How do I go about Air Cooling the Lian Li PC-011 Dynamic? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 07-18-2019, 09:59 AM - Thread Starter
Rep: 0
I will order the following parts:
Case: Lian Li PC-O11 Dynamic
Fans for intake (side panel): 3 Lian Li Bora Digital Fans
Motherboard: Gigabyte X570 Aorus Elite
CPU: AMD 3900x
GPU: AMD Radeon 5700XT
CPU Cooler: Noctua NH-U12A
Using 3 fans on the side only, is enough?
3 intake only? 3 exhaust only?
I can´t figure out.
Any help will be appreciated
mestregroda is offline
post #2 of 8 (permalink) Old 07-18-2019, 10:56 AM
Brightmist's Avatar
Rep: 18 (Unique: 17)
3900X, 5700X and X570 Aorus Elite are fine but I suggest waiting a bit more and getting an AIB 5700XT with better cooling instead of the blower version.
Similarly, NH-U12A @ 100$/€ is pretty overpriced. You can get Thermalright Le Grand Macho RT or a similar high end cooler for less and they'll probably provide better cooling.
I'm also not a big fan of O11 Dynamic's design and it doesn't come with any fans. It also has pretty low CPU cooler clearance if you're going air cooling. I'd probably go for something like Phanteks Evolv X instead that already comes with 3 decent fans which is all you need as intake fans and you shouldn't need any exhaust fans. Do remove unused back PCI-E covers to further help front intake fans push hot air out of the case.
Brightmist is offline
post #3 of 8 (permalink) Old 07-18-2019, 11:00 AM
TeslaHUN's Avatar
Rep: 18 (Unique: 16)
CPU: AMD 3900x
I can´t figure out.
In this review, they are testing various fan setup with tower CPU cooler
TeslaHUN is offline
post #4 of 8 (permalink) Old 07-18-2019, 11:03 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1035 (Unique: 619)
there's a 154mm CPU cooler height limit in the PC-011. Rules out a lot of coolers.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #5 of 8 (permalink) Old 07-18-2019, 03:25 PM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
The premier air cooling cases are Phanteks P600S , Fractal Design Meshify S2, Meshify C not Lian Li O11.
The Lian Li case is more suited to closed loop or open loop liquid.
I don't know if you can even fit the mugen 5 Rev B in the Lian Li O11, the mugen 5 is supposedly 154.5mm. Maybe that 0.5mm might fit, maybe not. The official Lian Li sites lists 155mm cooler height.
The NH-U12A probably isn't going to fit in there since it's 158mm.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #6 of 8 (permalink) Old 07-18-2019, 04:52 PM
makkara's Avatar
Rep: 2 (Unique: 2)
According to spec and this build 154,5mm cooler should fit, at least on intel. On amd the socket and CPU are probably couple mm higher.
https://builds.gg/shinoshido/polar-vortech-17676
E: According to this intel and amd have very similar height of the socket + CPU.
https://hardforum.com/threads/am4-so...eeded.1930302/
Air PC-O11 Dynamic
(8 items)
AMD Ryzen 7 3700X
MSI B450 TOMAHAWK MAX
G.Skill 16GB (2 x 8GB) Ripjaws V F4-3600C16D-16GVK
Corsair Force MP510 1TB NVMe
Seasonic FOCUS Plus 750 Gold
Scythe Fuma 2
Noctua NF-F12 PWM chromax.black.swap
makkara is offline
post #7 of 8 (permalink) Old 07-19-2019, 07:20 AM - Thread Starter
Rep: 0
Thanks all, I'll going watercooling instead
post #8 of 8 (permalink) Old 07-21-2019, 09:45 AM
ride1226's Avatar
Rep: 1 (Unique: 1)
Before you dump the money in liquid, I was running my i7-7700k at 4.8ghz in the mid 60s by just running all positive pressure on the case fans using the 3x 120mm on the side of the case. No other intakes or exhaust. Coupled that with a Cryorig h7 Quad Lumi and an extra fan on the heatsink for push pull. Worked fine for me over the past year. I could run 5.0ghz on it and still maintain temps in the 80s but didnt want to run that warm. Yes, its not the best case in terms of cooler clearance, but it was more worth it to me then spending multiple hundreds of dollars on a custom loop for a .2ghz increase in clock speed.
ride1226 is offline
