Does a cpu cooler with heatpipes degradate over the time? [Noctua NH-U12P v1] - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 06-12-2019, 03:10 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
Hello!
I have a Noctua NH-U12P bought about 8 years ago, it's been a lot of cpu's throught it, e8400, q6600, 2500k, 4790k and recently a Ryzen 2600X. Of couse Noctua has sent me two free socket adapters for it, 1st for 1155 socket, and recently for am4 socket, so very very happy with them, if you're reading me, gj on service guys
The problem is that with my 2600X on stock settings, I'm reaching 80º on OCCT, with a good airflow on my case, a Phanteks Enthoo Pro M SE with 4 14cm fans.
At first I was thinking it was problem of my cpu/bios config but yesterday I could test a Cooler Master 212 EVO and with it and the same test, it was on 73º, all same config.
I was thinking about maybe it wansn't well mounted, so I mounted again the noctua cleaning everything, and with the same thermal as CM 212, and thing went a little better, 77º, but still worse than the CM, and it shouldn't.
So, I'm not blaming about the Noctua, I think that 8 years of excellent service are enought but I was thinking about if this is a normal behaviour on heatpipes, to lose it's performance over the year, or maybe just my unit it's having some kind of problem.
So guys, what do you think, heatsinks with heatpipes degrade/lose performance over the years?
UPDATE: Answer from Noctua
Greetings from Noctua!
Thank you very much for contacting us.
In theory it could happen that a heatpipe becomes leaky, thus losing the vacuum inside and its function gone. However, either this happens very early in the beginning already, in case of a production error, or after mechanical damage to the heatpipe, but not suddenly by itself.
As far as I can tell you have recently switched to a newer platform (AM4).
From tests with AM4 CPUs in our lab we know that the heatspreader of the CPU has an elevated outer edge, similar to a ring. A cooler with a flat base, like the NH-U12, will thus sit on this outer "ring" but won't have good mounting pressure in the middle, resulting in worse temperatures. This is one of the reasons why all current models from us, and most current heatsinks from other brands as well, come with a slightly convex base to make sure the mounting pressure is best where the chip underneath the heatspeader sits.
We can't guarantee that this is the reason for the temperature difference but it seems very likely, based on our internal tests and information we have about this matter.
Kind regards,
Your Noctua Support-Team
MainEnthoo
(16 items)
Ryzen R5 2600X
MSI x470 Gaming Pro Carbon
RTX 2070 Windforce OC
KFA2 HOF Extreme DDR4 [email protected]
Samsung 970EvoPlus 500GB NVMe
Samsung 850Pro 512GB
Western Digital Black 2TB
Seasonic Focus+ 650W Platinium
Noctua NH-U12
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Razer Goliathus Cosmic Speed
Audio
Asus Xonar STX
rul3s is offline
post #2 of 19 (permalink) Old 06-12-2019, 04:05 AM
Manual breath enabled
Streetdragon's Avatar
Rep: 24 (Unique: 20)
Normaly not. Heatpipes are out of copper, and that wont go "bad"
Vaporchambers are normaly good to. because the drop of liquid in it is sealed up well.
How was the spreading on the block of the cooler?
maybe there was only good contact in the center or worse only on the edges?
Gameingcube
(18 items)
Intel I7 5930K
Asus Rampage V Extreme
1080 TI Founders Edition
F4-3600C16Q-32GTZR
2000GB Seagate Barracuda Compute ST2000DM008 256MB
samsung m2 970 evo
Leadex 80 Plus Platinum Netzteil, schwarz - 1200 Watt
heatkiller IV pro
EK-FC1080 GTX Ti - Nickel
Alphacool Eisbecher D5 250mm Plexi
Alphacool NexXxoS XT45 Full Copper 480mm
XSPC Multiport Radiator EX240
Scythe Grand Flex 4Pin PWM
thermaltake core x9
Operating System
Windows 10
Streetdragon is offline
post #3 of 19 (permalink) Old 06-12-2019, 04:29 AM
ErrantPigeon's Avatar
Rep: 1 (Unique: 1)
Vapor chambers can go bad: https://semiaccurate.com/2016/05/04/...chambers-fail/
In theory, this is possible with heat pipes, too.
However, this usually results in physically visible bending, cracking, warping etc. and not "silently" going bad.
ErrantPigeon is offline
post #4 of 19 (permalink) Old 06-12-2019, 04:42 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
The spreading was good, covering all the IHS, and with artic silver 5.
Tonight I'm going to check it again, but, I'm sure that if something was bended or similar I'd seen it yesterday when I dissasemble it.
MainEnthoo
(16 items)
Ryzen R5 2600X
Noctua NH-U12
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Audio
Asus Xonar STX
rul3s is offline
post #5 of 19 (permalink) Old 06-12-2019, 05:21 AM
white owl's Avatar
Rep: 136 (Unique: 103)
Short answer:
CPU air coolers should never degrade.
Longer answer:
The performance should stay the same as long as it's functionally the same. If a heatpipe leaked or if there were an issue with the base, I'm sure you'd see much worse performance.
While the seal on the tip of a heatpipe is quite good, I'm sure it's possible for one to have a very slight leak.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #6 of 19 (permalink) Old 06-12-2019, 05:45 AM
doyll's Avatar
Rep: 1641 (Unique: 920)
As others have said, yes, heatpipes do degrade over time, but in our coolers I have never known of any that degraded. I'm running a Thermalright Ultima 90 I got in 2007 with no degradation in cooling ability.
doyll is offline
post #7 of 19 (permalink) Old 06-12-2019, 07:28 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
Well, I've just send an email to Noctua Support explaining my problem, let's see what they say to me!
MainEnthoo
(16 items)
Ryzen R5 2600X
Noctua NH-U12
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Audio
Asus Xonar STX
rul3s is offline
post #8 of 19 (permalink) Old 06-12-2019, 07:37 AM
deepor's Avatar
Rep: 467 (Unique: 314)
Maybe the room temperature was different when you tested the two coolers?
deepor is offline
post #9 of 19 (permalink) Old 06-12-2019, 08:07 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
Is fas about 30 minutes from all tests, and it was at night, maybe 1º of diference... anyway, noctua should perform much bettern than CM 212, and this was not hapenning.
MainEnthoo
(16 items)
Ryzen R5 2600X
Noctua NH-U12
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Audio
Asus Xonar STX
rul3s is offline
post #10 of 19 (permalink) Old 06-13-2019, 06:21 AM
Rep: 1 (Unique: 1)
Test bench reviews much?!
Haaha!!,"keep sleeping on that pillow"!!
In a case like the one you have, you eliminate the fan factor, so to speak, which leaves you with a comparison of heatsink vs heatsink, and since they're both very similar. There you have it.
Shenhua is offline
Tags
cooler , degrade , heatpipes , Noctua
