Weirdest cooler I've ever seen in my life - Overclock.net - An Overclocking Community
post #1 of 29 (permalink) Old 08-24-2019, 08:26 PM - Thread Starter
Skylinestar's Avatar
Rep: 3 (Unique: 3)
CR-80EH. Pipes only.
https://www.lazada.com.my/products/n...-s4054182.html
Main Rig
(19 items)
Intel Core i5 6500 @ 4256MHz
ASRock Fatal1ty Z170 Gaming K6
Palit JetStream GTX1070
Corsair Vengeance LPX 2666 DDR4 2x4GB
Crucial M4 128GB SSD
Kingston UV400 480GB SSD
WD Blue 500GB HDD
Optical Drive
LiteOn DVD-RW
Corsair GS700
Noctua NH-U14S
Phanteks PH-F140SP case fan
Noctua NF-P14s Redux 1200 case fan
Fractal Define R5
Operating System
Win10 Education Edition 64-bit
Dell S2716DG
Keyboard
Microsoft Internet Keyboard
Mouse
SteelSeries Rival 100
Mouse
SteelSeries QcK mini
Audio
HiVi Swan M50W
Skylinestar is offline
post #2 of 29 (permalink) Old 08-24-2019, 08:38 PM
tindolos's Avatar
Rep: 93 (Unique: 81)
That's pretty wild indeed. I think it's kind of funny they put 0dB
Current Rig
(12 items)
i7 7700K @ 5.0 Ghz
MSI Z720 Gaming Pro Carbon
Gigabyte GTX 1070 8GB WINDFORCE OC
G.SKILL TridentZ RGB DDR4 16 GB @ 3200
Samsung 970 Pro NVMe M.2 512GB
Samsung 840 EVO SSD 250GB
Corsair RM850i
Noctua NH-D15S
Fractal Define XL
Operating System
Windows 10
Keyboard
SteelSeries Apex M750
Mouse
SteelSeries Rival 310
tindolos is offline
post #3 of 29 (permalink) Old 08-24-2019, 08:59 PM
polar's Avatar
Rep: 41 (Unique: 34)
70 bucks on Ebay.
I like it, love the soldering of the rods to base. Would be cool if each rod was a heat pipe.
3700x & H80iv2
Gigabyte x570 Gaming X F3 Bios
4x8 Team Dark 3200 14-14-14-31
Gigabyte 2070 OC
860 Evo 500 SSD m.2
Evga G3 850
Matrixx 70
polar is offline
post #4 of 29 (permalink) Old 08-24-2019, 09:21 PM
Kill Confirmed
speed_demon's Avatar
Rep: 78 (Unique: 65)
Yep, looks pretty wild. Was thinking the rods were heat pipes and that would be a novel idea in itself.
speed_demon is online now
post #5 of 29 (permalink) Old 08-24-2019, 11:23 PM
Heuchler's Avatar
Rep: 273 (Unique: 192)
Huge Fan
Overclocking History (Click to show)
Intel 386DX/16 @ 20 MHz
CX486SLC/50 @ 50 MHz
AM486DX2/80 @ 100 MHz
AM486 DX4-100 @ 120 MHz
AK5x86-P75 [email protected] 160 MHz
Pentium 90 @ 120 Mhz
IBM 6x86L P166+ [email protected] 160 MHz
Celeron 300a @ 454 MHz
Pentium 3 700 @ 933 MHz
Athlon XP 1400+ @ 1600 MHz
Athlon XP 1800+ @ 2088 MHz
Athlon XP 2500+ @ 2200 MHz
Athlon 64 3000+ @ 2603 MHz
Athlon X2 BE2300 @ 1900 MHz
Athlon X2 4200+ @ 2210 MHz
Athlon X2 5000+ @ 2600 MHz
Core 2 Duo E4300 @ 3000 MHz
Core 2 Duo E6750 @ 3600 MHz
Core 2 Duo E8400 @ 4000 MHz
Xeon C2Q L5408 @ 3200 MHz
Xeon C2Q X5450 @ 3300 MHz
Xeon C2Q E5440 @ 3400 MHz
Xeon C2Q E5450 @ 3600 MHz
Phenom2 X4 B50 @ 3700 MHz
Phenom2 X6 1045T @ 4050 MHz
Core i5-2500K Sandy @ 4500 MHz
X5650 6-Core Westmere @ 3982 MHz
AMD FX 8320E Black Edition
FX-8320E @4.5GHz, X5650 @ 4.0GHz, X6 1045T @4.0GHz, i7 [email protected]
Thinkpad T420p with i7-2720QM overclocked because this is OCN
Heuchler is offline
post #6 of 29 (permalink) Old 08-25-2019, 03:28 AM
doyll's Avatar
Rep: 1661 (Unique: 924)
'No Fan' has been around for long, long time.
Honestly it's a waste of money because a good cooler like Thermalright Macho 140 or Scythe Mugen with fan at low speed will cool better .. and unless you put your ear so close to fan it mght get hit by fan blades you won't be able to hear it anyway.
Or get Macho 0 and a shroud to rear exhaust vent. If case does not have any case fans it will get progressively hotter and hotter, so we have to have case fans anyway, so what is the deal with having no fan on cooler? Case fans move cool air in case. Obviously the same amount of heated air has to be leaving case (simple physics principle of amount in must equal amount out).
doyll is offline
post #7 of 29 (permalink) Old 08-25-2019, 04:34 AM
Smanci's Avatar
Rep: 75 (Unique: 64)
I have one. Not outright waste of money as it's tiny - just 113mm high and 155mm wide - and fits in very cramped spaces.
If it didn't take so much time, I'd test it against a passive Macho Rev. B on an 8400. It is clear that the CR80 loses in that comparison, the question is just by how much.
Smanci is offline
post #8 of 29 (permalink) Old 08-25-2019, 05:29 AM
doyll's Avatar
No idea which Nofan cooler you have, but Nofan CR-100A is 220mm in diameter and 132mm high. That is about 70mm wider than widest cooler I know of and will definitely not clear PCIe sockets on many motherboards or clear any but very short RAM. CR-100A is not able to keep up with 140mm fanned Macho coolers with fan at idle or in a normal tower case using duct from cooler to rear exhaust. Obviously CR-100C is 180x160mm and CR-95C is 180x148mm .. don't know what model your is as it's not listed in their current catalogue.
All depends on how much airflow case has. Less case airflow and temps will be much higher then with more case airflow.
Your case appears better designed for passive because it shape is like a small chimeny drawing cool air in bottom as as it warms it rises and goes out the top. Most cases do not do this very well at all. What case is it?
The importnat thing is you are happy with your cooler in your system. That's all that matters.
doyll is offline
post #9 of 29 (permalink) Old 08-25-2019, 06:03 AM
Smanci's Avatar
Case ventilation naturally affects both kinds of coolers but has more obvious effect on regular towers with more dense fin spacing. Relative to those heatsinks, CR80 does the better the less active ventilation there is. Effective convection occurs also regardless of orientation.
Smanci is offline
post #10 of 29 (permalink) Old 08-25-2019, 06:42 AM
Fix it till its broke
Owterspace's Avatar
Rep: 2 (Unique: 2)
That’s the first time I’ve heard someone say the less caseflow the better. I haven’t used the cooler, so not too sure what to say about that, other than it seems a bit backwards. I have only seen better results with moving air, like everyone else.
3770K @ 4700 1.375v/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/8GB G.Skill BBSE @ 1066 9-9-9-24 2T 1.65v
EVGA GTX 980 Classified @ 1480/2000/Asus Xonar Essence ST
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG/6x 120x38 @ 7v-12v/CM Silent Pro M2 850
Owterspace is offline
