Recommend me Radiator fans - Page 3 - Overclock.net - An Overclocking Community
post #21 of 32 (permalink) Old 05-11-2019, 04:47 PM
Retired Staff
animal0307's Avatar
Rep: 116 (Unique: 103)
In my experience, Nocutas may not always be the quietest fan for a given rpm range, but they are usually the most pleasant fans to listen to if you have to hear them. Plus that 6 year warranty man, you can't beat it.
Aesthetically: Do you care about the color if you can't see them? I'm not sure how much of the fans you can see through the grills on a Caseab case but if they aren't RGB or light by some other means can you really see them?
I totally side with you on the Price thing, around $30 USD per fan is nuts but the quality is worth it in my opinion. "Buy once, cry once" as the saying goes.
I'm biased as I have been using Noctuas for over 5 years now and I don't plan to stop so you may want to take my input with a grain of salt.
animal0307 is offline
post #22 of 32 (permalink) Old 05-11-2019, 05:04 PM - Thread Starter
Shawnb99's Avatar
Rep: 24 (Unique: 16)
The colour isn’t that much of an issue, I’d grab them either way. The cost is going to make me wait considering I’ll likely upgrade all 24 at once. It would nice if they were a different colour that brown clashes with everything, but then again it’s distinct and you know it’s a Noctua when you see it.
I went from upgrading my GPU at the start of the year to now only having the fans and a pair of pumps left over. I’ll need a bit of tome to recover and upgrade the fans.
All 24 with taxes I’m look at over 1k.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #23 of 32 (permalink) Old 05-12-2019, 05:08 AM
doyll's Avatar
Rep: 1661 (Unique: 924)
I've used and tested lots of fans and Phanteks PH-F120MP and PH-F140MP are probably my favorites. Low noise .. and pleasant sound when they are running fast enough to hear combined with resonable price, even lower priced on special in 2-packs and 3-packs. I'm in Europe so prices may be different where you are, but they might be worth a look.
doyll is offline
post #24 of 32 (permalink) Old 05-12-2019, 05:50 AM
Overclocker
JackCY's Avatar
Rep: 339 (Unique: 240)
Quote: Originally Posted by thagabe View Post
Noctual A25x12. Nothing comes close.... my system has 6xsilent wings 3 (1 is the high-rpm 2200) when this one is past 1500 rpm it sounds like a jet engine. Same performance @2000 the noctuas sound like the wind breeze from a mild day. 100% recommend the noctuas
NOT 100% sure on this one but it is highly rated: Silent typhoons, tho they may be hard to find as they are no longer being produced.
The Nidecs are still made, since when did Nidec stop making fans? You only can't buy them easily which was always an issue with any industrial product. If you want to buy 1000 or 10k of them I'm sure they will sell them.
I would not even consider Noctua and the like due to their insane price. They offer same quality, same warranty with sometimes slightly better performance/noise but for 5x price with a puke color scheme.
JackCY is offline
post #25 of 32 (permalink) Old 05-13-2019, 09:22 AM
doyll's Avatar
Amazon.com has
Nidec Servo Gentle Typhoon D1225C12B5AP 120mm 1850rpm model available new for $17.91 to $22.90
https://www.amazon.com/gp/offer-list...&condition=all
Coolerguys also have other GTs
https://www.coolerguys.com/collectio...0-and-4250-rpm
doyll is offline
post #26 of 32 (permalink) Old 05-13-2019, 09:43 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
Quote: Originally Posted by doyll View Post
Amazon.com has
Don't forget Darkside - http://www.performance-pcs.com/darks...k-edition.html - also available from NewEgg and Amazon.
ciarlatano is offline
post #27 of 32 (permalink) Old 05-13-2019, 06:59 PM
jura11's Avatar
Rep: 100 (Unique: 64)
Hi there
Personally running 9*Phanteks PH-F120MP, 3*Noiseblocker eLoop 120mm, 6*Corsair ML120 and 18*Noiseblocker BlackSilent Pro PL2
But have tried like Noctua A12x25, NF-F12 ,BeQuiet Silent Wings 3 or Pure Wings and Vardar F3 1850RPM
Noctua are my favourites,but they're expensive, Phanteks PH-F120MP are my another fans which are my another favourites, great fans for money and if you are running fans at 1000-1200RPM then they're great sounding fans, noisier than Noctua, Noiseblocker BlackSilent Pro PL2 are too nice sounding fans, just have bad luck with them,two of them started make unusual noise and RMA have been only option, Corsair ML120 hard to say if I would recommend them,3 of 6 fans Corsair replaced have been replaced under warranty,BeQuiet Silent Wings 3 nice sounding fans but expensive and beyond 1300-1500RPM they can be noisy
EK Vardar F3 1850RPM these fans I just can't or wouldn't touch or recommend, bearing noise or noise around 800-950RPM have been awful and hated these fans plus high starting draw can be issue for Aquaero
Nidec Servo Gentle Typhoon not sure, but these fans have high starting draw up to 0.53A and not sure if I would run more than 6 on one header/output on Aquaero, if you are running Aquaero 5 series then you are too limited by max draw at 1.5-1.65A,I know its start up draw but at this start up yours fans would be running at max speed and can trip protection on Aquaero
Hope this helps
Thanks, Jura
jura11 is offline
post #28 of 32 (permalink) Old 05-14-2019, 03:31 PM
cerealkeller's Avatar
Rep: 3 (Unique: 3)
Corsair ML Fans (Magnetic Levitation). They’re awesome, but, expensive.
cerealkeller is offline
post #29 of 32 (permalink) Old 05-14-2019, 08:22 PM
munternet's Avatar
Rep: 7 (Unique: 4)
I had some noctuas but returned them. They were ok when idling but too loud when working hard. Ended up with ek furious varders both 120's and 140's. I run them from 45% and up.
I would have bought the gentle typhoons if they were available.
Maybe I have been given the wrong Noctua fans from the shop (twice) but they said they were good and quiet and I found different at my heat levels so I won't be trying them again.
Battle PC
(15 items)
8700k @ 5.2ghZ
Maximus X Hero
EVGA 1080 Ti Superclock 2 Black
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Sansung M.2 1TB 970 EVO
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 2x 360mm Radiators and Vardar Fans
ThermalTake V51
Operating System
Windows 10 Lite
Dell Computer DELL U3415W 34.1 inches 3440 x 1440 pixels @ 48-85 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000mm x 500mm
Audio
Steelseries Siberia800 wireless Headset
munternet is offline
post #30 of 32 (permalink) Old 05-14-2019, 09:47 PM
Retired Staff
JedixJarf's Avatar
Rep: 305 (Unique: 244)
Here's another vote for silent wings 3. Just make sure you create a gasket of sorts around the fans to seal the airflow in.
JedixJarf is offline
