Overclocked ram gets hot? - Overclock.net - An Overclocking Community
post #1 of 51 (permalink) Old 09-12-2019, 04:55 PM - Thread Starter
Synoxia's Avatar
Rep: 8 (Unique: 6)
Is there something wrong with my config or the dimm heatsink? (1 stick have like 1cm clearance at best, but still not touching D15 fan).
DIMMS are 3600 c16-17-17-18 1.35v, i run them at 3800 c15-16-17-15-30-45 1.46v.
I am 12000 sec stable under google stress test but while gaming rams get into 51 celsius and thus crashing the game.
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
G-Skill Tridentz OC 16 gb 3800 c14-16-17-16-32-48
EVGA G3 Gold
Noctua D15
Phanteks Enthoo pro TG
Operating System
Win 10 1903 build 18950 64bit
Viewsonic XG2401
Keyboard
Fnatic RGB Cherry mx brown
Mouse
Logitech G Pro Wireless 950 dpi
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
post #2 of 51 (permalink) Old 09-12-2019, 05:00 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1248 (Unique: 682)
the more aggressive your RAM OC is the more sensitive it'll be to temp. either back off the OC or get better airflow. I'm at 1.5v and generally I'm 40-45c.
plus 12000 seconds doesn't mean you're stable. I've failed after the 8 hour mark plenty of times.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 51 (permalink) Old 09-12-2019, 05:01 PM - Thread Starter
Synoxia's Avatar
Rep: 8 (Unique: 6)
Yes i know, thats why i am asking if there's something wrong with my airflow/dimm heatsink. I've updated the thread with case photo.
With GSAT? or HCI?
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
post #4 of 51 (permalink) Old 09-12-2019, 05:05 PM
Avid Something-or-Other
shellashock's Avatar
Rep: 5 (Unique: 5)
Have you tested the air temp near the RAM during gaming vs during ram stress tests? I wouldn't be surprised if the Vega 64 is exhausting a bunch of hot air into your case during gaming and it is rising the memory temps high enough to destabilize your setup.
As a quick test, try taking the tempered glass side panel off your case during gaming and see if you are still getting crashes/your RAM still hits 51C. Alternatively you can try putting a fan over the memory to get some airflow on them and see how that affects their temp.
Overclocked DDR4 can easily reach 40-50C when you start pushing 1.45V+ if there is insufficient airflow. This won't physically damage the chips, but it can corrupt your data if your memory is unstable at that temperature. Highly recommend you make a backup to limit data loss.
shellashock is offline
post #5 of 51 (permalink) Old 09-12-2019, 05:13 PM - Thread Starter
Synoxia's Avatar
Rep: 8 (Unique: 6)
I have a spare 92mm fan. What if i put it on top? Could it make a difference in ram temps? I run at capped fps actually... my vega barely hits 65c and i dont have fan spinning that much. Like 45% at 69c but usually doesn't reach that...
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
post #6 of 51 (permalink) Old 09-12-2019, 05:20 PM
Stock is too casual~
Veii's Avatar
Rep: 22 (Unique: 19)
You could reverse airflow
Top and back Intake to cool VRMs and Rams - and front as exhaust
but it will get dust from the back
Looking at that setup, you would have to rotate the Cooler Fans too
- else yes, a fan at the top helps ram a lot
Every tiny bit of airflow helps transport heat out of this dimms heating up by the cpu and gpu nearby
If you are too lazy, slow down front intakes, and put some slow rpm top intake (over the rams)
oor speed up front intakes and put a slow (450-600rpm) top exhaust (closer to the back exhaust)
I would rotate that airflow tbh to cool VRMs , and RAM unless you have strong enough top exhaust fans ~ but that's just me
Personal Records
SiSandra Inter-Core Bandwith 14nm Ryzen global #1
RAM > Viper Steel @ 3466C14 (64.2ns) & Alt | Hynix-MFR 3333CL14 (72.5ns) & Alt
GPU > Gigabyte 970 G1 @ 1595|1900 (Hynix) | RX 580 Red Devil GS @ 1620|2200 (Micron)
CPU > TR 1950X [email protected]1.2v & [email protected]1.365v[105Mhz FSB](3.23Beta)
#Main: 1700X [email protected]1.365v1.73Ghz IMC CL14 (64.2ns)」+ Dark Rock 3 | X370 Taichi 1.0.0.3 ABBA by The Stilt | Viper Steel [PVS416G400C9K]| Gigabyte 970 G1 | Samsung 850 Evo
Veii is offline
post #7 of 51 (permalink) Old 09-12-2019, 05:59 PM
skupples's Avatar
Rep: 630 (Unique: 342)
yes
more volts, more clocks, more work, more heat.
just try to move more air over them.
skupples is offline
post #8 of 51 (permalink) Old 09-12-2019, 07:01 PM - Thread Starter
Synoxia's Avatar
Rep: 8 (Unique: 6)
NVM in the end i've just put silent wings 2 on top of the 2 industrial ppc on the front, probably not going to make a difference anyway but whatever... the only "aesthetically acceptable" solution would be switching to a case with better airflow.
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
post #9 of 51 (permalink) Old 09-12-2019, 08:39 PM
skupples's Avatar
good thing looks don't lower FPS and only you see it
skupples is offline
post #10 of 51 (permalink) Old 09-12-2019, 09:59 PM
BS Zalman's Avatar
Rep: 0
That means your Memory OC is not stable. As far as i know 51 C is still far from the maximum temperature DDR4 can handle, i heard/read DDR4 can take more than 90 C just fine.
I found in my experience that TestMem5 is very good at hunting the memory instability, but dont use the default profile. Use 1usmus_v3 profile, and if you want to be sure change to run for 10 or more cycle.
And if you OC the Infinity Fabric (3800) you must stres test the whole system too, since mem test application only stress the memory part. Use Real Bench, 3D Mark, blender, X264 stress test that use real workload.
Gaming is a good indicator too, if you found stuttering and crashing while gaming with OC setting meanwhile in a default setting you never found one, that means your system is not fully stable
BS Zalman is offline
