Thermalright tfx. New top 1 paste? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 04-18-2019, 01:53 AM - Thread Starter
Rep: 1 (Unique: 1)
Looks like it..... it has higher stats than the kryonaut and seeing some flawed reviews, in all of them seems to be better than the kryo.
Srry if there's another thread open for it.
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
post #2 of 7 (permalink) Old 04-20-2019, 03:13 AM
doyll's Avatar
Rep: 1639 (Unique: 920)
I did a couple of tests and found Thermalright's new TIM to be very good. Applies and spreads easy, and gives great heat transfer.
doyll is offline
post #3 of 7 (permalink) Old 04-20-2019, 07:02 AM
Fix it till its broke
Owterspace's Avatar
Rep: 2 (Unique: 2)
Did you use TFX or TF8? Id like to try either of them. Leaning more towards TF8 as I'm on a bit of a budget with an upcoming move. But if its worth it to get he TFX well you know.. I would just quit listening to my sensible side as usual. I did notice the performance of my CF3 to be diminishing slightly. I read because they want you to replace it every 3-6 months or something like that. I'm at that point. I'm sure under normal circumstances it would be fine, but I've been hitting Linpack Extreme fairly hard lately.
3770K @ 4500 1.25v/True Spirit 140 Power/TY-143 Push/Pull|x5690 E.S. @ 4000 1.275/Le Grand Macho RT
Asus P8Z77-V/Crucial M4 256GB|Asus Rampage III Formula/Intel 520 120GB
12GB G.Skill TridentX+RipJawsX @ 900 9-9-9-24 1T 1.575v|6GB Super Talent Chrome @ 800 6-6-6-20 1T 1.66v
EVGA GTX 980 Classified 3988 @ 1500/2000|EVGA GTX 970 FTW ACX 2.0 @ 1404/1753
Fractal Design Meshify C TG/CM Silent Pro M2 850|Fractal Design Define R4/TT SPM850
Owterspace is offline
post #4 of 7 (permalink) Old 04-20-2019, 09:37 AM
doyll's Avatar
I did some quick testing of both and found them both to be very good. Actually I tried TF5, TF8 and TFX. I like TFX best, but all are quite good.
Where did you read that garbage about needing to replace every 3-6 months? I have 2 systems running CF3 that were mounted 3 and 5 years ago with no heat transfer problems yet.
doyll is offline
post #5 of 7 (permalink) Old 04-20-2019, 10:33 AM
AMD Overclocker
Alastair's Avatar
Rep: 256 (Unique: 159)
How does tfx spread? Currently using CM Mastergel Nano. But if i can get an extra degree or two Ill take it.
GHOST rev 3.5
(29 items)
Rura Penthe
(12 items)
AMD FX-8370 @ 4.95GHz 1.5V 2700MHz NB/3000MHz HTT
ASUS M5A99FX PRO R2.0
Sapphire R9-Fury 3840
Corsair Vengeance 2133 4x4GB @ 2000 9-9-10-27 1CR
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
Antec High Current Pro Platinum 1300W
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
2x EK-FC Fury X fullcovers
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
Laing D5 Vario
EK-FC Terminal Dual Parallel
2x EK-FC Fury X Backplates
EKWB Coolstream CE280
6 Corsair ML140's
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #6 of 7 (permalink) Old 04-20-2019, 11:22 AM
Owterspace's Avatar
Rep: 2 (Unique: 2)
I thought I saw it on the Thermalright.de site, but its down where I am. It must be a mistake, I am probably noticing ambient temps changing thanks to spring.. I notice they play with info from time to time, for instance in the past, I have seen them lower the tdp rating of LGMRT from 320 down to 300 and then back up again. Although at last glance Thermalright.de continued to list LGMRT as 300w, while .com is still listing at 320w..
Ok, well thanks for the tip, I think I will just go ahead and from the TF8, as with my coupon its about 10 bucks on Aliexpress.
I have the same paste on LGMRT same mount for over a year, and I gave it the beans a few times, and its still ok. Holding a 2-3c spread on my x5690. My 3770k just plain runs hot, with a 10c spread over the 4 cores, and a 3c spread between 3 cores.
post #7 of 7 (permalink) Old 04-20-2019, 01:07 PM
AMD Overclocker
Alastair's Avatar
I really want to buy some tfx from aliexpress. Had i have known tfx existed when i ordered my block i would of ordered some with the block. Now i need thermal compound. But it takes like 8 weeks for something from china to get to me. So now i need to find something worth my time on aliexpress to bring up with some tf8 or tfx.
GHOST rev 3.5
(29 items)
Rura Penthe
(12 items)
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
XSPC D5 Bay Res
Laing D5 Vario
6 Corsair ML140's
Operating System
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
Audio
AMD Athlon 860K
Asus A88X-Pro
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Operating System
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
