Tt Riing or Noctua NF-A14? - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 04-15-2019, 07:20 PM - Thread Starter
Programmer
BradleyW's Avatar
Rep: 1555 (Unique: 1017)
Which is better for static pressure and air flow? I own both fans.
Thank you.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
AMD ASUS STRIX OC VEGA 64
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO NVM.e 250GB
SeaSonic 1250W Gold
Corsair 900D + Custom Loop.
BradleyW is offline
post #2 of 12 (permalink) Old 04-15-2019, 09:04 PM
Melcar's Avatar
Rep: 636 (Unique: 438)
Try them out and see which one performs better for your use case. I have the NF-A15 from my Noctua cooler, which is basically a NF-A14. That fan outperforms my other top 140/150mm fans at the same speeds (PH-F140MP and TY-143). It is also the loudest by a bit.
Sent from my Redmi 4A using Tapatalk
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #3 of 12 (permalink) Old 04-17-2019, 05:51 AM
doyll's Avatar
Rep: 1664 (Unique: 926)
How does performance compare at same noise levels?
I prefer TY series and PH-F140MP performance to noise and sound profile. It's not just about DB sound pressure level, but also about the actual sound and how it sounds to our ears. Some sounds are more annoying than others.
doyll is offline
post #4 of 12 (permalink) Old 04-17-2019, 08:37 AM
Melcar's Avatar
The NF-A15 is louder than the TY-143 at the same rpm, but it does cool better. I see as much as a 3C difference between the two on my NH-D15. The NF-A15 does have a louder hum that I find annoying. The TY-143 has to run at about 1700 rpm to cool as well as the NF-A15 at 1500 rpm, but while both are a bit loud at those speeds the TY has a smoother sound profile.
I find the PH-F140MP to be just as loud as the NF-A15 at the same rpm, but pushes less air.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #5 of 12 (permalink) Old 04-17-2019, 09:05 AM
Senior OCN Member
shilka's Avatar
Rep: 2752 (Unique: 1632)
I had NF-A14 FLX fans in my old Luxe and the ticking sound the motor in the NF-A14 made at low and medium speeds drove me crazy
Bought the TG version of the Luxe and keept the stock fans and those dont make any annoying sounds at low and medium speeds
If you dont mind the noise i would try the NF-A14 fans first
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is online now
post #6 of 12 (permalink) Old 04-17-2019, 09:06 AM
doyll's Avatar
Interesting. When I tested both A15 and TY series I found similar dB and cooling to rpm, and yeah the TY sound slightly better too. I also did PH-F140HP II and found them to have good sound and performance as TY series at same speeds. But depending where one lives on our big blue marble Phanteks and Thermalright can be hard to find.
doyll is offline
post #7 of 12 (permalink) Old 04-17-2019, 09:18 AM
doyll's Avatar
Nice case!
Originally Phanteks cases came with PH-F140SP fans (variable voltage 1200rpm) but that changed several years ago to a no model number fan that uses PH-F140SP housng and motor with a PH-f140MP impeller. They work very well indeed. Honestly the only bad fan from Phanteks is their 200mm one .. and it's really bad!
doyll is offline
post #8 of 12 (permalink) Old 04-17-2019, 09:18 AM
Melcar's Avatar
The hardest to source here in Mexico is Thermalright. Only viable place to import is Nam's, and they don't always have good stock. Last I checked Amazon had several TY fans available (after a loooong time of not having them), but the TY-143s I got at that time ended up with a weird PWM curve.
Phanteks used to be relatively easy to get, especially after Phanteks Mexico got started. But that was then. These days for some reason there is a lack of local stock.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #9 of 12 (permalink) Old 04-17-2019, 09:27 AM
doyll's Avatar
Can you get be quiet! Silent Wings 3 at reasonable prices? I've only used a few of them but really like them.
Maybe try finding Cooljag Everflow fans. Same OEM as TY most of TY-xxx series fans.
http://www.cooljagusa.com/index.php?...assid=82&id=87
Most are variable voltage but one is PWM
http://www.cooljagusa.com/index.php?...ssid=82&id=108
Puget Systems in USA sells some of them too.
https://www.pugetsystems.com/store/i...=d41d8cd9&que=
doyll is offline
post #10 of 12 (permalink) Old 04-17-2019, 10:01 AM
Melcar's Avatar
Amazon Mexico has the 120mm SW3 for about $20-21USD before import fees and shipping. PerformancePCs has them for $23USD before shipping (no import fees if I buy from them). Will try looking for the Cooljag fans. Unfortunately most stuff that is easy to get here locally is Cooler Master and Corsair. I already spend most of my lunch money on the MLs, so I'm not looking to buy more fans anytime soon. The MLs ended up being useless for my purposes, so I may eventually look into the SW3.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
