Upgrading stock cooler for less than $60 - Page 3 - Overclock.net - An Overclocking Community
post #21 of 106 (permalink) Old 08-18-2019, 12:20 AM
poah's Avatar
Rep: 4 (Unique: 3)
Quote: Originally Posted by ciarlatano View Post
Uh...yeah....ok.....
while the esports duo isn't the best cooler it's cheap and quiet while cooling better than the supplied one.
I'm also not going to trust a review site that places a 120mm cooler ahead of a 280mm one.
poah is online now
post #22 of 106 (permalink) Old 08-18-2019, 05:24 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
But is also a big notch below the coolers already discussed in the thread, and at roughly the same price point. It also doesn't fit in the OP's case. Seems like you put a lot of thought into the recommendation.
Since you don't like the Tweaktown results (neither do I, I have always found their testing suspect at best), let's use the eTeknix results. Keep in mind that the Mugen used in these tests is the low noise version:
Hmmm....didn't seem to keep up with the Scythes there, either. Maybe if we go to another somewhat unknown site (since no major sites seem to review Arctic products these days) that tested the older version Mugen 5 the results will favor the Arctic more:
Nope, didn't work out there, either. So....your recommendation is to buy a cooler that doesn't perform on par with those being discussed, that also doesn't fit in the case. Good job, Sparky, good job. Peddle on!
Yet, when the holes support your opinion they are welcomed, ignored and/or denied - https://www.overclock.net/forum/246-...l#post28079736
ciarlatano is offline
post #23 of 106 (permalink) Old 08-18-2019, 05:44 AM
poah's Avatar
Rep: 4 (Unique: 3)
what has reviews of a fan that shows it to be very good considering the price got to do with a review site that appears a bit dodgy?
also given than his case can take a cooler of 165mm height and the esports 34 duo is only 157mm high how does it not fit?
so remind me why I have to put more thought into to it and peddle on?
These are rhetorical questions. Please don't respond.
poah is online now
post #24 of 106 (permalink) Old 08-18-2019, 06:29 AM
OG AMD
Redwoodz's Avatar
Rep: 582 (Unique: 459)
A couple different other than already good suggestions.
Thermalright ARO-M14G
https://www.amazon.com/Thermalright-...QH3HTS62JPR1H8
Enermax ETS T50 FSS
https://www.amazon.com/Enermax-T50-P...11&s=pc&sr=1-1
both under $60
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #25 of 106 (permalink) Old 08-18-2019, 06:55 AM
ciarlatano's Avatar
Enermax ETS T50 FSS
both under $60
Aquatuning has the ARO-M14G in stock in grey - https://www.aquatuning.us/air-coolin...grey-amd-ryzen . All of the Thermalrights I have used have been great, but i have never used this one, and info on it is a little hard to find. I think @doyll may have wound up doing some tests on it. Maybe he can shed some light.
The Enermax looks interesting, but the three tests I found of it showed drastically different results.
You're right. I made a mistake on the height, which I misread on one site as being 170mm tall. So, I want to give you all of the props you deserve for making a recommendation of a cooler that is clearly outperformed by every other cooler mentioned in the thread, based solely on your thinking that "cheap and quiet while cooling better than the supplied one" is important as getting a better cooler for the same cost, and the fact that you have never tested it yourself but have fans that you like from the same manufacturer, but does fit in the case.
post #26 of 106 (permalink) Old 08-18-2019, 08:13 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
The H7 Plus is an H7 that comes with a second fan, yes? So a ~$25 cooler that is only a few degrees better than a 212 in every other review is their 5th best?
wat
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #27 of 106 (permalink) Old 08-18-2019, 08:54 AM
ciarlatano's Avatar
wat
Yeah...it seems any time I find a review on anything Arctic these days, it still of crazy discrepancies. I think the TT CLC with RGB fans being put on par with the Eisbaer as more comical than the H7 result, though.
post #28 of 106 (permalink) Old 08-18-2019, 10:36 AM
doyll's Avatar
Rep: 1661 (Unique: 924)
Quote: Originally Posted by MoNsTeReNeRgY22 View Post
I just built a new rig with the 3700x and am looking to upgrade my CPU cooler. While I enjoy the looks of the stock cooler, I am not thrilled with the noise and performance.
For now, I honestly am only planning to stay at stock or going for a mild overclock.
I definitely like the black/dark coolers and I can go either way with RGB. I have the NZXT H500i utilizing the stock fan set up; 1 top and 1 rear exhaust.
I don't really want to spend more than $60 since I don't plan on going crazy.
After doing some research and reading various reviews, I found the following but am open to other suggestions:
- CM Hyper 212 RGB Black Edition ~ $40
- CM ML120L RGB ~ $40
What do you think/recommend for me? I appreciate any help and input!
Some very good post, but some absolutely horrible ones as well.
Your NZXT 500i has 165mm CPU clearance. Thermalright ARO-M14G would work very well, so woulld Scythe Mugen 5. I would go Thermalright.
But before you go spending money on new cooler, how do you have your case airflow setup? If case is not flowing cool air to cooler then things will run hot.
doyll is offline
post #29 of 106 (permalink) Old 08-18-2019, 04:46 PM
ciarlatano's Avatar
User results for the ARO-M14G - https://www.overclock.net/forum/246-...l#post28093464
Improvement over a LGMRT on a 3800X. That's pretty impressive. These new Ryzens are definitely different in terms of cooling.
post #30 of 106 (permalink) Old 08-18-2019, 04:57 PM
9 Cans of Ravioli
The Pook's Avatar
if you want something cheap, I just saw this on YouTube.
$17 cooler that's basically on par with a 212 on a 3600 (it lost by 3c but it's got a weaker fan that's 8dBa quieter).
Swap the fan for something decent and it'd likely perform better than the 212 for $10-$15 less.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
