Noctua NH U12S SE AM4 or Corsair H115i PRO [2600x/3600x] - Overclock.net - An Overclocking Community
post #1 of 63 (permalink) Old 06-17-2019, 08:04 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
Hello mates,
As I stated on this topic my "old" Noctua NH U12P is not working well with my actual Ryzen 2600X and I want to replace it.
I was thinking about going the same line, with Noctua NH-U12S AM4 SE or try a the CLC Corsair H115i PRO
Points to consider:
- My case is Phanteks Enthoo Pro M SE full with 4x14cm phanteks fan (2 intake, 2 outtake)
- I apreciate silence, my actual build is very silent IMO
- Price is not a problem, 60€ for the Noctua, and 115€ for the Corsair (on sale)
- I DO overclock, I want to keep my 2600x the coolest and in a future the 3600x, just to let PBO max out speed.
- Aestethics is important to me, never had a CLC but I think that this would be very nice with the Phanteks Halos that I already have.
- I dont want bigger air coolers like NHu15D os similar, I usually move the computer and I dont like the aesthetics on them.
So, what would you do?
EDIT 1: First test with Corsair H115i PRO
Quote: Originally Posted by rul3s View Post
Hello guys,
Yesterday I've received the Corsair H115i PRO and those are my impresions.
First o fall, mounting it on the top was so ugly, to many space lost, so I was going to mount it on the front.
Mounting it on the front has some problems, so to have it fans on the front pushing air to the cooler on the back, you have to take out the hdd caddy and the plate covering it to let the radiator go lower, and I needed the hdd caddy.
Finally I got it like this:
2 original 14cm fan pushing air botom-middle, radiator mounted on the middle-top, and 2 corsair ML fans on pull also on middle-top.
I didn't like iCUE software, so hard to discover the way to change from silent to balanced profile, now the tests.
CONFIG:
CPU [email protected]
PBO settings maxed out
vcore offset -0.875 + LLC Level 6
vsoc 1.025
DRAM [email protected] 1.40v
Noctua NHU12P (old one, 8 years)
Gaming CSGO: 49-53º
Realbench 1h: 78-80º, peak 87º
Corsair H115i PRO SILENT(Config as I described before, 2 fans push, 2 fans pull)
Gaming CSGO: 50-52º
Realbench 1h: 69-73º, peak 84º
Corsair H115i PRO BALANCED(Config as I described before, 2 fans push, 2 fans pull)
Gaming CSGO: 47-50º
Realbench 1h: 64-67º, peak 75º
The main diference on performance about SILENT and BALANCED was the pump RPM's, going silent and PUMT on balanced throwed almost the same perf as all in balanced.
Also, I've found the kit so silent, no as silent as before, but no problem about it.
Cons:
- I didnt like the cable management, had so many cables from the cpu-block.
- Front mount was not as I expected, not 100% agree with the result.
- I was expecting more performance, like not hitting 70º in realbench
So, I've found one Noctua NHU12A from Review at 70$, I'ver ordered it and I'll be making tests all the weekend and keep the one I like the most, I'll keep you informed guys!
EDIT2:
Quote: Originally Posted by AlphaC View Post
Shouldn't test with PBO. PBO maximizes the CPU power until it hits the limit as long as temperature is below threshold.
If you're testing cooler performance you really need a fixed clockspeed and fixed voltage with a consistent repeatable load.
That makes a lot of sense.
Friday when I received the noctua I've made some tests, with H115i PRO before dissasemble I got 67º max temp on realbench.
30 minutes later, with NHU12A, got 74º on max temp with same test.
At first I was thinking about thermal paste, just need time to sit down, but, heatsink was really "hot" so thermal-conductivity was working good.
Maybe PBO was reaching higher than with CLC, I dont know now, but 100% agree that test should have been made with fixed voltage/freqs, now it's to late.
But I'm happpy with the change, NHU12A is not as big as I thought and its working pretty well and silent, so it's OK, but I'll keep in my mind that H115i PRO was performing better, louder, but better.
MainEnthoo
(16 items)
Ryzen R5 2600X
MSI x470 Gaming Pro Carbon
RTX 2070 Windforce OC
KFA2 HOF Extreme DDR4 [email protected]
Samsung 970EvoPlus 500GB NVMe
Samsung 850Pro 512GB
Western Digital Black 2TB
Seasonic Focus+ 650W Platinium
Noctua NH-U12
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Razer Goliathus Cosmic Speed
Audio
Asus Xonar STX
rul3s is offline
post #2 of 63 (permalink) Old 06-17-2019, 08:21 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 996 (Unique: 605)
if money isn't an issue get whatever you like better.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #3 of 63 (permalink) Old 06-17-2019, 09:49 AM
Rep: 42 (Unique: 34)
Have you thought about the NH-U12A? It performs better than both, and has great sound performance as well. Infact, the NH-U12A even beats the Corsair H150i.
Buris is offline
post #4 of 63 (permalink) Old 06-17-2019, 10:05 AM
NewType88's Avatar
Rep: 1 (Unique: 1)
I would get the NH-U12A. Aesthetics are subjective, I personally think air coolers look better than AIO's.
NewType88 is offline
post #5 of 63 (permalink) Old 06-17-2019, 10:06 AM
Senior OCN Member
shilka's Avatar
Rep: 2733 (Unique: 1624)
Dont buy a CLC cooler its going to be worse in every way compared to your old NH-U12P
https://www.overclock.net/forum/61-w...lc-cooler.html
The NH-U12A or NH-D14/15 are better options than the NH-U12S
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
EVGA GTX 1080 FTW2
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
EVGA SuperNova G2 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod E series PSU cable set
shilka is offline
post #6 of 63 (permalink) Old 06-17-2019, 10:07 AM
⤷ αC
AlphaC's Avatar
Rep: 872 (Unique: 575)
Don't buy NH-U12S , it's not stronger than other $40-50 coolers at this point such as Scythe Mugen 5 Rev B, Thermalright ARO-M14G (Macho Rev B with AM4 mounting only) , or Thermalright True Spirit 140 Power (one of the strongest slim towers due to 6x 8mm heatpipes). The NF-F12 fan is also rather underwhelming on its own so neither the heatsink nor the fan are standouts.
If you want to buy Noctua I'd probably spend ~$60 on the NH-U14S. It's been shown to outperform the ARO-M14G in some tests and the NF-A14 hasn't been replaced by a better fan yet.
The NH-U12S doesn't have the heatpipes or fin area of other top slim towers which is why NH-U12A came out this year.
If you're looking at watercoolers , even if you want RGB, I'd be looking at full copper solutions such as Swiftech Drive x3 series for ~$160. The step up is from $50 air coolers to $150 copper expandable watercoolers. You can go from a $40-50 air cooler to a $70-90 one but the improvement isn't as large as from a ~$30 4 heatpipe Scyhe Kotetsu MKII/ Be Quiet Pure rock / Cryorig H7 / Arctic Freezer series to a 6 heatpipe Mugen 5 or ARO-M14G.
Buying a H115i is like going from a NH-U14s to a NH-D15s, a few degrees at most unless you have a overclock on a 8+ core CPU pulling over 160W.
see https://nl.hardware.info/reviews/778...j-30-en-40-dbn
When limited to 30dB the Mugen 5 (the Mugen 5 has a 1200rpm fan rather than 1500rpm) outperforms the NH-U12S.
Hyper 212 to Mugen 5 is over 10 degree drop
In computerbase's latest testing on Ryzen 7 CPU overclocked in a highly restrictive Thermaltake F51 case which favors liquid cooling:
https://www.computerbase.de/2019-06/...ldruckpegel-oc
Be Quiet Dark Rock 4 52.4 degrees delta temp @ 35.5dBA <--- failed HardOCP testing
Thermalright Macho Rev B 51.2 degrees delta temp @ 37dBA
Mugen 5 50.8 degrees delta temp @ 37dBA
Silver arrow T8 with Noctua fans 48.8 degrees delta temp @ 36dBA (otherwise ~ 48.8 degrees delta temp is achieved with ~ 39dBA)
Noctua NH-D15 49.3 degree delta temp @33.5dBA
Noctua NH-U12A 48.1 degrees delta temp @ 35.5dBA
H115i pro 46.5 degrees delta temp @ 34dBA
Also
Noctua NH-D15 = 44.2degree delta temp @36.5dbA
H115i pro = 41.9 degree delta temp @37dBA
From NH-U12A review
Name:	NH-U12A Ryzen OC.png
https://www.computerbase.de/2019-05/...ldruckpegel-oc
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #7 of 63 (permalink) Old 06-17-2019, 10:07 AM
Senior OCN Member
shilka's Avatar
NH-U12A beats the H100i and the H150i
Seravee
(30 items)
Intel Core I7 6850K
EVGA GTX 1080 FTW2
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
post #8 of 63 (permalink) Old 06-17-2019, 12:48 PM
poah's Avatar
Rep: 4 (Unique: 3)
easy to find other reviews that disagree
https://www.guru3d.com/articles_page...review,11.html
poah is offline
post #9 of 63 (permalink) Old 06-17-2019, 12:51 PM
Senior OCN Member
shilka's Avatar
Never mind
Seravee
(30 items)
Intel Core I7 6850K
EVGA GTX 1080 FTW2
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
post #10 of 63 (permalink) Old 06-17-2019, 02:31 PM
Rep: 2 (Unique: 2)
Thermalright aro m14. Big, heavy, cheap, reliable and silent.
Enviado desde mi Redmi Note 3 mediante Tapatalk
Shenhua is offline
Tags
Corsair , h115i , nhu12s , Noctua
