140mm 10mm thick usb fan? - Overclock.net - An Overclocking Community
post #1 of 38 (permalink) Old 04-27-2019, 06:39 PM - Thread Starter
To The Game
Chargeit's Avatar
Rep: 289 (Unique: 197)
Hello,
I'm getting a laptop in in a few days. I want to make a laptop cooler for it out of some 3/4" oak plywood I have on hand. I want to add in a fan for cooling. I'd like a 140mmx10mm usb fan if possible. Is anyone aware of such a fan? I'm having trouble finding one.
Thanks,
Chargeit
Chargeit is offline
post #2 of 38 (permalink) Old 04-27-2019, 06:42 PM
Shadowarez's Avatar
Rep: 24 (Unique: 21)
Closest to that would be the
AC Infinity MULTIFAN S4, Quiet 140mm USB Fan for Receiver DVR Playstation Xbox Computer Cabinet Cooling https://www.amazon.ca/dp/B00MWH4FL4/..._BtqXCbYS55V2J
Sent from my SM-G965W using Tapatalk
Shadowarez is offline
post #3 of 38 (permalink) Old 04-27-2019, 06:47 PM - Thread Starter
To The Game
Chargeit's Avatar
I own a few of their other sizes. They're good fans but kind of thick.
Looks like I might have to go with an 80mm fan. Seems to be the largest size I can find at 10mm thick. Was hoping I missed something.
Thanks!
Chargeit is offline
post #4 of 38 (permalink) Old 04-27-2019, 06:51 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 960 (Unique: 592)
Wouldn't it be easier to just grab a standard 140mm fan and wire it yourself for USB? Get a high RPM one you know that can run on 5v and ezpz.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 16GB
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #5 of 38 (permalink) Old 04-27-2019, 06:52 PM
Shadowarez's Avatar
Np got a few 120s in my AV cabinet very nice was thinking same thing for labtop cooler lol just not the wood I'd get off shelf replace with these lol.
post #6 of 38 (permalink) Old 04-27-2019, 07:11 PM - Thread Starter
To The Game
Chargeit's Avatar
Yeah might have more luck finding a normal low profile 140mm fan. I'll dig around for one. See what I can come up with.
Chargeit is offline
post #7 of 38 (permalink) Old 04-27-2019, 07:19 PM - Thread Starter
To The Game
Chargeit's Avatar
Yeah I have a 120 and 80mm. One of them is in my AV cabinet and the other one is around here somewhere. Very nice build quality.
Chargeit is offline
post #8 of 38 (permalink) Old 04-27-2019, 09:15 PM
Overclocker
JackCY's Avatar
Rep: 300 (Unique: 219)
Never seen a 140mm even 120mm 10mm height fan. All the laptop pads/coolers use 2x80mm low profile 5V fans. Or something close to it. These low profile fans are often pretty crappy. If you can fit 25-30mm height then get a standard high speed 1350-1700rpm 140mm fan and run it at 5V, many will start around 4V I think, gotta check the specific fan though when it starts up.
JackCY is offline
post #9 of 38 (permalink) Old 04-28-2019, 07:06 AM - Thread Starter
To The Game
Chargeit's Avatar
The standard fan thickness is much thicker then 3/4" plywood.
I plan on routing out a spot to mount the fan. I could have the fan a little proud on the bottom though I'd like to keep it flush if possible.
For the task I don't think it needs to move a ton of air. Main reason for wanting a 140mm fan was just to have a large fan running at low rpm.
Once I get the laptop in I can better plan the laptop cooler. I'll be able to see what height makes sense for any risers on the bottom and see what kind of fan thickness I can fit in. There are 15mm 120mm fans I'm seeing which might have to do.
Here are two 120mm 15mm fans I'm looking at,
Noctua (1850 rpm)
https://www.amazon.com/Noctua-NF-A12.../dp/B071W6HJP6
Or,
SilverStone (1500 rpm)
https://www.amazon.com/SilverStone-T...dp_ob_title_ce
15mm is a little thicker then I'd like but it should work. I'll leave them a little proud on the bottom to give myself more meat to mount them to but they should work.
I found this to converter 5v power to a 12v fan,
Step up converter,
https://www.amazon.com/gp/product/B0...H0AUR22S&psc=1
Plug,
https://www.amazon.com/gp/product/B0...EH2276JE&psc=1
Looks about right?
Chargeit is offline
post #10 of 38 (permalink) Old 04-28-2019, 07:19 AM
Overclocking Enthusiast
ozlay's Avatar
Rep: 268 (Unique: 215)
Scythe Slip Stream 120mm x 12mm
800rpm SY1212SL12SL
1,200rpm SY1212SL12L
1,600rpm SY1212SL12M
2,000rpm SY1212SL12H
Prolimatech Ultra Sleek Vortex 140mm x 15mm
In Loving Memory Of Kassandra
Kaby
Rikka
(11 items)
Intel I5-7600k
Asrock Z270M Extreme 4
Titan X
Titan X
Galax HOF
850 pro
960 Pro
970 Evo
Seasonic Prime Snow
enthoo evolv matx tempered glass
Operating System
windows 10 pro
ozlay is offline
