Monsterlabo Passive Cooled SFF Case - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 08-14-2019, 04:05 PM - Thread Starter
Heuchler's Avatar
Rep: 274 (Unique: 193)
Monsterlabo Passive cooled SFF case
https://www.monsterlabo.com/the-first-1
Monsterlabo First - 200-watt Passive lab test
https://www.igorslab.media/monsterla...ortest-teil-1/
Google Translate
https://translate.google.com/transla...test-teil-1%2F
Igor Wallossek ended up 3D scanning his GPU and hopefully in Part II of the video will have a custom GPU solution.
[Igor'sLAB] Monsterlabo The First Review
MonsterLabo The First Review – Not Quite Silent
https://www.kitguru.net/components/l...-quite-silent/
Specification:
Motherboard support: Mini-ITX
Included fans: Premium Package includes 1x 140mm Noctua
Fan mounts: 1x 120/140mm
Fanless configuration: CPU 100W, GPU 120W
Active configuration: CPU 140W, GPU 160W
5.25-inch optical drive bays: None
Internal drive bays: 1x 3.5-inch, 3x 2.5-inch
Power supply: ATX, SFX-L, SFX (Max. length 160mm)
Dimensions: 430mm H x 205mm D x 215mm W
Seasonic fanless PSU
Zalman had fanless cases a long time ago - TMM 300 and TNN 500AF
Name:	MonsterLabo Passive SFF case.jpg
Name:	Monsterlabo passive-cooling.jpg
Overclocking History (Click to show)
Intel 386DX/16 @ 20 MHz
CX486SLC/50 @ 50 MHz
AM486DX2/80 @ 100 MHz
AM486 DX4-100 @ 120 MHz
AK5x86-P75 [email protected] 160 MHz
Pentium 90 @ 120 Mhz
IBM 6x86L P166+ [email protected] 160 MHz
Celeron 300a @ 454 MHz
Pentium 3 700 @ 933 MHz
Athlon XP 1400+ @ 1600 MHz
Athlon XP 1800+ @ 2088 MHz
Athlon XP 2500+ @ 2200 MHz
Athlon 64 3000+ @ 2603 MHz
Athlon X2 BE2300 @ 1900 MHz
Athlon X2 4200+ @ 2210 MHz
Athlon X2 5000+ @ 2600 MHz
Core 2 Duo E4300 @ 3000 MHz
Core 2 Duo E6750 @ 3600 MHz
Core 2 Duo E8400 @ 4000 MHz
Xeon C2Q L5408 @ 3200 MHz
Xeon C2Q X5450 @ 3300 MHz
Xeon C2Q E5440 @ 3400 MHz
Xeon C2Q E5450 @ 3600 MHz
Phenom2 X4 B50 @ 3700 MHz
Phenom2 X6 1045T @ 4050 MHz
Core i5-2500K Sandy @ 4500 MHz
X5650 6-Core Westmere @ 3982 MHz
AMD FX 8320E Black Edition
FX-8320E @4.5GHz, X5650 @ 4.0GHz, X6 1045T @4.0GHz, i7 [email protected]
Thinkpad T420p with i7-2720QM overclocked because this is OCN
Heuchler is offline
post #2 of 3 (permalink) Old 08-14-2019, 05:02 PM
Brightmist's Avatar
Rep: 18 (Unique: 17)
This is a good concept. Apple's latest Mac Pro also has similar custom motherboard/cooling design relying on air cooling and I liked that too(albeit it's way too overpriced).
I'm hoping we'll at least get some cases with integrated GPU cooling similar to this in the future even if they don't include CPU cooling since it's less of an issue.
Brightmist is offline
post #3 of 3 (permalink) Old 08-14-2019, 05:58 PM - Thread Starter
Heuchler's Avatar
Really have now idea why they didn't go Threadripper solution or Ryzen 3000s for PCIe Gen 4 instead of the odd dual PCIe slot for dual Vega Solution (Vega II Duo) in the new Mac Pro.
Would be a fun DIY project.
Heuchler is offline
