67-M PRO
EVGA GTX 750ti 2GB
Asus Strix RX 570 4GB
Kingston HyperX 16GB
1TB Samsung Spinpoint
60GB Corsair Force series 3
Cooler Master 700w Silent Pro
Aerocool Qs-200 Lite
Operating System
10 Home x64
LG W2363D
AOC AGON AG251FZ
fenderjaguar is offline
post #2 of 6 (permalink) Old 04-13-2019, 11:24 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 444 (Unique: 296)
You should be able to rig a fan on there pretty easily, and will just need the connection adapter. Zip ties, rubber bands, etc should do it. Adding the second heatsink won't be nearly as effective.
Almost picked up a Johnny Marr Jaguar, btw. But, I just can't get comfortable with the 7.5" radius.
ciarlatano is offline
post #3 of 6 (permalink) Old 04-13-2019, 11:43 AM
Missing the Old days
Cerberus's Avatar
Rep: 258 (Unique: 218)
I would personally mount the fan at a 45° angle towards the back of the case, hitting the card, pulling more air easier, and having a better angle towards the back to exhaust the warmer air...
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is online now
post #4 of 6 (permalink) Old 04-13-2019, 08:10 PM
RX7-2nr's Avatar
Rep: 175 (Unique: 159)
Those fans are often pretty generic and can be easily replaced. Usually they have a square or triangular mounting pattern and as long as you get a fan that's roughly the same measurement across as your cards fan it will mount right up. Even if your fan has some obscure mounting pattern, zipties work wonders.
Easy Automatic Shutdown Script for Overheating CPU (water pump failure)
XSPC Photon 270 mounting plate for the Corsair 750D
AMD
(7 items)
Ryzen 1800x
ASUS ROG Crosshair 6 Hero
MSI Airboost Vega 64 8gb
G. Skill Trident Z 3200
Samsung 960 EVO 500 GB M.2
Samsung 860 EVO 1 TB
Raystorm CPU, Aquacomputer Vega GPU, XSPC EX-360 & EX-240
Intel Xeon X5650 @ 4.6
ASUS P6T
Powercolor PCS+ 290x
12gb Corsair Dominator
1tb WD Black
250gb Samsung 840 SSD
Cooler Master V850
XSPC Raystorm, EK 290X SE, EX240, EX360
XSPC Photon 270, Alphacool D5 Acetal HF Top
Corsair 750D
Operating System
8.1
Keyboard
Ducky Zero
Mouse
Mionix Naos 7000
RX7-2nr is offline
post #5 of 6 (permalink) Old 04-14-2019, 02:08 AM - Thread Starter
Rep: 1 (Unique: 1)
To be honest, I'm not really interested in replacing the original fan at all. It was noisy, even on idle and it wouldn't go below 40%. I've been looking at other peoples idle and load temps of 750ti, and I've come to the conclusion that the temps I have now are completely normal.
Thanks for the advice about putting the fan at an angle, that sounds like a good idea. If I ever get shut of the HDD on the bottom of the case (which is more likely now, as I see 1TB SSD are becoming available and cheaper now), I'll probably do that.
And yeah, I hear you about the old fender necks. Every time I play a compound radius, not to mention jumbo frets, it's sooo much easier to play
Thanks for the replies
The uATX byter
(12 items)
i7 2600k
Asus P8P67-M PRO
EVGA GTX 750ti 2GB
Operating System
10 Home x64
LG W2363D
AOC AGON AG251FZ
post #6 of 6 (permalink) Old 04-17-2019, 08:39 AM
Rep: 0
I agree that you can buy a better replacement for it for a cheap price, then you problem will be solved. Glad you did. Find the right adhesive that suit the material if your current adhesive won't work. Noisy and idle fans are not worth the value spent.
lerkinn is offline
