Looking for Cooling Thoughts/Opinions - Page 3 - Overclock.net - An Overclocking Community
post #21 of 36 (permalink) Old 07-11-2019, 01:45 PM - Thread Starter
zyxwvu4321's Avatar
Rep: 0
Quote: Originally Posted by doyll View Post
Thanks for the update!
Definitely no clearance problems there. What did you have on it before and what are temps now compared to before?
Current settings are Ryzen 5 2600 running at 4.1GHz w/1.25v.
Yesterday I tested out the H100i and it's max temp running the newest Prime95 Small ffts was 62.9c. Preliminary testing with the TSP a bit disappointing... it hit 70.3c after like 5 minutes when Prime95 started up the 2nd calculation. It is giving me the same idle temps of ~30c. I may try reseating it when I get home from work in the morning. Thanks!
zyxwvu4321 is offline
post #22 of 36 (permalink) Old 07-11-2019, 04:26 PM
Fix it till its broke
Owterspace's Avatar
Rep: 7 (Unique: 4)
Just curious how long you let prime run for? It takes a bit for the coolant to get heat soaked. I didn't have any problems with my H100 when it was new.. It was great. I didn't use the stock fans though, I was using beast fans. I used it for five years, and after the third or fourth it started losing capacity. I was using an x5690 on it. My brother is using that H100 now on his 7700k, and its running at 4500. You can try reseating it, might help. I would have to go back in the thread to see what your case cooling setup is like. To really achieve the best results with this cooler, you need to move some air. Like with the H100, it ramped up pretty quick and got pretty loud. TY-143 would work well for you
3770K @ 4600MHz 1.265v/Thermalright Le Grand Macho RT/TF8/TY-143
ASRock Z77 OC Formula|12GB G.Skill Mix @ 933MHz 9-10-9-28 2T 1.6v
EVGA GTX 980 Classified 3988 @ 1497/2001|Intel 545S x2
CM Silent Pro M2 850|FD Define R4/5x 120x38 @7v/TY-147A+B|ZM-MFC2
Owterspace is offline
post #23 of 36 (permalink) Old 07-11-2019, 07:25 PM - Thread Starter
zyxwvu4321's Avatar
Rep: 0
My bad! I had intended to mention in my previous post about the times. P95 ran for a bit over 1.5 hours with the H100i, and that peak happened well before I stopped it. I probably do need to fiddle with the air flow since I have a big ol GPU in the middle of everything. I took pictures but didn't have time to post since I was in a rush to get to work.
post #24 of 36 (permalink) Old 07-12-2019, 01:46 AM - Thread Starter
zyxwvu4321's Avatar
Rep: 0
Yeah, not too sure what I can do to increase air to the cooler with how the case is laid out. :-/ Will probably end up cutting out the grill with that upper intake fan. Gives it a super annoying high-pitched sound. All fans are Phanteks PH-F140SPs. http://www.phanteks.com/PH-F140SP.html
post #25 of 36 (permalink) Old 07-12-2019, 01:50 AM
Graphics Junkie
UltraMega's Avatar
Rep: 56 (Unique: 51)
CLCs tend to begin failing after a couple of years. There seems to be a correlation of failure rates with top mounted being lowest, radiator in front with hose fittings are at bottom and front mount with hose fittings at top being worse, but I'm not sure which is which there. It has to do with keeping pump/waterblock on CPU lower than radiators so air collects in radiator, not pump.
Failure rates aside, my H115i just doesn't preform any better than a Noctua would, and the Noctua is more reliable long term while also being cheaper, quieter, and doesn't need any annoying software.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is online now
post #26 of 36 (permalink) Old 07-12-2019, 03:09 AM
doyll's Avatar
Rep: 1696 (Unique: 938)
zyxwvu4321
Do you have a way to monitor air temp into cooler during testing? If you run something like Handbrake at 100% it puts CPU at 100% load as soon as it starts encoding and peak temps will be in about 5 minutes. It may not be a problem, but your top intake may be disrupting the cooler fan's ability to draw air in. This is becuase top fan is forcing air at right angles to what cooler fan needs. Like I said, it may not be a problem.
Do temps go down if you open case front door?
First graph is approx 10 minute run of [email protected] under TRUE Spirit 140 Power using Handbrake at 100% CPU use doing a short run to show how it reaches max temp in about 3 minutes and drops back to idle temp in simialr 3 minutes. You can see it take another couple of minutes for case's airflow to stablize with temps coming down a few degrees.
2nd graph is 24 hours on 6700K under TRUE Spirit 140 Direct.
Below are links to what I monitor airflow temp into cooler with, and how to optimize case airflow.
https://www.overclock.net/forum/22319171-post2.html
https://www.overclock.net/forum/22319249-post5.html
Preaching to th choir. The only AIO I use for more than testing is be quiet! Silent Loop 280. I topped up coolant at about 8 months, changed coolant at about 15 months and topped up new coolant about 8 months ago so it's time to change coolant again.
Name:	i7 980 Prime 95 27-07-2014 mod .jpg
Name:	6700k 24hr temp load graph.png
doyll is offline
post #27 of 36 (permalink) Old 07-12-2019, 05:33 AM
Owterspace's Avatar
Rep: 7 (Unique: 4)
Holy ****, the cooler is almost on the GPU. Impressive. You are probably grabbing heat from that. In which case, TY143 would definitely help.
On mine, I have a ton of space.
post #28 of 36 (permalink) Old 07-12-2019, 01:47 PM - Thread Starter
zyxwvu4321's Avatar
Rep: 0
zyxwvu4321
I did run out and buy one of those indoor/outdoor thermometers to hang inside. While running Handbrake, the sensor was dangling ~2-2.5cm in front of cooler fan. During the entire run, the temp of the sensor stayed ~1C higher than ambient. It rose a bit during the run until my AC kicked on, but always the same amount above ambient. My Handbrake run did reach peak ~3 minutes after it started, topping out at 68.1C, then back down to the normal idle temp of 30C quickly afterwards. Haven't had time to do any other testing like removing front, removing top fan, etc.
Yeah, the base of the cooler is larger than the top of a Ryzen chip, so when I get it placed for good, I may try to slide it a bit higher towards the top of the case to get a little more space between the GPU.
post #29 of 36 (permalink) Old 07-13-2019, 03:03 AM
doyll's Avatar
Mount basically indexes cooler centered on CPU, so it's not easy to offset and get a good seat. I would not try mounting cooler off of center. It's not going to move, so as long as it's not touching GPU you are fine. I've has some coolers that mounted so close to GPU I put a thin piece of plastic between them just to be sure it there would be no contact and possible electrical short.
doyll is offline
post #30 of 36 (permalink) Old 07-13-2019, 02:13 PM - Thread Starter
zyxwvu4321's Avatar
Rep: 0
Ah, good deal!
I had some time to run a couple more Handbrake tests today. For all of these, the room temp was ~24.5c and the sensor about 3-4cm in front of the cooler was ~25.5c.
After reseating the cooler and tightening it down a little more, the max temp was 67.1c. I then tried unplugging that top fan and running the same test. Temperature sensor didn't show any changes, but CPU temp maxed out at 69c this time.
Will try more in the future!
