Recommend me Radiator fans - Page 2 - Overclock.net - An Overclocking Community
post #11 of 32 (permalink) Old 05-10-2019, 04:27 AM
Rep: 3 (Unique: 3)
Quote: Originally Posted by ciarlatano View Post
Well.....it's not really according to me as much as it is according to actual results. First, we are talking about 120mm fans here, not 140mm fans. I'm guessing that @Shawnb99 has no interest in replacing all of his rads for the pleasure of using average 140mm fans. Second, it isn't about "under 1500 rpm" nearly as much as it is about "at like noise levels", or conversely which fan is quieter at the same performance level, and which has the nicer sound signature. Given that, the NF-A12X25 far outperforms the NF-F12 iPPC in every respect, and it doesn't have the iPPC's bearing noise that those with sensitive hearing find so irritating. The OP is using 24 fans....24 iPPC would be like nails on a chalkboard at any speed due to that bearing noise. Take a look at actual measured performance through a rad below 1500 rpm - https://www.techpowerup.com/reviews/...x25_PWM/5.html - the iPPC stacks up very poorly next to the NF-A12X25, SW3, ML120, GT, and even the $15 Phanteks F120ML.
Man, i never said anything about replacing radiators, so stop guessing what i haven't even said. Buying 24fans is still expensive. In my country its cheaper to invest in another 360mm external rad setup, temps will be much cooler and push-pull won't be needed unless rads are too thick. Thats my point of view and it works. Even if 24x fans are running at 700rpm, motor hum will be still audible, due to high amount of fans.
TopM5 is offline
post #12 of 32 (permalink) Old 05-10-2019, 07:45 AM
doyll's Avatar
Rep: 1683 (Unique: 934)
Quote: Originally Posted by Shawnb99 View Post
I think one of my Vadars died on me. After reading it causes issues with the AQ, I’m looking to replace all the fans on my rads. So I’m looking for suggestions for the best fans for the rads in my sig.
Not trying to confuse the issue, but is it fans or is it airflow temp going into radiators? While radiators react much less to changes in air temp, it does make a significant differnce if the room temp is 22c and the air into radiators is 25c, 28c, or higher. Ideally we want all radiators to be receiving air at or near room temp.
Pay attention to ciarlatano, he knows his stuff.
doyll is offline
post #13 of 32 (permalink) Old 05-10-2019, 07:51 AM - Thread Starter
Shawnb99's Avatar
Rep: 50 (Unique: 32)
All of my rads are in push/pull and as intakes.
I’m looking for quieter fans and really just looking for some other option than Noctua’s as they are expensive.
Since only 1 fan has died atm I’ll likely just get another Vadar to replace it but am considering my options on replacing all of them at some point.
NF-A12x25 PWM goes for $39 CDN, replacing all 24 of my Vadars for the Noctua’s would only run me $910 before taxes.
We really need a cheaper option to Noctua’s.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #14 of 32 (permalink) Old 05-10-2019, 08:07 AM
doyll's Avatar
Okay, so you have all radiators as intakes. Does your case have as much exhaust vent area as you have radiator intake area?
Sorry for all the basic questions, but with as much radiator area as you have I am wondering why cooling is a problem .. and wondering if it's an airflow problem rather than a fan problem .. or maybe coolant flow problem. Do you maybe know what coolant temp in and out of block is?
Airflow is like anything else in physics .. equal and opposite action. For 2 cubic inches of air to flow into a case we have to have the same 2 cubic inches of air flowing out of case.
doyll is offline
post #15 of 32 (permalink) Old 05-10-2019, 08:20 AM
Melcar's Avatar
Rep: 637 (Unique: 439)
For 120mm fans at or below the 1500rpm mark I would go with PH-120MPs instead. If you are aiming for 2000rpm or so, ML120s or SW3 High Speed. I wouldn't bother with the NF-A12x25 to be honest, unless price was not a concern.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #16 of 32 (permalink) Old 05-10-2019, 08:49 AM - Thread Starter
Shawnb99's Avatar
Cooling isn’t a problem at all. After seeing a thread on issues with the Vadars and the AQ6 on start up I wanted to see what other options there was.
I’ll likely have to upgrade them at some point since I have the older F4 models that are discontinued now I think so only the “bulk” models left. Since it’s just one fan causing trouble for now I’ll replace it while I can and if any more start dying will be the time to redo them all.
I know I can go wrong with the Noctua’s, I just can’t stand the brown.
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #17 of 32 (permalink) Old 05-10-2019, 09:20 AM
doyll's Avatar
Now it makes sense.
doyll is offline
post #18 of 32 (permalink) Old 05-10-2019, 10:52 AM
Rep: 9 (Unique: 9)
Whatever Melcar said in his comments.
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
post #19 of 32 (permalink) Old 05-11-2019, 02:56 PM
NewType88's Avatar
Rep: 2 (Unique: 1)
If you can wait and just replace the broken fan with a Cheapo fan, noctua should be releasing black nfa12 at the end of the year.
NewType88 is offline
post #20 of 32 (permalink) Old 05-11-2019, 03:45 PM - Thread Starter
Shawnb99's Avatar
Nice . Yeah I can still order some from EK so since a 2nd one went down now I’ll just order 2 from them and hold off till the end of the year if I can. By that stage I’ll be able to afford to replace all 24.
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
