Air cooling vs water cooling - Overclock.net - An Overclocking Community
post #1 of 39 (permalink) Old 11-06-2019, 03:33 AM - Thread Starter
Rep: 0
I need a better cpu cooler than my stock one. AM4 compatible (Ryzen 5 2600x, Corsair 275r case, decently low profile RAM).
I've been doing research and I can't decide for the life of me which way too go. The only air coolers anyone every suggests highly are Noctua. Sounds great, but I hate the beige and kind of worry about sag on the Mobo. Water cooling looks cool, but I am worried about messing something up and getting my rig wet. The airflow in my case isn't top notch, and I have a blower GPU, if that would matter one way or another.fedloan irs.gov easybib
What are my best options for $100 or less (prefer less)
NuzakFarnas is offline
post #2 of 39 (permalink) Old 11-06-2019, 03:41 AM
The last VRM burner
Rep: 30 (Unique: 16)
No need to worry about sag at all, if you want Noctuas performance equivalent then go for Raijintek Tisis. You also have a freshly released Arctic Liquid Freezer II that got very nice results from two reviews that exists as to date.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #3 of 39 (permalink) Old 11-06-2019, 03:53 AM
Senior OCN Member
shilka's Avatar
Rep: 2752 (Unique: 1632)
You can buy black Noctua coolers now but the Thermalright True Spirit 140 Power is just as good and way cheaper than the Noctua coolers but its 170mm tall it might not fit in your case
There is room for a 170mm cooler so it might be able to fit or it might not since there is so little space left
As for motherboard sag thats not a thing if its screwed properly in place
This is how the black NH-U12S looks
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #4 of 39 (permalink) Old 11-06-2019, 06:14 AM
doyll's Avatar
Rep: 1664 (Unique: 926)
Corsair says 750R has 170mm CPU clearance and every case I've ever check had a few more mm than spec said. This means case will support TRUE Spirit 140 Power will fit case. All AMD motherboards I've checked have enough room toward PCIe sockets for TS140P while some don't have quite enough for fan on front, but it's not a problem for fan on back of cooler. TRUE Spirit 140 Power costs about $50, leaving you plenty of money for better case fans if needed.
Motherboard sag is not a problem with even the heaviest CPU coolers.
doyll is offline
post #5 of 39 (permalink) Old 11-06-2019, 07:30 AM
StAndrew's Avatar
Rep: 12 (Unique: 8)
Air cooling is hands down the best for the money. The limitation is, your surface area (ie cooling capacity) is limited by the weight / size of the cooler. You can dynamically increase 'surface area' of the air over the cooler with more air flow (poor noise to performance ratio).
Watercooling can increase surface area as far as the case can support radiator mounts (unless you choose to mount radiators outside the case) and can increase 'surface area' of the liquid over the CPU block through increased flow rate. Pump noise is an issue depending on what pump you use). Unfortunately, you rapidly reach a point of limited return for your $$$. The real advantage is the noise to performance ratio.
AIO's generally don't cool as well as a good air cooler mostly because they suffer from poor flow rate.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #6 of 39 (permalink) Old 11-06-2019, 07:54 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 406 (Unique: 273)
MB sag? Is it 2002 and we are back to using paper MBs?
Air cooling trumps CLCs every time. Similar cooling, lower noise, lower price, better longevity and no risk.
ciarlatano is offline
post #7 of 39 (permalink) Old 11-06-2019, 09:14 AM
Fix it till its broke
Owterspace's Avatar
Rep: 4 (Unique: 3)
Compared to my R3F my P8Z77V is pretty thin.. and a bit bendy, though not when it’s mounted. The pcb on my 980 classy is also a few layers thicker than the pcb on my gtx 580 matrix platinum, that card has some saggage.
3770K @ 4600MHz 1.315v/Le Grand Macho RT/TY-143/TF8
Asus P8Z77-V/12GB G.Skill Mix @ 1866MHz 9-10-9-24 2T 1.6v
EVGA GTX 980 Classified @ 1480/2000MHz 1.212v
Intel 545S 256 @ Raid 0, WD 1TB Black, Toshiba 1TB
Fractal Design Meshify C TG/CM Silent Pro M2 850
Owterspace is offline
post #8 of 39 (permalink) Old 11-06-2019, 09:24 AM
Overclocker in training
ThrashZone's Avatar
Rep: 78 (Unique: 59)
Hi,
If you don't feel good about the awkward size of large air coolers you can always rig a hanger from the ceiling of the case.
I've done it before
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #9 of 39 (permalink) Old 11-07-2019, 02:51 PM
poah's Avatar
Rep: 4 (Unique: 3)
sorry but that just isn't true.
poah is offline
post #10 of 39 (permalink) Old 11-07-2019, 03:06 PM
StAndrew's Avatar
Rep: 12 (Unique: 8)
A very compelling argument. You have me convinced.
StAndrew is offline
