Noctua D15 Fan Configuration - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 08-18-2019, 10:40 AM - Thread Starter
wa3pnt's Avatar
Rep: 15 (Unique: 13)
I did a new build with the D15. Because of the RAM height, I could not place the second fan behind the D15 in Push.
I have the center fan pushing into the rear fin assembly, and the second fan pulling on that same rear fin assembly.
Because a fan in push is more efficient, would I be better off to obtain a 120 fan and place it on the rear fin assembly pushing?
I have checked, and a 120 will clear the RAM.
RodeoGeorge
A link to the Build Log for my latest build (ASUS8) in a Thermaltake Tower 900.
https://www.overclock.net/t/1621450/build-log-thermaltake-tower-900-asus8
wa3pnt is offline
post #2 of 6 (permalink) Old 08-18-2019, 10:42 AM
Senior OCN Member
shilka's Avatar
Rep: 2741 (Unique: 1626)
Adding the second fan will only make it 2c cooler so unless that really matters and you need those 2c dont bother with the second fan the middle one alone is fine
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #3 of 6 (permalink) Old 08-18-2019, 05:39 PM - Thread Starter
wa3pnt's Avatar
The D15 came with 2 fans.
I changed them out for NF-A15 HS-PWM chromax.Black.swap to eliminate the brown fans.
I already have the two fans, but as mentioned cannot use the rear fan (which is actually the one closest to the front of the case) in push because of my RAM height. Consequently that fan is currently in at the front of the D15 in pull.
My thoughts were that I could replace the NF-A15 with a NF-F12 PWM chromax.black.swap which has the same RPM characteristics as the NF-A15, but would fit above the RAM in a push configuration.
RodeoGeorge
wa3pnt is offline
post #4 of 6 (permalink) Old 08-18-2019, 06:27 PM
Lexi is Dumb's Avatar
Rep: 35 (Unique: 27)
You absolutely can. I did. Is it worth doing? No. Does it look 10x better than just having no fan there? yes.
Panthera
(14 items)
Ryzen 7 3700X
Aorus X570 Pro Wifi
MSI Gaming X Trio RTX 2080
G.Skill Trident Z 16GB 3200Mhz CL14
1TB Samsung 860 Evo
Corsair HX750 Platinum
Noctua NH-D15 w/Chromax
NZXT H700
Acer XB271HU [email protected] Gsync
Samsung LU32H850 [email protected] Freesync
Keyboard
Coolermaster Pro S TKL
Mouse
Logitech G703
Audio
M50X & M50Xbt
Audio
Edifier S880DB
Lexi is Dumb is offline
post #5 of 6 (permalink) Old 08-19-2019, 02:37 AM
Linux Lobbyist
Rep: 1 (Unique: 1)
It's not worth having more than the one single fan in the middle, unless you just have to have another one there due to aesthetics.
Dogzilla07 is offline
post #6 of 6 (permalink) Old 08-19-2019, 03:41 AM
doyll's Avatar
Rep: 1660 (Unique: 923)
As already said, it's not worth the effort. If you have 171mm CPU clearance and 52mm center CPU to RAM you could use a Thermalright TRUE Spirit 140 Power instead of D15 and have as good or better cooling with slightly less noise. Another option is Le Grand Macho which only needs 48mm center CPU towards RAM and cools as good or better than D15 with a little less noise. TRUE Spirit 140 Power is about $50 and LGM RT is about $80.
doyll is offline
