Don't knock the Hyper 212 EVO - Page 2 - Overclock.net - An Overclocking Community
post #11 of 106 (permalink) Old 04-20-2019, 04:03 PM
Fix it till its broke
Owterspace's Avatar
Rep: 6 (Unique: 4)
But they aren't under $30 any more, they are 35 now, looks like you can get a refurb for 22. It had a hard time with my x5690 at 4ghz. I still stick with it being marginally better than a 970-990 stock cooler
3770K @ 4700 1.375v|Le Grand Macho RT/TY-143|Asus P8Z77-V|8GB G.Skill Mix @ 1100 9-11-9-28 2T 1.665v|Intel 545S @ Raid 0|EVGA GTX 980 Classified @ 1500/1903|CM Silent Pro M2 850|FD Meshify C
X5690 E.S. @ 4293 1.375v|True Spirit 140 Power/TY147B|Asus Rampage III Formula|10GB G.Skill Mix @ 800 9-9-9-24 2T 1.55v|Intel 520|EVGA GTX 970 FTW ACX 2.0 @ 1475/1853|TT TP650|FD Define R4
Owterspace is offline
post #12 of 106 (permalink) Old 04-20-2019, 05:06 PM
Master of Black Snow
Ceadderman's Avatar
Rep: 700 (Unique: 519)
Either you didn't mention it or maybe I missed it, but did you try to clean and apply fresh TIM to the socket before changing out to the 212?
Don't get me wrong, I am on my 5th or 6th Hyper 212 EVO. In fact I recently purchased my latest one to go with my Streacom BC1 open bench table. As many sockets as the EVO covers it was a no brainer for a solid performance CPU cooler to box up and have on hand when I am doing any new build. Whether for client or for personal use. I use custom cooling loops, so knowing the state of my systems prior to blocking and tubing is very important. You simply don't just dive right in and start putting together your cooling setup without knowing whether or not you have an issue with any component. Doing so is living dangerously, because if you have an issue with a motherboard or CPU, you have to drain your loop and then dismantle it to be able to remove the offending component. It's bad enough when you have to do so with an Air cooler. Even worse when it's custom cooling.
I've only had one negative experience with the 212 EVO and that was when I had to remove it to block my CPU on my CIVFormula. The thumbscrews were so tight that I could not remove it as it was installed. I had to remove the MB from the case in order to access the backplate(this was back when CPU cutouts were not so large) and remove it by unscrewing the backplate. Not that big of a deal for me since I had to install an EK backplate anyway. But for someone who only needed to change out their CPU or TIM that could be a bit more of an irritant as it was for my experience. I've since learned not to overdo it on the tension. I simply screw each thumbscrew all the way down and back out about a quarter turn to make sure that I don't have to worry about this issue.
As far as performance? Well I simply have zero complaints about these CPU coolers. My first EVO was 2nd hand IVGC to replace my Corsair H50 when I decided to custom cool the previously mentioned system which was running a lapped 955BE at the time. I contacted CoolerMaster about the fan brackets for the 2nd fan setup and they sent me the fan brackets free of charge. Didn't even bother charging me for shipping. IIRC that cooler on my lapped CPU put sub 40 temps on my screen @ Idle and mid 40s under load. I currently have this one on my Black Snow build while I compile my setup and get it ready for a the new Case. Low 40*c's @ 3.6ghz.
I cannot speak to what anyone does and their results with their 212, but I don't use the stock paste and I spread my TIM over the entire surface of the IHS. This means there are no issues with coverage or with less TIM or bubbles in the paste when mounting the Cooler. It also means less time wasted on reseats or reapplications. I use G751 or Ectotherm and both are still relevant today with TIM like ThermoGrizzly available. I've tried that stuff, and while many many many more people have nothing but high praise for it, my experience with it was not a good one. I couldn't get more than 1 application out of it and that first one, wouldn't push out of the tube easily at all. While at least CM paste does what it's meant to do and for much cheaper. I did actually purchase a 3g tube of Ecto last February so I have more than enough for my needs and it should last me for the rest of the year due to my application process.
~Ceadder
I am really starting to feel my Oats as a long time member of OCN. Why did we go back to this system again?
https://valid.x86.fr/cache/banner/w8cbvb-6.png
Black snow
(17 items)
Ryzen 7 1800x
ASUS Crosshair VII Hero
XFX RX 480 Black Edition 8GB
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z370 Platform Desktop Memory Model F4-3200C14D-16GTZSK
Western Digital Black
Samsung 750 EVO
Samsung 850 EVO
Samsung 850 EVO
Adata m.2
EVGA Supernova
EKWB Crosshair VI Acetyl Monoblock
Lian Li O11 Dynamic
Operating System
Windows 10 Home 64bit USB
Samsung NU6900
Keyboard
Corsair K55
Mouse
Corsair M65
Other
Xbox Wireless Controller: Winter Forces Special Edition - Xbox One/Xbox One S/Windows 10
AMD Phenom II X6 1100T
Crosshair IV Formula
Corsair Dominator
x2 HITACHI 1TB Deskstars 1TB RAID0
Samsun 750 EVO
EVGA
EK D5 Vario
EK x3 250 RGB
Yate Loon 120x20 (D12SM-12C) Medium Speed Silent Fans
EK Supreme HF Classified
Monsoon 1/2"x5/8" PETG White Hardline tubing.
Monsoon Economy Hardline fittings
EK x3 CSQ Clean Acrylic
EK RX 480 Copper/Acetyl
HAF 932
Operating System
Win7 64 bit Ultimate OEM
Asus VH222H Black HDMI Widescreen
Keyboard
Logitech the OCZ went buhbye adios. Don't know what I'm going to replace it with.
Mouse
Logitech g9x
Mouse
COOLER MASTER Weapon of Choice: M4 Duramesh Pad
Audio
Logitech X-240 2.1 speakers
Other
Creative X-Fi
Other
Sunbeam Rheosmart 3
Ceadderman is offline
post #13 of 106 (permalink) Old 04-20-2019, 06:19 PM
Rep: 8 (Unique: 8)
Quote: Originally Posted by Gilles3000 View Post
I'm not sure why people keep hyping this cooler, sure its fine to keep around as a back-up, but its no longer relevant if you're buying new.
The only thing all these kinds of threads are doing is causing new builders to keep buying 212's, while there are much better coolers in the same price range nowadays.
What do you get to be much better at the price point of a 212? In a case well configured it can handle pretty much of a beating even mildly overclocking top consumer CPUs with normal temps.
If ryzen 3000 is what i expect it to be, coolers like 212 will regain a lot of relevance back again.
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
post #14 of 106 (permalink) Old 04-20-2019, 06:30 PM
white owl's Avatar
Rep: 136 (Unique: 103)
Quote: Originally Posted by MacLeod View Post
I think they're the best cooler on the market dollar for dollar. I had one for a couple years and ran it on a FX-8150 and it handled it up to 4.2 Ghz which was pretty impressive considering it was less than $30.
No they're not as good as higher end models but for unde $30, you can't beat em.
They aren't under $30.
I doubt many will rush to buy a 212 to replace the Wraith cooler...unless they don't have coolers this time?
Even if they don't I'm not sure why you'd want a 212 over a Cryorig H7 or True Spirit 140 Direct and the more expensive but D14 equivalent True Spirit 140 Power
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #15 of 106 (permalink) Old 04-20-2019, 06:32 PM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Anyone still buying CM Hyper EVO 212 for over $30-$35 when you can get the DEEPCOOL GAMMAXX 400 when on sale for $17 shipped (normally $22-$25) at times is not really keeping up with the times, lol
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #16 of 106 (permalink) Old 04-20-2019, 06:35 PM
Rep: 8 (Unique: 8)
Because those coolers are not always available or at the 30 bucks mark. Also the h7 is very, very slightly better, not much better and the true spirit 140 it's not in the same class, nor by price or performance. It's a much, much better cooler than more often than not, costs double.
Because you're wrong. The 212 it's still better than a 2700x cooler at less than half the RPM. And it's vertical, which means in airflow cases scales like crazy in performance (this is not theory, it's just current present situation in my home). Keeps my 2600 stock so low that barely reaches 50°C in gaming with 20°C room temp. Usually it goes around 46-47°C, and all my fans, cooler included run around 700rpm. It scales almost linearly with the RPM from the front intakes.
I had it on a 1800x at 3.95ghz with 1.38v+ in a define S+3nf A14 front intakes, running at 1200 rpm, and in prime95 small fft was getting 74-76°C. Room temperature 20°C~.
It's not gonna win any prize, but it's a damn good cooler at 30 bucks. The best.
Shenhua is offline
post #17 of 106 (permalink) Old 04-20-2019, 06:40 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1246 (Unique: 682)
Cryorig H7 was cheaper than the 212, so even if it only performed on par with the 212 it'd still be the better buy.
Unfortunately the H7 is EOL (AFAIK) and the only place in the US where it's still in stock is for >$100.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #18 of 106 (permalink) Old 04-20-2019, 06:59 PM
white owl's Avatar
It's a $6 difference between the 212 and the 140 direct on Newegg
The only reason I used those coolers as an example is becasue they're well known.
https://www.overclock.net/forum/246-...ernatives.html
Better is better, an H7 can cool as much a 5c better than a 212 on something as lite as a 4790k with only 1.3v, that gap would get much larger if you add more power. Plus the 212 feels like flimsy piece of crap, that was my first impression of it.
What sort of argument was that anyway? You're going to buy a lower quality cooler with worse performance to save $3-5? The gammaxx is equal quality for $20 and the PureRock is better in every way for the same money.
Ignoring the H7 entirely there are still a pile of coolers better than a 212 for about the same price or as good for less. If they sold the 212 for $20 again that would be different.
You can still buy the H7 direct from Cryorig on Newegg FYI...if you don't want to wait on that it's not like you're starved for choices.
Scales like crazy in performance? What does that even mean? More vertical = more TDP? I guess vertical works if you don't have a GPU...or don't care that the CPU or GPU are cuddling for warmth. The 212 can't compete with the stock wraith cooler for PPD, since the wraith is free it has infinite PPD. Also you can get a 212 equivalent for $20 so it's moot from every angle.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #19 of 106 (permalink) Old 04-20-2019, 07:56 PM
It Just Works
TFL Replica's Avatar
Got mine on sale in 2016. It does seem to be a bit overpriced right now (unless you go refurb or it goes on sale).
TFL Replica is offline
post #20 of 106 (permalink) Old 04-20-2019, 08:27 PM
Overclocker in training
ThrashZone's Avatar
Rep: 119 (Unique: 79)
Hi,
Still have an evo great cooler for it's size
Not sure if a D14 was much better.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
