Wraith Prism Thoughts? - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 10-24-2019, 04:08 PM - Thread Starter
RWBY FNDM's Avatar
Rep: 6 (Unique: 4)
Rocking the Wraith Prism. Honestly, it’s good enough, since overclocking isn’t really beneficial for Ryzen 3000. PBO, 1.325V +200 offset, and I’m getting 38c idle, 53-55c gaming, and 77c max load.
RWBY FNDM is offline
post #2 of 4 (permalink) Old 10-25-2019, 10:38 AM
Senior OCN Member
shilka's Avatar
Rep: 2758 (Unique: 1636)
One reason to upgrade is less noise as the Wraith is not the most quiet cooler around
Dumpster fire
(27 items)
Seravee
(19 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
EVGA SuperNova G2 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
LG 24MP59G-P
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mouse
Logitech MX518 Hero
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
shilka is online now
post #3 of 4 (permalink) Old 10-26-2019, 07:35 AM
doyll's Avatar
Rep: 1667 (Unique: 927)
My complaint is this kind of cooler tends to re-use it's own heated exhause because air is blowing down through cooler where it hit's mobo turning out, hitting RAM & GPU turning up along side of cooler and fan where fan pulls it is drawn back into fan. When I tested some stock and low profile flat coolers years ago I found air temp into cooler even on open bench test test station with 140mm fan blowing air over top of motherboard CPU was 8c hotter than if fan was turned over pulling air out of cooler (at same cooler fan speed).
So almost any small tower will cool much better than stock flat coolers do.
doyll is offline
post #4 of 4 (permalink) Old 10-27-2019, 09:04 AM
Rep: 0
It's pretty good for a stock cooler, fan can get annoying unless you tweak the fan curve.
2600ryzen is offline
