AIO or Aiur Cooled!? - Overclock.net - An Overclocking Community
post #1 of 84 (permalink) Old 08-07-2019, 11:10 AM - Thread Starter
Rep: 59 (Unique: 49)
So, i always hear that Air cooled is "better" but i was wondering...Why!? As the better ones tend to be MASSIVE and normally are hideous to look at. I need to get a New CPU cooler and people say to get Noctua NH-U12A which itself is nearly £90. Why not for example get a Corsair Hydro Series H100x? Both the same price, one is HUGE the other isn't If space/Aesthetic is just as important as cooling. Maybe not quite, but enough to make you question getting the NH-U12A for example. What else could you guys suggest?
I was thinking about the Freezer 34 eSports Duo Arctic, seems quite decent, reasonable price. Doesnt look to overly huge and nice black colour scheme but not too sure.As the case is a Corsair Air 540 if i did get a air cooled fan, due to the cooler needing to be facing the front of the case i would have 3 fans blowing cold (when its not insanely hot summer!) into the case, directly into the CPU cooler fans but that also have the issue of the RAM slots as not sure what ones will be able to fit in there without having any issues with the RAM i have as they aren't short ones.
Its for a Tomahawk Max with a Ryzen 5 3600.
ArmageddonAsh is offline
post #2 of 84 (permalink) Old 08-07-2019, 11:28 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1448 (Unique: 730)
If your budget is under ~$100, go air.
Not much to explain, a <$100 air cooler performs better than a <$100 AIO.
If your worries are RAM clearance, the Thermalright Le Grand Macho RT is one of the best air coolers you can buy and won't block any RAM slots regardless how tall your RAM is.
If your worries are with airflow/case airflow, then you need to fix that before dumping money into a cooler because an AIO and a heatsink both need good airflow to function. Otherwise you're just wasting money.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #3 of 84 (permalink) Old 08-07-2019, 11:32 AM
The last VRM burner
Rep: 47 (Unique: 27)
Because... AiOs performance suck when compared to air cooling at half the water cooling one price. You need to spend tons of bucks to get an equivalent cooling capability of Le Grand Macho, Tisis or NH-D14. Also, they're much louder. And if a person go for looks first then well... he's dumb
PC for all
(23 items)
i7 5775c @4.2GHz/3.8GHz
MSI Z97 MPower
Iris Pro 6200 1300MHz
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Front Arctic P14 PWM PST x2
Top Arctic P14 x2
Back Arctic P12
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mouse
Tiger Gaming Arc teflon mouse feet
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 84 (permalink) Old 08-07-2019, 11:32 AM - Thread Starter
If your worries are airflow, then you need to fix that before dumping money into a cooler, because an AIO and a heatsink both need good airflow to function.
Well, Noctua NH-U12A Vs Corsair Hydro Series H100x? Both same cost. Price isnt as much of a problem, without going into the crazy, crazy prices that i have seen. Lets say my budget at most was £100. Would the top end Air cooler still beat then top end AIO cooler in that price range?
post #5 of 84 (permalink) Old 08-07-2019, 11:36 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
This pretty much sums it up. Then you can add in the fact that air coolers are far more reliable and never leak or have a tube burst.
ciarlatano is offline
post #6 of 84 (permalink) Old 08-07-2019, 11:38 AM
9 Cans of Ravioli
The Pook's Avatar
H100X is old and has 40dBa fans and an old Gen4 Asetek pump (new AIOs are Gen6). Go with the NH-U12A.
The only Corsair AIOs you should be looking at is the H100i Pro, H115i Pro, or H150i Pro.
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
WD Blue 4TB SSD
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Operating System
Keyboard
Mouse
Logitech G603
The Pook is offline
post #7 of 84 (permalink) Old 08-07-2019, 11:39 AM
ciarlatano's Avatar
Performance on those two particular pieces would be nearly the same, but the the Noctua would be significantly quieter doing it.
And.....there are plenty of other air coolers out there that you could say the same about. Many of which may appeal to you more on the aesthetic side.
Has there ever been a shred of evidence showing that the newer gen pumps have any performance advantage? Or any advantage at all? We have seen Asetek gen changes that were nothing more than a change to cut production costs, so.....
post #8 of 84 (permalink) Old 08-07-2019, 11:41 AM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
If it's a Ryzen 5 3600 then it's an utter waste of money to buy a £90 NH-U12A or a Corsair 240mm AIO.
There's $50 coolers that will cool it more than fine that have been shown to handle prior gen Ryzen 7 chips, such as Scythe's Mugen 5 (6 heatpipes) , Thermalright ARO-M14G (also 6 heatpipes) and is equal to Macho Rev B, Thermalright True Spirit 140 Power (6 x 8mm heatpipes), etc. That's not even including within Noctua's own lineup, since the NH-U14S (6 heatpipes) cools within a degree or two for low TDP chips (<150W).
£38.49 https://www.alternate.co.uk/Thermalr...roduct/1170066
£40.38 https://www.aquatuning.co.uk/air-coo...grey-amd-ryzen
£42.95 https://www.overclockers.co.uk/scyth...hs-046-sy.html
What you need to be looking at is: heatpipes, heatpipe contact (direct touch loses some capability since the heatpipe has part of it removed and flattened), fin area , heatsink mass (sans fans), and fan quality.
The Freezer 34 comes with Arctic's new fans but at the end of the day it's still a 4 x6mm direct contact heatpipe cooler. What you want is as many heatpipes that will fit over the Ryzen IHS (6x6mm = 36mm while the IHS is 37mmx37mm). If the 4x6mm heatpipes are concentrated at the middle they probably won't help the chiplets, especially for direct contact designs that don't have a full baseplate.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #9 of 84 (permalink) Old 08-07-2019, 11:42 AM - Thread Starter
I had a Corsair AIO and had zero problems from it at all. Just because they can break - doesnt mean they do. Same could be said for Air coolers. ANything can break. Freezer 34 eSports Duo Arctic is one that i have been interested in. Doesnt look too huge, isnt really ugly, nice colour scheme as well. Dark Rock Pro 4 CPU Cooler doesnt look too bad, nice colour. I wonder if it would need fans on the outside as well as one on the inner part as well? Looks like it can go fan / Metal / Fan / Metal / Fan. The issue i also have is how well they would fit, where as a AIO would be an easy one to fit into it and not have to worry about the fans touching RAM slots or anything else
post #10 of 84 (permalink) Old 08-07-2019, 11:50 AM
Gaming enthusiast
Ironcobra's Avatar
Rep: 36 (Unique: 30)
Not to mention Corsair has excellent customer service and a 5 year warranty on there aio, my 3600 on a 115i is idling around 27c and gaming around 50c with nice and quiet noctua fans. I do not miss having those small block v8s attached to my cpu. My next move will be to a full loop when I replace my 1080ti but until then Im happy with my aio with the fan upgrades of coarse. The corsair fans are dog ****
Origin: Ironcobra80
Steam: Ironcobra
Gaming Ryzen
(14 items)
3600
Gigabyte Auros Master x570
EVGA XC ULTRA 2080 TI
G.SKILL TridentZ RGB F4-3600C16D-16GTZR (16-15-15-28 3800)
HP EX950 1TB
SAMSUNG EVO 860 1TB
SEASONIC FOCUS+ GOLD 650W
CORSAIR 115I PRO PUSH/PULL FANS-NOCTUA
CORSAIR CARBIDE AIR 540
Operating System
W10 FAST RING
LG OLED C6 65"
Keyboard
Varmilo VB87M
Mouse
LOGITECH G900
Mousepad
Zowie Gear P-SR
Ironcobra is offline
