Problem with Dark Rock PRO 4, over 100° - Page 2 - Overclock.net - An Overclocking Community
post #11 of 56 (permalink) Old 09-16-2019, 12:28 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
Quote: Originally Posted by poliacido View Post
zero
anyway i am fine it can happen...someone forgot to peel it off but it's not this case
going to put on again the AIO and i noticed it is also a little convex too, but just on the vertical axis, if it try to move it horizontally it doesn't move
a lot heatsinks/AIOs are intentionally (a tiny bit) convex, the IHS should ideally be as flat as possible.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #12 of 56 (permalink) Old 09-16-2019, 12:33 PM
doyll's Avatar
Rep: 1661 (Unique: 924)
Quote: Originally Posted by The Pook View Post
how many second hand heatsinks do people buy with protective film on them?
All of the coolers I sell after testing are "used" coolers with protective plastic on the base.
doyll is offline
post #13 of 56 (permalink) Old 09-16-2019, 12:38 PM
doyll's Avatar
zero
Just a thought, is case warm/hot to the touch when CPU is hot? If case isn't flowing cool air to cooler and the air entering cooler is 20c warmer than room the CPU will also be 20c hotter than if cooler is receiving air at room temp.
doyll is offline
post #14 of 56 (permalink) Old 09-16-2019, 12:46 PM - Thread Starter
Born to ride
poliacido's Avatar
Rep: 1 (Unique: 1)
the side panel is removed
My PC: - Asus Crosshair VII Hero- 2700X - 2x8 Gskill 3200 cl15- RX 5700XT Pulse - AX760 - Asus PG279Q - Corsair C70 Military Green
poliacido is offline
post #15 of 56 (permalink) Old 09-17-2019, 04:34 AM
doyll's Avatar
While that doesn't mean air going into cooler is room temp, it is probalby not more than 3-8c above room temp. My builds run cooler with side cover on than off.
Can't remember if you have removed, cleaned and re-installed. You said you were going to re-install your CLC. Have you done this and checked the DRP4 seat/print? I'm guessing you probalby have a bad mount/seat wiht DRP4. Maybe mount isn't installed properly, problem has to be heat transfer from CPU to cooler, it's highly unlikely a defective cooler.
doyll is offline
post #16 of 56 (permalink) Old 09-17-2019, 01:02 PM - Thread Starter
Born to ride
poliacido's Avatar
Rep: 1 (Unique: 1)
Ok little update, but no solution:
@doyll : yes i cleaned all and re-installed the cooler 3 times now and like i said the TIM print was perfect from the 1st time i applied it, all screws are tight to the max. I can say the mount mechanism is installed super properly
@The Pook : i put on again the corsair AIO and the temps are back to normal... meanwhile i checked and i can say the cooler is a bit convex but very very minimal (the aio is more covex) and the IHS i can say seems a little little bit concave... but almost impossible to notice. I checked with a flat piece of steel and if i put it to direct light i can see a very very little gap in the middle but like i said almost barely visible..
These photos are from the last try, i put even more paste to see if it made any difference
post #17 of 56 (permalink) Old 09-17-2019, 01:40 PM
9 Cans of Ravioli
The Pook's Avatar
Where are you mounting the AIO? If you're mounting it to the front maybe it's just that the heatsink isn't getting good enough airflow and the AIO up front does? That shouldn't cause a 20C temp difference though.
Past that I really dunno what to tell you, thermal paste spread looks fine and even if the CPU was badly concave/convex temps on both the AIO and heatsink would suck, not just on the heatsink.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #18 of 56 (permalink) Old 09-17-2019, 01:52 PM - Thread Starter
Born to ride
poliacido's Avatar
Rep: 1 (Unique: 1)
The AIO is mounted on top with the fans blowing out the case... the 2 fans you see in the photo are the 2 front intakes in the case
But exactly like you said even with poor/none airflow it should not cause this huge temp difference....
Really I feel like I've been knocking my head against the wall trying to understand what's going on. I reached the guy that sold me the cooler and asked him if he can open a RMA ticket with amazon because it's still under warranty
post #19 of 56 (permalink) Old 09-18-2019, 09:13 AM
doyll's Avatar
Please let us know how it all works out. I'm sure I'm not the only one wondering what the problem is.
doyll is offline
post #20 of 56 (permalink) Old 09-18-2019, 12:40 PM - Thread Starter
Born to ride
poliacido's Avatar
Rep: 1 (Unique: 1)
Ok i think i resolved the problem (if we can say so)....
The guy who sold me the cooler asked amazon to send it back with a RMA and they will refund him the price... so i get back my money and he also get some € back
No chance to get a replacement because it was selled on amazon by a third party seller
At least we get the money back but i still have to buy a new heatsink to replace my AIO but this time i am buying it sold and shipped from amazon so i can just try it for 30 days
