Thermalright True Spirit 140 Direct AM4 issue - Overclock.net - An Overclocking Community
post #1 of 30 (permalink) Old 06-08-2019, 11:07 PM - Thread Starter
waitandhope123's Avatar
Rep: 0
Tried using this on an ASRock Tai Chi x470 and it didn't work. The mounting system is fine but the actual cooler sits off the CPU to far to make contact. I've no idea what the deal is since it supposedly supports AM4 but in my case I guess it doesn't. Just bizarre as I thought all AM4 sizing was standard, appears not to be the case. Any insights let me know but the spacers it comes with don't allow for height change of any sort. If they had shorter spacers it should work but I don't and the box says AM4 is supported and the backplate has holes for it. I find this just really confusing. Also it's not a little off the CPU, you could slide a quarter under there I think that's the kinda distance we're talking about here
https://www.newegg.com/p/22B-002R-00001
http://www.thermalright.de/en/cooler...rit-140-direct
waitandhope123 is offline
post #2 of 30 (permalink) Old 06-08-2019, 11:24 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
The washers compress , use the thumbscrew
Did you forget washers on the back ? The ones on the front of the board are attached to the thumbscrews
http://www.thermalright.de/media/pdf/manual_am4_en.pdf
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #3 of 30 (permalink) Old 06-09-2019, 10:09 AM
doyll's Avatar
Rep: 1702 (Unique: 941)
What AlphaC said.
If that doesn't resolve the probem, could you post some pic so we can see the problem?
doyll is offline
post #4 of 30 (permalink) Old 06-09-2019, 12:08 PM - Thread Starter
Rep: 0
The way it works is the 4 long screws go through that backplate with the mylar sheet, then you put the backplate cap on and the washers for the backplate, but those are hard plastic and are only meant to keep the screws from hitting the motherboard when they're pushed through. They are flush on the other side with the motherboard. The primary issue is the 4 screw pillars, they are to long and prevent the heatsink from making contact with the CPU. They have silicone washers on them, which I hand tightened. It doesn't seem that's wrong as the images I see don't show them overtightened and I think even removing their washers wouldn't lower the heatsink enough to hit the CPU, idk I'd have to try again.
post #5 of 30 (permalink) Old 06-09-2019, 12:40 PM
⤷ αC
AlphaC's Avatar
Make sure you are using the M3L6 on the top of the thumbscrew and M3L10 on backside
AlphaC is offline
post #6 of 30 (permalink) Old 06-09-2019, 05:01 PM - Thread Starter
Rep: 0
It won't matter what screws I use because they go directly into the 4 metal screw pillars, there is no change is in distance depending on the screws used. Then the metal bracket lay over the pillars and you screw it in place. But then it's to high to touch the CPU, I put more than a pea size dot and it didn't even spread and barely touched the cooler. I'll try once more next weekend but it's just weird, it should all be the same distance on AM4 and other sockets. I can't change the pillars either because they accept screws they aren't screws, so where am I going to find ones that are smaller and fit properly?
post #7 of 30 (permalink) Old 06-09-2019, 05:13 PM
⤷ αC
AlphaC's Avatar
I don't understand the problem though, the heatsink is supposed to be higher than the square frame since you screw the two flanges coming off the heatsink into the frame you put around the socket.
The installation is similar to on Intel , just the holes used are different:
https://www.tweaktown.com/reviews/80...ew/index5.html
https://www.techpowerup.com/reviews/..._Direct/4.html
https://www.legitreviews.com/thermal...eview_191871/3
"Here is a picture of the AMD washer, which is slightly larger than the Intel one. You just need to make sure you have the skinny part up so it can seat itself into the screw cutout on the motherboard."
https://www.hardocp.com/article/2017...u_air_cooler/2
AlphaC is offline
post #8 of 30 (permalink) Old 06-09-2019, 05:22 PM - Thread Starter
Rep: 0
The heatsink is higher than the frame, but it doesn't contact the CPU at all. It sits on the metal frame off the CPU. The pillars are screwed on just like the images show.
post #9 of 30 (permalink) Old 06-09-2019, 06:46 PM
AMD OC'ing Enthusiast
mattliston's Avatar
Rep: 108 (Unique: 86)
You must be "bottoming out" in the threaded mounts.
Put the back spacer on
AM4 is shorter than AM3 package, so you may be using the AM3 stuff accidentally
mattliston is offline
post #10 of 30 (permalink) Old 06-09-2019, 08:40 PM
OG AMD
Redwoodz's Avatar
Rep: 600 (Unique: 465)
Usually washers go on top of mobo- not between backplate and back of mobo. Mylar sheet goes in between mobo and backplate on back side.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
