THERMALRIGHT Assassin Spirit 120 [plus] - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 08-22-2019, 03:28 PM - Thread Starter
Heuchler's Avatar
Rep: 269 (Unique: 190)
4x 6mm HDT heatpipes tower cooler - Assassin Spirit 120 single fan [plus dual fan version]
mid-July. Name: Assassin spirit 120. Single fan version: 129 yuan. Dual fan PLUS version: 169 yuan
https://www.chiphell.com/thread-2017645-1-1.html
http://thermalright-china.com/product/as120/
THERMALRIGHT Assassin Spirit 120 Plus
http://thermalright-china.com/product/as120plus/
Name:	THERMALRIGHT Assassin Spirit 120 HDT.jpg
Name:	THERMALRIGHT Assassin Spirit 120 PLUS.jpg
Overclocking History (Click to show)
Intel 386DX/16 @ 20 MHz
CX486SLC/50 @ 50 MHz
AM486DX2/80 @ 100 MHz
AM486 DX4-100 @ 120 MHz
AK5x86-P75 [email protected] 160 MHz
Pentium 90 @ 120 Mhz
IBM 6x86L P166+ [email protected] 160 MHz
Celeron 300a @ 454 MHz
Pentium 3 700 @ 933 MHz
Athlon XP 1400+ @ 1600 MHz
Athlon XP 1800+ @ 2088 MHz
Athlon XP 2500+ @ 2200 MHz
Athlon 64 3000+ @ 2603 MHz
Athlon X2 BE2300 @ 1900 MHz
Athlon X2 4200+ @ 2210 MHz
Athlon X2 5000+ @ 2600 MHz
Core 2 Duo E4300 @ 3000 MHz
Core 2 Duo E6750 @ 3600 MHz
Core 2 Duo E8400 @ 4000 MHz
Xeon C2Q L5408 @ 3200 MHz
Xeon C2Q X5450 @ 3300 MHz
Xeon C2Q E5440 @ 3400 MHz
Xeon C2Q E5450 @ 3600 MHz
Phenom2 X4 B50 @ 3700 MHz
Phenom2 X6 1045T @ 4050 MHz
Core i5-2500K Sandy @ 4500 MHz
X5650 6-Core Westmere @ 3982 MHz
AMD FX 8320E Black Edition
FX-8320E @4.5GHz, X5650 @ 4.0GHz, X6 1045T @4.0GHz, i7 [email protected]
Thinkpad T420p with i7-2720QM overclocked because this is OCN
Heuchler is offline
post #2 of 18 (permalink) Old 08-24-2019, 05:56 AM
doyll's Avatar
Rep: 1660 (Unique: 923)
Had not seen Assassin Spirit 120 and Assassin Spirit 120 Plus before. I like the look of new fan. The base is interesting in that heatpipes are plated except on base.
Thermalright now seems to be working at least 3 different markets;China (Asia), Europe (maybe old USSR countries separte as well) and Americas. Each area sees some product difference if only in how they name it.
Their changes in fan clips is long overdue. While their old clips did work okay once cliped, they were not simple to clip. Anyone installing a cooler with the old clips should practice installing the fan on cooler before installing cooler to figure out how to do it.
doyll is offline
post #3 of 18 (permalink) Old 08-24-2019, 08:05 AM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
This probably wouldn't be a good buy over say a Scythe Kotetsu Mark II which happens to be ~155mm height as well and € 30.
Ultimately I think Thermalright is aiming at bit too low a pricepoint as there's already the True Spirit 120 Direct. $30ish is already low, if they're aiming for $20 it's a losing battle.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #4 of 18 (permalink) Old 08-24-2019, 11:10 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 403 (Unique: 271)
Isn't the Kotetsu a rather bad performer? I thought I had recalled that, and in the couple of reviews I pulled up it was pretty bad.
ciarlatano is offline
post #5 of 18 (permalink) Old 08-24-2019, 11:25 AM
⤷ αC
AlphaC's Avatar
Well in Toms HW USA it did poorly on their HEDT chip (it's a 4 heatpipe cooler with a 1200RPM 120mm fan) but over on computerbase , hwinfo NL, and Techtesters it did okay
https://www.computerbase.de/2017-12/...-oc-1200-u-min
https://nl.hardware.info/grafiek/19?...s%5B%5D=421773
http://www.mod-your-case.de/index.ph...howposts2-1721
https://www.techtesters.eu/scythe-ko...en-tuf-review/
The original Kotetsu was highly recommended by SilentPCReview for non-overclocked mainstream socket systems.
AlphaC is offline
post #6 of 18 (permalink) Old 08-24-2019, 12:45 PM
ciarlatano's Avatar
Ok, but given TR's track record, why are you assuming it won't be a better performer before we've seen any test results?
post #7 of 18 (permalink) Old 08-24-2019, 12:59 PM
Overclocker
JackCY's Avatar
Rep: 338 (Unique: 240)
That's a no on the area of heatpipes, 4x6mm is weak and the base is another no with such spaced heatpipes.
5x6mm or 6x6mm heatpipes that are direct contact with no aluminum gaps, thanks. On 140mm this changes into 8mm heatpipes at best.
Fan...? Looks like their Chinese division got a hold of Noctua's manufacturer lol.
JackCY is offline
post #8 of 18 (permalink) Old 08-24-2019, 07:58 PM - Thread Starter
Heuchler's Avatar
$18 for the single fan version [$24 for the dual] MSRP doesn't sound too bad.
Hyper 212 RGB Black Edition $53
w
h
a
t
Heuchler is offline
post #9 of 18 (permalink) Old 08-25-2019, 05:25 AM
doyll's Avatar
w
h
a
t
Where are you getting this MSRP pricing? I ask because it sound too low to be true.
doyll is offline
post #10 of 18 (permalink) Old 08-25-2019, 08:00 AM
ciarlatano's Avatar
https://ru.gecid.com/news/kuler_ther...irit_120_plus/
