Which Outdoor Thermometer to Use and How? - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 11-12-2019, 01:19 PM - Thread Starter
Rep: 1 (Unique: 1)
I saw the Airflow guide and in particular the tip on using an outdoor thermometer to monitor temperatures (https://www.overclock.net/forum/246-...l#post22319171). I am now interested in doing something like this as this means I can have a nice but cheap way of having a temperature monitoring screen at the front of my PC (read: no need to set up a tiny screen as the second/third screen within Windows just for temperature monitoring)
But I have a few questions:
1. What keywords should I use when finding such thermometers? So far all I see in Amazon are either those for "smart" homes or those with max temperatures that are too low
2. What should I look out for when it comes to such thermometers?
3. How can they be set such that they are on par or better than temperature monitoring software like Ryzen Master and HWiNFO64?
Thanks!
darkarn is offline
post #2 of 16 (permalink) Old 11-12-2019, 01:26 PM
skupples's Avatar
Rep: 630 (Unique: 342)
uhh... idk about all that...
I'd say get one of the cheep digital fish tank thermos over an outdoor.
though I guess having a classic mercury to look at would be cool? everyone uses enough LEDs now where visibility wouldn't be an issue.
not to mention genuine PC temp probes are like $10 per 10 pack, and accepted by most motherboards.
skupples is offline
post #3 of 16 (permalink) Old 11-14-2019, 05:08 AM
doyll's Avatar
Rep: 1674 (Unique: 931)
Thanks!
Try searching for:
. . "wired wired indoor/outdoor thermometer"
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313.TR1.T RC0.A0.H0.TRS0&_nkw=wired+wired+indoor%2Foutdoor+t hermometer&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw =digital+indoor+%2F+outdoor+thermometer
on ebay and/or Amazon.
If you only want single temp remote sensor themometer to monitor temp in case search for:
. . "fridge thermometer"
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313.TR3.T RC0.A0.H0.TRS1&_nkw=fridge+thermometer&_sacat=0&LH _TitleDesc=0&_osacat=0&_odkw=wired+wired+indoor%2F outdoor+thermometer
or
. . "LCD fridge thermometer"
https://www.ebay.com/itm/5X-Digital-...a273ded8068ab1
or
. . "aquarium / terreriam thermometer"
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=aquarium+ %2F+terreriam+thermometer&_sacat=0&LH_TitleDesc=0& _osacat=0&_odkw=fridge+thermometer
Look for something small and compact.
I like having both room and cooler intakes monitored beause then it's easy to see the difference.
The little LCD fridge / freezer / aquarium models have temp range of -50c to 110c and are 48x28x1.5mm. Small and thin enough to mount onto case with double stick tape or bluetack.
I don't think Ryzen Master and HWiNFO64 and HWiNFO64 can monitor air temp into cooler .. because they have no provision for remote sensors.
doyll is offline
post #4 of 16 (permalink) Old 11-14-2019, 06:01 AM
cssorkinman's Avatar
Rep: 487 (Unique: 274)
cssorkinman is offline
post #5 of 16 (permalink) Old 11-15-2019, 06:58 AM
doyll's Avatar
Quote: Originally Posted by cssorkinman View Post
Just curious, but why did you use one iyou linked to instead of one of the much lower priced digital ones?
doyll is offline
post #6 of 16 (permalink) Old 11-15-2019, 07:14 AM
It was the one in my purchase history - It was a few years back already so I'm a little fuzzy on why I went with that particular one but I had to make it work with an old fan controller/temp readout and I know that the way it was cabled, it would work better than others.
Just meant to be an example.
What's your suggestion?
post #7 of 16 (permalink) Old 11-15-2019, 09:30 AM
doyll's Avatar
I don't connect sensor to internal monitor so use self-contained units. Mine are basic digital indoor / outdoor with wired probe that cost less than a fiver on eBay.
doyll is offline
post #8 of 16 (permalink) Old 11-15-2019, 09:43 AM
Certainly a good option - amazing that such a thing can be produced/sold so economically.
Kinda weird, when I wrote my reply , your previous post was not there . Trying a new browser , maybe that had something to do with it.
post #9 of 16 (permalink) Old 11-15-2019, 10:02 AM
Shawnb99's Avatar
Rep: 46 (Unique: 31)
Any cheap thermostat will do but no need to spend money on that, temp probes that plug into you MB are just as good if not more accurate.
Only reason to buy a LCD one is if you want to read the temps away from the PC, otherwise just buy some probes and plug them into the MB
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #10 of 16 (permalink) Old 11-15-2019, 11:28 AM
doyll's Avatar
Assuming motherboard user has is capable of using probes and probes cost less than cheap indoor/outdoor digital thermometers.
doyll is offline
