Weirdest cooler I've ever seen in my life - Page 2 - Overclock.net - An Overclocking Community
post #11 of 29 (permalink) Old 08-25-2019, 07:46 AM
Cinderblocks's Avatar
Rep: 6 (Unique: 4)
It's not the "less airflow the better", just that NoFan needs it less. Also it benefits less from more airflow.
I don't know. Some guy.
Cinderblocks is offline
post #12 of 29 (permalink) Old 08-25-2019, 09:02 AM
doyll's Avatar
Rep: 1661 (Unique: 924)
Quote: Originally Posted by Smanci View Post
Case ventilation naturally affects both kinds of coolers but has more obvious effect on regular towers with more dense fin spacing. Relative to those heatsinks, CR80 does the better the less active ventilation there is. Effective convection occurs also regardless of orientation.
Based on what you think or based on actual data you can post here or at least post links to? Just because you think something does not make it fact.
Effective convection yes, but all air coolers need some airflow. Reasoning is simple logic; coolers radiate heat from cooler to air, and if that air does not move away from cooler to allow more cool air to reach cooler the air heats up .. meaning that hotter air does not absorb as much and eventually no more heat at all.
This all means there has to be airflow and if no fans are being used then it has to be the result of warmed / expanded / less dense air rising away from cooler allowing cool air to flow in and take it's place.
doyll is offline
post #13 of 29 (permalink) Old 08-25-2019, 12:17 PM
new to OCN?
PontiacGTX's Avatar
Rep: 1542 (Unique: 926)
if you wanted passive cooling raijinek tisis is much than enough and probably as good as high end cpu coolers when using fans
https://www.newegg.ca/p/13C-001T-00015
PontiacGTX is offline
post #14 of 29 (permalink) Old 08-25-2019, 02:20 PM
doyll's Avatar
I suspect case airflow effects both equally .. assuming both are removing same amount of heat from CPU to transfer into that airflow.
Quote: Originally Posted by Owterspace View Post
That’s the first time I’ve heard someone say the less caseflow the better. I haven’t used the cooler, so not too sure what to say about that, other than it seems a bit backwards. I have only seen better results with moving air, like everyone else.
More airflow is only better up to point that air flowing through fins (rods on Nofan) is same temp as room. Any faster airflow is wasted.
But keep in mind faster airflow tends to also be more turbulent, and more turbulent airflow tends to mix cool intake with heated air in the case raising it's temp and thereby supplying warmer air to cooler .. and warmer air means warmer component because numer of degrees warmer the air is into cooler is same number of degrees hotter component will be.
doyll is offline
post #15 of 29 (permalink) Old 08-25-2019, 05:45 PM
Heuchler's Avatar
Rep: 273 (Unique: 192)
Computex 2007 Thermalright HSC-300, HSC-500 and HSC-700 (HTPC) and HSC-100 midi-tower case passive case (side-panels and top are huge arrays of aluminium fins)
Name:  thermalright hsc-100 passive cooling case.jpg
Size:  40.8 KBClick image for larger version
Name:	Thermalright HSC-300, HSC-500 and HSC-700 (HTPC) and one desktop model (HSC-100.jpg
Size:  32.1 KBName:  thermalright-HSC-case-03.jpg
Size:  38.0 KBName:  thermalright-HSC-case-04.jpg
https://www.legitreviews.com/compute...coverage_520/6
http://xtreview.com/addcomment-id-26...ling-case.html
Overclocking History (Click to show)
Intel 386DX/16 @ 20 MHz
CX486SLC/50 @ 50 MHz
AM486DX2/80 @ 100 MHz
AM486 DX4-100 @ 120 MHz
AK5x86-P75 [email protected] 160 MHz
Pentium 90 @ 120 Mhz
IBM 6x86L P166+ [email protected] 160 MHz
Celeron 300a @ 454 MHz
Pentium 3 700 @ 933 MHz
Athlon XP 1400+ @ 1600 MHz
Athlon XP 1800+ @ 2088 MHz
Athlon XP 2500+ @ 2200 MHz
Athlon 64 3000+ @ 2603 MHz
Athlon X2 BE2300 @ 1900 MHz
Athlon X2 4200+ @ 2210 MHz
Athlon X2 5000+ @ 2600 MHz
Core 2 Duo E4300 @ 3000 MHz
Core 2 Duo E6750 @ 3600 MHz
Core 2 Duo E8400 @ 4000 MHz
Xeon C2Q L5408 @ 3200 MHz
Xeon C2Q X5450 @ 3300 MHz
Xeon C2Q E5440 @ 3400 MHz
Xeon C2Q E5450 @ 3600 MHz
Phenom2 X4 B50 @ 3700 MHz
Phenom2 X6 1045T @ 4050 MHz
Core i5-2500K Sandy @ 4500 MHz
X5650 6-Core Westmere @ 3982 MHz
AMD FX 8320E Black Edition
FX-8320E @4.5GHz, X5650 @ 4.0GHz, X6 1045T @4.0GHz, i7 [email protected]
Thinkpad T420p with i7-2720QM overclocked because this is OCN
Heuchler is offline
post #16 of 29 (permalink) Old 08-26-2019, 02:17 AM
Not New to Overclock.net
Ramzinho's Avatar
Rep: 893 (Unique: 611)
@Skylinestar what are the odds this gets posted literally a day after you start the thread
Oh yeah, I'm Back.
Hot Flame (WIP)
(8 items)
AMD R7 3700X
Gigabyte X570 Aorus Pro Wifi
AMD 5700 XT
Crucial P1
Seasonic Focus G
Phanteks Enthoo Evolv X
Operating System
Windows 10 Pro
Acer XR342CKP
Ramzinho is offline
post #17 of 29 (permalink) Old 08-26-2019, 03:21 AM
- Insanity Beckons -
Elrick's Avatar
Rep: 173 (Unique: 89)
https://www.youtube.com/watch?v=rWqs0S-Djfg
He should actually wait for the release of the 65w version of the 3900x series (I certainly am).
Kind of ignorant putting in an over specified CPU on a cooler that actually needs 65w and below, for effective cooling.
Did you see all the dust on his old Asus board, makes me want to hit it with a Dyson (several times) .
Elrick is offline
post #18 of 29 (permalink) Old 08-26-2019, 04:29 AM
doyll's Avatar
I remember those! I Thermalright's owner and I had an extened emailed discussion before/during their development. We had many interesting conversations about cooling.
Zalman TNN 500AF is one that actually made it into production and sales.
https://www.quietpc.com/tnn500af
Sorry, but I hate video reviews. I tried to skim through it for the good stuff .. didn't see any. Lots of babble and very little actual data.
Indeed, or use a current low wattage CPU.
doyll is offline
post #19 of 29 (permalink) Old 08-26-2019, 04:49 AM
News Fiend
ryan92084's Avatar
Cooler is neat and all but my real interest is what is the deal with the nail polish "grease"? Is that bottle mostly empty is or is it really that transparent?
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #20 of 29 (permalink) Old 08-26-2019, 06:56 AM
s1rrah's Avatar
Rep: 627 (Unique: 411)
I'd still hack a giant fan on to it.
s1rrah is offline
