Noctua NH U12S SE AM4 or Corsair H115i PRO [2600x/3600x] - Page 6 - Overclock.net - An Overclocking Community
post #51 of 63 (permalink) Old 06-20-2019, 03:09 AM
doyll's Avatar
Rep: 1702 (Unique: 941)
Thanks for the info.
Wish we knew what the temp of air flowing into air cooler was compared to room temp air flowing into radiator. If you are interested in monitoring airflow temp, here is link to how I do it as well as guide to optimizing case airflow.
https://www.overclock.net/forum/22319249-post5.html
doyll is offline
post #52 of 63 (permalink) Old 06-20-2019, 04:03 AM
Martin778's Avatar
Rep: 18 (Unique: 18)
Kind of a predicatble result :-) When you test a CPU that acutally is able to transfer the heat efficiently to the haetspreader, the results will change significantly. (I'm looking at you, Intel - with stock vs direct die temp differences of 20c!). That's the main reason I skip reviews when they use a non-delidded 7700K or 8700K...
Martin778 is offline
post #53 of 63 (permalink) Old 06-20-2019, 05:39 AM
doyll's Avatar
Anytime we see test results in degrees with no reference to air temp going into cooler we have to take that results with a heavy dose of salt.
This is even more true when those results include CLCs mounted as intake while air coolers are in middle of case usually wihtout near enough case airflow to supply them with air that is only 5c above room temp .. often it's 10c difference or more and every degree warmer the air into cooler is translates into almost exactly the same number of degrees hotter CPU is.
So a CLC mounted as intake giving a CPU temp of 65c while an air cooler mounted on CPU using 10c warmer air will be 75c when both air cooler and CLC are removing exactly the same amount of heat from CPU.
doyll is offline
post #54 of 63 (permalink) Old 06-23-2019, 11:43 AM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
Shouldn't test with PBO. PBO maximizes the CPU power until it hits the limit as long as temperature is below threshold.
If you're testing cooler performance you really need a fixed clockspeed and fixed voltage with a consistent repeatable load.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #55 of 63 (permalink) Old 06-24-2019, 03:06 AM
poah's Avatar
Rep: 8 (Unique: 7)
tuff - that is what happens when you use an air cooler. You are at the mercy of the internal case temp which is a major downside of an air cooler. of course if you actually use an open air test bench rather than a case it isn't an issue is it.
poah is offline
post #56 of 63 (permalink) Old 06-24-2019, 04:36 AM
doyll's Avatar
More from the great poah .. is that just more poah to step in?
With a decent case setup with decent fans there is no downside.
Case with good fans flow air at or near room temp to components cooling as well or better than as well as quieter than CLCs .. and are much more dependable as well as lower priced .. meaning air cooling is clearly the choice of informed buyers.
A test bench is just that, a test bench.
doyll is offline
post #57 of 63 (permalink) Old 06-24-2019, 04:45 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
But....but.....that would require setting up airflow correctly....that would be so hard and take moments of planning.....the other components in the system don't need cooling or airflow.....I wuv my Asetek.....
ciarlatano is offline
post #58 of 63 (permalink) Old 06-25-2019, 12:58 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
That makes a lot of sense.
Friday when I received the noctua I've made some tests, with H115i PRO before dissasemble I got 67º max temp on realbench.
30 minutes later, with NHU12A, got 74º on max temp with same test.
At first I was thinking about thermal paste, just need time to sit down, but, heatsink was really "hot" so thermal-conductivity was working good.
Maybe PBO was reaching higher than with CLC, I dont know now, but 100% agree that test should have been made with fixed voltage/freqs, now it's to late.
But I'm happpy with the change, NHU12A is not as big as I thought and its working pretty well and silent, so it's OK, but I'll keep in my mind that H115i PRO was performing better, louder, but better.
PhanteksR7
(16 items)
Ryzen R7 3700x
Asus x470 Strix F
RTX 2070 Windforce OC
KFA2 HOF Extreme DDR4 4000CL19 BDie
Samsung 970EvoPlus 500GB NVMe
Samsung 850Pro 512GB
Samsung 860QVO 2TB
Seasonic Focus+ 650W Platinium
Noctua NH-U12P
Phanteks Enthoo Pro M SE
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Razer Goliathus Cosmic Speed
Audio
Asus Xonar STX
rul3s is offline
post #59 of 63 (permalink) Old 06-25-2019, 02:21 AM
PC Enthusiast
Ashura's Avatar
Rep: 53 (Unique: 40)
Thanks for sharing your results. Your build is super clean, looks great!.
Did you switch back to NH U12s?
PolaRyz
(15 items)
AMD Ryzen R7 1700x
Asus Crosshair VI Hero
Asus GTX 1060 6Gb
Hyper X Predator 32gb 3000Mhz
Crucial MX100 256 GB
Seagate ST1000DM003
Toshiba DC01ACA300
SeaSonic S12G 750w 80+ Gold
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Logitech G402 Hyperion Fury
Mousepad
Steelseries Qck Mass
Ashura is offline
post #60 of 63 (permalink) Old 06-25-2019, 02:38 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
Nope, my previous heatsink was a NHU12P, I've sold it and buy a NHU12A, the one you see on the pic.
PhanteksR7
(16 items)
Ryzen R7 3700x
Asus x470 Strix F
Samsung 860QVO 2TB
Noctua NH-U12P
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Audio
Asus Xonar STX
rul3s is offline
Tags
Corsair , h115i , nhu12s , Noctua
