Reducing My VEGA 64 Hot Spot Temperature? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 04-19-2019, 05:59 PM - Thread Starter
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
In my corsair 900D case, the air flow wasn't very good. Radiator fans set the exhaust and 2 TY 140's as intake.
My Vega 64 ASUS Strix undervolted reached 85c core, 107c hot spot, 115c VRM.
Since using better thermal pads on the VRM, and adding pads between the PCB and backplate, and replacing stock fans for a pair of Corsair SP120's, the core is now 57c. Hot spot 87c, 73c VRM.
Core and VRM has a massive improvement. Hot spot is still too warm for my liking. How can I reduce it more?
Here's my current setup in my new X71 Core with Noctua 140's as intake. I get the same temps with the X71 chassis by the way. See attachment. Thank you.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #2 of 11 (permalink) Old 04-19-2019, 06:22 PM
Have you seen my Baseball
Drake87's Avatar
Rep: 29 (Unique: 27)
Nice looking setup.
Drake87 is offline
post #3 of 11 (permalink) Old 04-20-2019, 09:09 AM - Thread Starter
Programmer
BradleyW's Avatar
Thank you.
Other than watercooling the GPU, how else could I reduce the hot spot temperatures more? 87c is still a little too warm for me. I'd be much happier with 80c.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #4 of 11 (permalink) Old 04-20-2019, 09:31 AM
Facepalm
Falkentyne's Avatar
Rep: 445 (Unique: 310)
You can't.
Because no one knows exactly what the 'hotspot' is to begin with.
Someone said it was the hottest temp the GPU registered. But that can't be true. Another person said it's some sensor around the die and interposer, possibly on the PCB backside.
Even W1zzard didn't know what the hotspot is.
Regardless, you can't do anything about it. The cooler the GPU and HBM and VRM's are, the cooler the hotspot will be. That's all you can do.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is online now
post #5 of 11 (permalink) Old 04-20-2019, 10:10 AM - Thread Starter
Programmer
BradleyW's Avatar
You can't.
So actually what you've just said is, I can lower the hot spot, by lowering the temperature of the other components. So I'll rephrase, how can I reduce the temperature of everything apart from the hot spot? (Which in turn will lower the hot spot).
Better fans on the heat sink? Install the rajintek cooler? Better fans on the case intake?
Cheers.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #6 of 11 (permalink) Old 04-20-2019, 10:43 AM
Maracus's Avatar
Rep: 1 (Unique: 1)
Did you replace the thermal paste? I re pasted my Strix 56 with Grizzly Kryonaut and changed the pads also and it lowered all my temps. Undervolting the is what helps the most, what are your P6/P7 settings?
Maracus is offline
post #7 of 11 (permalink) Old 04-20-2019, 10:54 AM
AMD Overclocker
Alastair's Avatar
Rep: 261 (Unique: 163)
We know what hot spot is thanks to RVII. It is the hottest temp in the center of the die. While GPU temp is the edge of the die temp.
GHOST rev 4
(26 items)
Rura Penthe
(12 items)
AMD Ryzen 7 3800X
Gigabyte Aorus X570 Pro Wifi
MSI VEGA 64 WAVE
Avexir Core 2 3600MHz 18-20-20-44
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
CoolerMaster V1300 Platinum
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
XSPC D5 Vario
EKWB Coolstream CE280
6 Corsair ML140's
Barrow Vega 64 full cover waterblock.
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #8 of 11 (permalink) Old 04-20-2019, 11:51 AM - Thread Starter
Programmer
BradleyW's Avatar
I certainly did. It didn't help much. The only thing that's made a real difference is ditching the stock fans for a pair of SP120's.
That's interesting. So this applies to Vega 56/64?
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #9 of 11 (permalink) Old 04-20-2019, 01:00 PM
AMD Overclocker
Alastair's Avatar
RVII is VEGA. Just shrunk from 14 to 7nm.
If You Can Cool It! You Can Clock It! (AMD's Vishera)
GHOST rev 4
(26 items)
Rura Penthe
(12 items)
AMD Ryzen 7 3800X
MSI VEGA 64 WAVE
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
XSPC D5 Bay Res
XSPC D5 Vario
6 Corsair ML140's
Operating System
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
Audio
AMD Athlon 860K
Asus A88X-Pro
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Operating System
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #10 of 11 (permalink) Old 04-20-2019, 02:09 PM - Thread Starter
Programmer
BradleyW's Avatar
I just wanted to double check. Thank you.
Would the Raijintek be a waste of money? I thought about switching the SP120's which are attached to the card for a pair of EK Vardars
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
