Noctua NH-U12A to 15s or AIO - Overclock.net - An Overclocking Community
post #1 of 33 (permalink) Old 09-10-2019, 07:24 PM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Howdy there,
I'm trying to get my 9900k stable at prime 95 small fft but fail to do so with the 12A, I'm pegging 100 degrees and already lifted the TJmax up to 105 which I didn't feel safe about and set it back to the regular 100.
Are there any coolers out there that would give me another bump in cooling performance like 10 degrees?
I've seen reviews where the D15 is actually en par with the 12A but nothing with the 9900k, everybody is using these stupid ass old CPUs to test it with.
I think that's the only high wattage test I've seen so far but why are the small AIOs better than the 150i pro for example, it doesn't make sense !!!!
https://www.overclock.net/forum/atta...294654&thumb=1
Melodist is offline
post #2 of 33 (permalink) Old 09-10-2019, 07:39 PM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Found one more indicative benchmark
https://www.overclock.net/forum/atta...294658&thumb=1
Melodist is offline
post #3 of 33 (permalink) Old 09-10-2019, 07:40 PM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
What I'm trying to cover is about 235 watts under 100 degrees.
Melodist is offline
post #4 of 33 (permalink) Old 09-10-2019, 08:35 PM
NewType88's Avatar
Rep: 1 (Unique: 1)
What’s your case and fan setup ?
NewType88 is offline
post #5 of 33 (permalink) Old 09-11-2019, 04:20 AM
doyll's Avatar
Rep: 1661 (Unique: 924)
As NewType88 asked, what is your case and case fan setup? How long does it take from starting a 100% load test for CPU to reach maximum temp? What is the actual air temp into cooler during stress test vs temp of room air entering case?
You might find link below to how airflow works and how to optimize case airflow of interest:
https://www.overclock.net/forum/22319249-post5.html
doyll is offline
post #6 of 33 (permalink) Old 09-13-2019, 07:41 PM
poah's Avatar
Rep: 4 (Unique: 3)
remember that prime 95 is an unrealistic load on the CPU. when gaming the temp will be considerably lower and applications such as blender will be a bit lower. a big air cooler like the nh-D15s or an large 280/360 aio will cool the chip assuming you are not using stupidly high voltage.
poah is offline
post #7 of 33 (permalink) Old 09-14-2019, 04:59 AM
Fix it till its broke
Owterspace's Avatar
Rep: 2 (Unique: 2)
Remember, your pc should be able to run anything, realistic or not. If it cant, your overclock is fake because you cant sustain it under all conditions. Real or not. Same goes for negative AVX offsets
Its difficult to have the highest performance in a quiet machine. Concessions will have to be made.
Just sayin.
3770K @ 4400 MHz 1.215v(Dynamic)/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/12GB G.Skill Mix @ 1866MHz 9-10-9-24 2T 1.6v
EVGA GTX 980 Classified @ 1480/2000MHz 1.212v
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG/CM Silent Pro M2 850
Owterspace is online now
post #8 of 33 (permalink) Old 09-14-2019, 05:43 AM
Never Finished
airisom2's Avatar
Rep: 268 (Unique: 206)
All air coolers struggle with taming an overclocked 9900K. Some flagship air coolers should get you into high 80s mid 90s with a 5ghz overclock on p95, but case airflow will be a big factor in that. If you want lower temps, you can lower clocks. Knocking it down to 4.8 should give you much better temps and increase the life of your chip.
1680 V2 4.5GHz 1.33v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Rosewill Rise | Thermalright LGM RT
Logitech G600 | G440 | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Passive Preamp | Emotiva BasX A-100
OCZ Vertex 4 256GB | 51TB DAS | SS Prime Ultra Titanium 1KW
airisom2 is offline
post #9 of 33 (permalink) Old 09-14-2019, 06:51 AM
doyll's Avatar
Please ignore post 7. Running CPU at 100% with some dedicated stress test means little to nothing. What is important is your CPU will run everything you use at reasonable temps and doesn't crash.
The only time dedicated stress testing means anything is if you are posting that OC as some sort of score in some sort of competition.
doyll is offline
post #10 of 33 (permalink) Old 09-14-2019, 07:11 AM
Owterspace's Avatar
Rep: 2 (Unique: 2)
No need to ignore my post. My reply was in response to poah. And its true, if it cant run everything you throw at it without throttling, or using an AVX offset, then its not a stable overclock. Hence, concessions will be made. Stable means flat, doesn't move, level.. using an offset to drop clocks is not keeping a level clock. Maybe its just crazy talk on my end, but it makes sense to me. Of course stable means not crashing too.. but do you see where I'm going with this?
