Upgrading stock cooler for less than $60 - Page 11 - Overclock.net - An Overclocking Community
post #101 of 106 (permalink) Old 09-03-2019, 08:57 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
Quote: Originally Posted by MoNsTeReNeRgY22 View Post
Wow its been years since I used speedfan, thanks! I will give that a whirl and then will look into aquareo controllers if that does not work out.
Appreciate everyones help with this!
Have a look at Argus Monitor, as well. I've had far better success with it than with SpeedFan, and the interface and setup are far easier to use. It's not free, but it does have a free trial and is only like $5 if I recall correctly.
ciarlatano is offline
post #102 of 106 (permalink) Old 09-04-2019, 07:53 AM
Linux Lobbyist
Rep: 1 (Unique: 1)
Here for instance, when I'm doing a budget build for an actual close IRL friend (which means I'm stubbornly not budging on anything), I go like this:
get the cheapest case that's not horrible : https://ms-start.com/en/ms-cyclops-v...ming-case.aspx
Or differently known as AKYGA AKY012BK, the MS is domestic importer of the same chinese chassis just way cheaper (bought it for 27 euros).
It's perfect for it's higher than usual elevating feet, and 0.7mm steel which is at least 0.2mm more thick than the others in it's price range as well as perforated PSU cover. 2xUSB2.0 and 2xUSB3.0 at the front (i dare you to find this at this price point with all the other perks). 2x140/3x120mm front fans, 2x120mm top with magnetic mesh. 163mm CPU cooler height and 400mm gpu cooler length and plenty of room for 2 radiators for water cooling.
And then i proceed to strip the front panel in this fashion: https://imgur.com/a/ak7F8hW
This leaves this flat front beauty of cheapness with front mesh and foam filter removed, and the case prime for either:
1.Putting the mesh back on because the mesh holes are small enough for an ok filter of its own.
2.Putting 1 or 2 pieces of hard mosquito mesh for windows, and securing it in place with twist-ties for easy removal for cleaning.
3.Putting the mosquito mesh pieces in 1 or 2 wood frames that are then secured onto the front frame of the chassis with weak double-sided tape for easy removal
Add a pack of Arctic P12 PWM PST black for 4 euros a pieces (box of 5 for 20 euros), or even Arctic P14 PWM PST black for 5 euros a piece. And the end result is a poor man's Meshify C with unbeatable airflow for 47 euros.
Friend is probably gonna do no.3 cause he has access to wood and woodworking stuff so he's gonna make a nice black frame.
Dogzilla07 is offline
post #103 of 106 (permalink) Old 09-05-2019, 11:27 AM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
Quote: Originally Posted by Roboionator View Post
HI
i "upgraded" with enermax ets-t50 axe silent, and now after 1 min of load i have higher temp than with stock cooler
stock 90
enermax 96
3900x stock
x570 master
at least noise is upgraded
Because you disregarded the placement of the heatpipes. The gap between heatpipes is higher on the T50 Axe. Normally it wouldn't matter that much but it does with chiplet design of Ryzen 3rd gen.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is online now
post #104 of 106 (permalink) Old 09-05-2019, 02:12 PM
Roboionator's Avatar
Rep: 0
I cant place my cooler any other way, ok what do you suggest i sell the cooler and bay what? nice from amd!
I need for this time when i wait for monoblock...
Roboionator is online now
post #105 of 106 (permalink) Old 09-05-2019, 02:21 PM
⤷ αC
AlphaC's Avatar
I mean the placement of the heatpipes within the T50 axe itself. It's nothing you can change yourself. It's just not ideal at all for Ryzen 3rd gen.
post #106 of 106 (permalink) Old 09-09-2019, 03:24 AM
Rep: 0
Ok i go with be quiet Dark Rock Pro i hope will be better, what do you mean? Thx
