Should i switch to Normal noctua fans? Positive pressure and quietness - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 08-21-2019, 04:58 PM - Thread Starter
Synoxia's Avatar
Rep: 10 (Unique: 8)
I am trying to improve both my air cooling performance and quietness.
Fan config is x2 intake industrial 2000 noctua, x2 D15 chromax, x1 exhaust industrial 2000.
I want to achieve positive pressure case by raising intake fan speed. However i noticed that after 1200 rpm industrial motor whines and is audible compared to chromax which is silent until 1400rpm.
Should i replace those industrial 2000 on front with somethimg else? Im never gonna run them at 2000 unless > 75c which means never.
I also thought i could remove 1 noctua chromax from the d15 and use it as intake on the top... but i think that would sacrifice too much cooling performance... no?
Any ideas? The case is a phanteks enthoo pro M temoered glass with stock air filters (i only removed the one on top)
Tryndamere
(14 items)
AMD Ryzen 3700x
Asus C7H Hero Wifi
RTX 2080 SUPER
G-Skill Tridentz 32gb 3800 16-16-16-16-40-56-336 1t GDM on
HGST enterprise 7200rpm 3tb
EVGA G3 Gold 750w
Noctua D15
Phanteks Enthoo pro TG
Operating System
Win 10 REVI 1909 R4 64bit
Asus XG279Q 170hz
Keyboard
RantoPad mxx Gateron Brown
Mouse
Logitech G Pro Wireless
Mousepad
Artisan ZERO Fx small
Audio
JBL LSR 305
Synoxia is offline
post #2 of 20 (permalink) Old 08-21-2019, 05:18 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1457 (Unique: 734)
try it and see, would take all of .... 15 minutes?
I run my iPPC 3000 at a fixed 600 until 70c (then 800 until 80c and 1200 at 90c) on my radiator and they're silent and do a good enough job as my only intakes. If you need to run yours at 1200 to get good enough performance then it sounds like you have other issues than fan choice.
Regardless, I've been happy with my Phanteks F140XP, I'm using 4 @ 600-1000 RPM as exhaust and they're plenty quiet. Maybe look into those (or the MP if they're going on a radiator).
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is online now
post #3 of 20 (permalink) Old 08-21-2019, 05:25 PM
Rocklin is offline
post #4 of 20 (permalink) Old 08-22-2019, 04:58 AM - Thread Starter
Synoxia's Avatar
Rep: 10 (Unique: 8)
I run my iPPC 3000 at a fixed 600 RPM (until 70c) on my radiator and they're silent and do a good enough job as my only intakes. If you need to run yours at 1200 to get good enough performance then it sounds like you have other issues than fan choice.
Regardless, I've been happy with my Phanteks F140XP, I'm using 4 @ 1000 RPM as exhaust and they're plenty quiet. Maybe look into those (or the MP if they're going on a radiator).
ryzen 3000 scales with temp, i mtrying to get the most cooling out without too much noise
Tryndamere
(14 items)
AMD Ryzen 3700x
Asus C7H Hero Wifi
RTX 2080 SUPER
EVGA G3 Gold 750w
Noctua D15
Operating System
Asus XG279Q 170hz
Keyboard
Mouse
Mousepad
Audio
JBL LSR 305
Synoxia is offline
post #5 of 20 (permalink) Old 08-22-2019, 05:18 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
First off, if you run the two intakes and single exhaust at the same speed, you already have positive pressure.
Second, I'm going to throw a curveball at you......go dig out those F140MP fans that came with your case (provided it came with the MP style, and isn't an older case that came with the SP) and try them as intakes. In the lower rpm ranges that you are going for they move more air with less noise in this application than the Noctuas that you replaced them with.
ciarlatano is offline
post #6 of 20 (permalink) Old 08-22-2019, 05:32 AM - Thread Starter
Synoxia's Avatar
Rep: 10 (Unique: 8)
Damn. I already throw them in the bin unfortunately (the mp)... which fan you recommend buying then? P.S I use the provided dust filter... shouldn't static pressure fan be better for this?
Also, there are 2 intakes and 1 exhaust but didn't you count the D15 fans?
Tryndamere
(14 items)
AMD Ryzen 3700x
Asus C7H Hero Wifi
RTX 2080 SUPER
EVGA G3 Gold 750w
Noctua D15
Operating System
Asus XG279Q 170hz
Keyboard
Mouse
Mousepad
Audio
JBL LSR 305
Synoxia is offline
post #7 of 20 (permalink) Old 08-22-2019, 06:07 AM
doyll's Avatar
Rep: 1702 (Unique: 941)
What carlatano said above.
No, the D15 fans are flowing air through cooler inside of case, not flowing air into / out of case.
Using only case intake fans instead of intake and exhaust is like running a cooler with only middle or from fan (depending on cooler) instead of front and back/middle fans. Difference is only a degree or 2 higher with single fan at same speed, but noise level is lower with single fan. If we speed up fan to same noise level as 2x fans made the cooling is basically the same.
Most all of my build have no exhaust fans, just good front intakes and maybe a bottom intake with all PCIe back slot covers removed. Removing PCie slot covers increases rear vent area around GPU dramatically and thus improves airflow back and out of case around GPU. Ths gives us lower CPU and GPU temps becuase the GPU's heated exhaust is more likely moved back and out thru PCie open slots.
doyll is offline
post #8 of 20 (permalink) Old 08-22-2019, 06:14 AM
ciarlatano's Avatar
You aren't really understanding how static pressure ratings matter (or don't, as the case may be) in actual application. For example, you are probably assuming that your IPPC 2000 fans have higher static pressure than your Chromax. They do at max speed, but that is only because they spin faster. At the same speed they have the same same pressure because they are the same fan blade and housing. So, when you are looking at these static pressure ratings for max speed, they mean little to nothing in terms of real world usage, unless your real world involves running all of your fans at max speed at all times. The important measurement of a fan's SP and AF performance comes from a PQ Curve (https://www.nidec.com/en-NA/technolo...sary/000/0630/) which shows the relationship between AF and SP throughout a fans usable range.
No, you would not count the fans on the D15 as they are neither intake or exhaust.
post #9 of 20 (permalink) Old 08-22-2019, 06:28 AM
doyll's Avatar
What ciarlatano said.
PH-F140MP (same impeller as newer Phanteks case fans) are very good case fans with good static pressure and airflow in the speed range (400-1100rpm) most of us run our case fans. There are better fans (be quiet! Silent Wings 3) but they case 2-3 times more for maginal improvement.
doyll is offline
post #10 of 20 (permalink) Old 08-22-2019, 09:13 AM
Technodox's Avatar
Rep: 5 (Unique: 4)
I had thos 140MP's static pressure fans with the wider fins, they sound very bad, the air flow XP's are way better. The difference is a whir like a propeller starting.
Technodox is offline
