Azza 2000 hurrican 230mm case fans help - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 10-05-2019, 11:04 AM - Thread Starter
Rep: 0
Hello I have an Azza 2000 hurrican case and want to replace the top and side fans that are supposedly listed as 230mm by manufacturers specs. I was wondering if anyone here has successfully found some fans that fit this case and where can I buy them?
InfiernoX is offline
post #2 of 7 (permalink) Old 10-15-2019, 09:16 AM
AyyMD's Avatar
Rep: 6 (Unique: 5)
Can you substitute those fans with a 120/140mm fan, at least? That would be ideal for cooling performance.
AyyMD is offline
post #3 of 7 (permalink) Old 10-16-2019, 04:57 AM
Senior OCN Member
shilka's Avatar
Rep: 2752 (Unique: 1632)
230mm fans have almost zero static pressure so if even the smallest resistance makes the fan move almost no air in or out of the case
You are much better off with a pair of 120mm or 140mm fans instead and thats the reason why there are so few cases out there with 200mm or bigger as the fans of that size are not very good
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #4 of 7 (permalink) Old 10-19-2019, 12:25 AM
TeslaHUN's Avatar
Rep: 20 (Unique: 18)
So tell me , why is Cooler Master Haf X is still one of the best cooling case in market even today ? It has 1x230mm and 2x200mm fan installed.
Also , even a cheap thin (20mm ) 20cm CoolerMaster fan(pathetic 0,88 h2o pressure on max) can flow thourgh a radiator ,wich is more restrictive than a pc case with grill+filter
I made a video a while ago :
TeslaHUN is offline
post #5 of 7 (permalink) Old 10-19-2019, 01:19 AM
Senior OCN Member
shilka's Avatar
The HAF X is not one of the best cooling cases it never was is not and never will be i had one myself and i had 200mm and 230mm fans in it and with drives in the front close to zero air came in the front due to the crappy static pressure
As soon as there is an obstacle or resistance in the case the performance of 200mm+ fans drops like a rock
That is the reason why a smaller but higher static pressure fan is actually better as an intake fan if you have obstacles like drives in the way
Edit: after i ditched the HAF X and moved to a Phanteks Luxe and replaced the front fan (which also was a crappy 200mm fan) i got much better temps with the same hardware and that was due to the Noctua NF-A14 140mm fans having much higer static pressure
You only need to look at the Cooler Master H500P with the plastic front to see what i am talking about
Dual 120mm or 140mm fans are much better than a single 200mm or 230mm fan
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
post #6 of 7 (permalink) Old 10-19-2019, 02:17 AM
TeslaHUN's Avatar
Sorry to dissapoint u , but u are completely wrong
HafX and H500p both are in top5 best cooling case , the king is still Raven RV02 also with big fans (3x180mm)
TeslaHUN is offline
post #7 of 7 (permalink) Old 10-19-2019, 02:19 AM
Senior OCN Member
shilka's Avatar
I said the 500P with plastic front not the newer mesh version
There is a reason why they came out with a mesh version as the old plastic version was one of the worst cases GN ever tested
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
