help with meshify s2 set up - Overclock.net - An Overclocking Community
post #1 of 26 (permalink) Old 04-18-2019, 03:43 AM - Thread Starter
Rep: 0
https://www.fractal-design.com/home/...fy-s2-black-tg
Hoping someone can help me with a good fan set up.
The case supports:
Front: 3x 120mm/140mm
Rear: 1x 120mm/140mm
top: 3x 120mm /140mm.
Bottom: 2x 120mm/140mm
Going to be using a noctua dh-15 and I already own 2 noctua NF-A14 flx
Was hoping to try out 2-3 ARBG fans just for a change, as I have used a plain set up for a long time.
Price isn't too much of an issue, and I'm fine with not using those 2 noctua fans at all.
Current thoughts was just doing
2x 140mm front
1x140mm back
1x120mm top
I'm not sure how the top fan would go with being above the dh-15 though.
heto is offline
post #2 of 26 (permalink) Old 04-18-2019, 10:14 AM
Melcar's Avatar
Rep: 636 (Unique: 438)
I would go with front and (if you can) bottom intakes. Forget exhaust fans. Those two NF-A14 FLX would make great intakes. Just add another bottom or front intake (could be another Noctua) and you are set.
Rear exhaust fans are generally the noisiest in a PC due to the stamped grills on most cases. With the two FLX and your NH-D15 blowing towards the back you should not need an active exhaust anyway. Just make sure everything in the rear is vented.
Top fans are also mostly useless and just add noise. Closing off the entire top panel is the best you could do really, since that will cut down on noise considerably. Or you can leave the top as is so it serves as a passive air exchange (just make sure you have filters up there).
Since you really want ARGB, and most ARGB fans are no good, just get something like Phanteks Halos for your FLX fans. Hook up the Halos to your motherboard or whatever controller you fancy. The Lux version of the Halos comes with an adapter so they can be connected to standard ARGB headers.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #3 of 26 (permalink) Old 04-19-2019, 06:36 AM
Fix it till its broke
Owterspace's Avatar
Rep: 2 (Unique: 2)
I used to use the top fans exclusively to pull air into the case, now I am using them to exhaust gpu heat. I use 120x38 fans, and a single wasn't enough to vent that heat. I am running a Meshify C, after coming from an R4. With the C, it doesn't take long to see the mobo temp climb when the gpu is running. I now have 3 in 3 out and mobo temp climbs about 2-3c vs about 7-9c running the tops as intakes. I initially set it up with 5 in 1 out, then 4 in 2 out, and for now I have settled on 3/3. I have a pic to show the fans I am using, though one of the tops is pointing down, I have changed it.. I run the big fans at 7v and when I want 110cfm I switch them to 12v otherwise they scream like a TY-143 at full tilt. The rear fan is at 12v, and is quieter then the others while moving a **** ton of air. Of course the true test will come with summer.. and if I have to start dropping clocks Also, not as dusty in this config. No filters or foam.. Also, TY-143 is running on the "standard" setting in bios, so it can work with TY-147A instead of just over powering it. It still reaches about 1800rpm, so its quietish.
3770K @ 4600 1.3v/True Spirit 140 Power/TY-143|Asus P8Z77-V|8GB G.Skill TridentX+PerfectStorm @ 1000 8-9-8-24 1T 1.65v|EVGA GTX 980 Classified 3988 @ 1497/2001|CM Silent Pro M2 850|Fractal Design Meshify C TG
X5690 @ Stock+Turbo/Le Grand Macho RT|Asus Rampage III Formula/8GB STT Chrome+OCZ Reaper @ 667 6-6-6-20 1T 1.6v|EVGA GTX 970 FTW ACX 2.0 Rev.1 @ 1404/1753 (Stock)|TT SPM850|Fractal Design Define R4
Owterspace is offline
post #4 of 26 (permalink) Old 04-19-2019, 08:12 AM
Overclocker
JackCY's Avatar
Rep: 301 (Unique: 220)
Fill in front and bottom as intake. Rear exhaust, closed top. Cut all grills out.
JackCY is offline
post #5 of 26 (permalink) Old 04-19-2019, 02:12 PM
Rep: 1 (Unique: 1)
Closed top, 3x140mm front intake and 1-2 bottom intakes, no exhaust. Remove the brackets bellow the GPU or at least some of them, and remove the front PSU shroud cover.
You don't need anything more.
I used to have in my Meshify C 2x140mm front intakes and one rear exhaust.
I moved the rear exhaust on the front tied with zip ties bellow the 2x140mm fans.
I got 4°C improvements on already low CPU temps (from 52 to 48), got 1-2°C lower temps and 150 lower RPM on the GPU fans, and also allowed me to drop the inferior 140mm front intake from 1600 RPM to 800.
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
post #6 of 26 (permalink) Old 04-20-2019, 03:04 AM
doyll's Avatar
Rep: 1639 (Unique: 920)
The case supports:
2x 140mm front
1x140mm back
1x120mm top
First thing I suggest is you read 'How Airflow Works' and 'Setting up a case for optimum cooling' in link below. They will give you a general idea of how to setup a case with good airflow.
https://www.overclock.net/forum/246-...l#post22319249
https://www.overclock.net/forum/22319249-post5.html
doyll is offline
post #7 of 26 (permalink) Old 04-20-2019, 03:31 PM
TeslaHUN's Avatar
Rep: 17 (Unique: 15)
Keep 2x A14 as front intake and just buy 2x 14cm Phanteks Halos rgb (normal or argb version )frame for them.
TeslaHUN is offline
post #8 of 26 (permalink) Old 04-20-2019, 03:52 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 960 (Unique: 592)
I run two front Noctua NF-A14 iPPC-3000s up front as intake and 4x cheap-o "Aigo" 140s on my Meshify S2 and it does great. The Aigo fans are run at ~30% (and even at 100% they're pretty crappy tbh) so it's still positive pressure.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 16GB
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #9 of 26 (permalink) Old 04-22-2019, 08:40 PM - Thread Starter
Rep: 0
Thanks for the advice guys. I will also for sure be getting the phanteks halos digital over regular argb fans.
heto is offline
post #10 of 26 (permalink) Old 04-23-2019, 07:31 AM
Melcar's Avatar
Make sure you get the Lux version for the adapter (or buy the adapter separately). Without the adapter the Halos will only work properly with Phanteks controllers.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
