Decent Budget SP Fan Recommendation. - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 10-21-2019, 07:17 PM - Thread Starter
Hydro Therapist
Fifth Horseman's Avatar
Rep: 22 (Unique: 20)
Looking to get some new SP fans for my radiators. Im looking for 140mm with quality and performance similar to Noctuas but without the massive price tag. I need a total of 16 fans for push/pull so keep that in mind. These radiators are hidden so i could careless about RGB or aesthetics as they will not be seen only heard. PWM will probably never go past 1200 rpms so.
I was looking at the newer Arctic P14 fans. They sell them in a value pack which would keep from breaking the bank.
https://www.amazon.com/ARCTIC-P14-Va.../dp/B07HCKWF2X
CPU: i7-8700k @ 5 GHz
GPU: GTX 1080 Ti Aorus Extreme @ 2,114mhz
RAM: Trident Z RGB 32GB Ddr4-3000
Motherboard: Gigabyte Aorus Z370
Storage: Intel Optane 900p
Cooling: Dual EK Coolstream 560mmm x 45mm, Dual D5 Pumps
Fifth Horseman is offline
post #2 of 13 (permalink) Old 10-21-2019, 07:33 PM
speed_demon's Avatar
Rep: 85 (Unique: 68)
The new P14's are pretty good and are the best bang-for-the-buck that you'll find. They get my vote.
Quis custodiet ipsos custodes?
speed_demon is offline
post #3 of 13 (permalink) Old 10-22-2019, 02:19 AM
TeslaHUN's Avatar
Rep: 20 (Unique: 18)
Arctic P14 without question, topic can be closed
TeslaHUN is offline
post #4 of 13 (permalink) Old 10-22-2019, 02:20 AM
The last VRM burner
Rep: 30 (Unique: 16)
Arctic P14.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is online now
post #5 of 13 (permalink) Old 10-22-2019, 07:49 AM
doyll's Avatar
Rep: 1663 (Unique: 926)
Are you sure you need both push and pull fans on your radiators? Also, when plugging multiple fans into each other like PST can be careful to not overload the header you are plugging them into and/or the fan cable from header. Keep in mind fans draw 3-5 times more load at startup than they do once they get up to speed. This startup load is why almost every fan header and/or fan controller failures occur when system is starting up, not while it's running. A fan rated 0.15A running load is likely drawing something like 0.5A at startup. Below is link to Nidec Servo Gentle Typhoon specs with running and startup loads listed.
http://www.e-jpc.com/pdf/gentle-typh...-catalog-2.pdf
doyll is offline
post #6 of 13 (permalink) Old 10-22-2019, 05:39 PM - Thread Starter
Hydro Therapist
Sounds like i'll be going with the P14's, since they seem to be so recommended.
post #7 of 13 (permalink) Old 10-23-2019, 04:54 AM
doyll's Avatar
Arctic P14 are cheaply built but seem to be okay. That is why peeps recommend them. They are okay fans for very low price but are not as good as top tier fans which cost 2-4 times as much.
I still think push/pull is extreme overkill. The minor improvement for paying thice as much for fans isn't worth it. Increasing push fan speed 100rpm will give similar temps as push/pull. Martin's Liqud Lab did comparison testing of push, pull and push/pull years ago, his conclusiong was:
Not much difference between push and pull (the higher the rpm fan, the less the difference), with push having the slight win. Push/pull is always slightly better. How much variance you get depends mostly on the radiator model
Link to testing and data:
https://martinsliquidlab.wordpress.c...ud-testing-v2/
doyll is offline
post #8 of 13 (permalink) Old 10-23-2019, 04:59 AM
The last VRM burner
You know,
. One among a long list of reviews that show actually same manner.
PC for all
(21 items)
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
post #9 of 13 (permalink) Old 10-23-2019, 05:55 AM
doyll's Avatar
Quote: Originally Posted by BroadPwns View Post
You know, https://www.youtube.com/watch?v=7cGdQi7LqlU&t=290s. One among a long list of reviews that show actually same manner.
Nice bit of testing. Wish I spoke Greman.
doyll is offline
post #10 of 13 (permalink) Old 10-23-2019, 05:58 AM
The last VRM burner
Numbers are universal language . Measures are through radiator.
PC for all
(21 items)
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
