3-5 degrees higher Temps due to scratched surface? - Overclock.net - An Overclocking Community
post #1 of 42 (permalink) Old 09-13-2019, 10:05 AM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Hi there,
I've re-attached my Noctua NH-U12a 3 times due to trying out several other new coolers and realized a temperature rise of 3-5 degrees celsius compared to the first application, even though I've re-seated the cooler again to make sure it wasn't a bad thermal paste application.
Before installing the cooler again, I've noticed scratches from the edges of the processor and a dent of the surface area (very small).
Could this lead to higher temps compared to my first application?
Melodist is offline
post #2 of 42 (permalink) Old 09-13-2019, 10:15 AM
Avid Something-or-Other
shellashock's Avatar
Rep: 4 (Unique: 4)
Just to make sure, ambient temperature in your room and/or case has not changed in between each test? It is common to see air temperature increase in the case/room during stress testing (especially over long periods of time with power hungry loads like linpack/P95) and this can confuse you if you do not record the air temperature going into the cooler at the same time you take the CPU core temperature.
shellashock is offline
post #3 of 42 (permalink) Old 09-13-2019, 10:26 AM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Yeah I've tested this thoroughly and the temps are worse from the getgo. Before I was between 89 and 91 package and now I'm at 91 to 94 package.
I've also noticed the IHS has scratches compared to before, even though I've only reinstalled the cooler several times, which might've come from removing the cooler.
Melodist is offline
post #4 of 42 (permalink) Old 09-13-2019, 10:29 AM
HWBot Bencher
Noxinite's Avatar
IMO, those tiny scratches would make a negligible difference in temperatures. Especially as thermal paste is supposed to fill these kinds of imperfections and improve conduction.
DDR2 Frequency 1st Place = 910.1MHz DDR (1820.2MHz) - http://hwbot.org/submission/3589779
Reference Frequency 10th Place = 711.18MHz - https://hwbot.org/submission/3978447_
Noxinite is offline
post #5 of 42 (permalink) Old 09-13-2019, 10:41 AM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Probably me from twisting the cooler?
Or could they be existing marks, exposed by using 99.9% Isopropyl several times?
Melodist is offline
post #6 of 42 (permalink) Old 09-13-2019, 11:38 AM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Has maybe the TIM solder cracked or something?
Melodist is offline
post #7 of 42 (permalink) Old 09-13-2019, 11:45 AM
skupples's Avatar
Rep: 563 (Unique: 321)
that seems unlikely, but if you're searching for reasons to delid
I don't see anything anywhere worthy of changing temps even 1c tbh. Did you bork the cooler? Is only one fan coming on? no fans coming on?
skupples is offline
post #8 of 42 (permalink) Old 09-13-2019, 11:51 AM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
No no, everything is the same, exactly the same, that's why it is so odd, the cooler, compared to before, obviously has tons of scratches now on the surface, I guess that may be the cause?
That's before
https://www.overclock.net/forum/atta...295348&thumb=1
and that's after
https://www.overclock.net/forum/atta...295350&thumb=1
Could too much thermal paste cause this?
Name:	without avx offset.jpg
Melodist is offline
post #9 of 42 (permalink) Old 09-13-2019, 11:57 AM
skupples's Avatar
i use a scotch bright pad all the time on my coolers & cpus. no difference in temps.
delid time.
skupples is offline
post #10 of 42 (permalink) Old 09-13-2019, 12:09 PM
ntuason's Avatar
Rep: 170 (Unique: 152)
I say cure time is the cause.
i7 980x + CF 6970
(11 items)
Intel® Core™ i9-9900K @ 5.1GHz
ASUS ROG Maximus XI Apex Z390
ASUS ROG Strix GeForce RTX 2080 Ti O11G
G.Skill Trident Z Royal @ 4133MHz CL18
Samsung 970 EVO Plus NVMe - M.2
Samsung SSD 850 EVO
Samsung SSD 850 EVO
Corsair AX1200
NZXT Kraken X72 360mm Push/Pull
Lian Li PC-011 Dynamic
Operating System
Windows 10 Pro 64bit
Samsung CHG70 32" QLED, 1ms 144Hz
Keyboard
Logitech G815 Tactile
Keyboard
Filco Majestouch 2 Cherry MX Red
Keyboard
Logitech G513 Romer-G
Mouse
Logitech G703 Wireless
Mousepad
Logitech G840
Audio
Kanto Yu4 + Kanto SUB8 8-Inch
Audio
Audeze LCD-4
i7 980X 3003B475* @ 4449.1MHz 1.45V (6C-12T)
ASUS Rampage III Extreme - 1208 BIOS
CrossFire Asus EAH6970 945MHz/1450MHz 1180 mV*
6GB Corsair Dominator GT 2009MHz / 7-8-7-20 T1 C7*
RAID 0* OCZ Vertex 3 120GBX2 (OS)+ 4X 2TB WD Green
Seasonic PRIME 600 Titanium
Corsair Obsidian 800D
Operating System
Windows 7 Ultimate 64Bit
Keyboard
Filco Majestouch-2 Cherry MX Red
Mouse
Razor Mamba 4G
Mouse
Steelseries SX
ntuason is offline
